Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.00 average.
Old 10-12-2012, 01:44 PM   #12901
E46tknv
My Ride: Fst'r then your e46
You could have just unplugged the coil pox 1 by 1 to see any difference in performance
E46tknv is offline   Reply With Quote
Old 10-12-2012, 02:18 PM   #12902
UDM-E46 Enthusiast
My Ride: 2002 BMW 330I
Water pump.
Going to go replace my water pump and windshield washer fluid pump : )
UDM-E46 Enthusiast is online now   Reply With Quote
Old 10-12-2012, 02:18 PM   #12903
ryannel2003
Modded ///Member
ryannel2003's Avatar
My Ride: 2000 BMW 323i
I was always told to swap the bad coil to another cylinder and see if the misfire follows it to the other cylinder which in this case it did pretty quickly. This would also explain my intermittent hesitation I've been suffering from too.
2000 323i | Orientblau | 160k miles
ryannel2003 is online now   Reply With Quote
Old 10-12-2012, 03:47 PM   #12904
ryannel2003
Modded ///Member
my coil pack died today
Old 10-12-2012, 03:57 PM   #12905
sneakingword
My Ride: e46 325i 03
Anyone can HELP i just put a NEW power steering pump in and fluids in their i drove with out it for a longgggg time nowwww when i turn this moaning sounds coming what do u guys think it is i need to fix it ASAP dont want my pump to mess up the car has 174200 miless
sneakingword is offline   Reply With Quote
Old 10-12-2012, 04:04 PM   #12906
Wolrab
Registered Gadfly
Wolrab's Avatar
My Ride: 330Ci MT, 545i SMG
Send a message via Skype™ to Wolrab
I assume you didn't get the parts from Momentum?
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 10-12-2012, 04:06 PM   #12907
jayb328i
My Ride: E46 2000 328i
Me too..I replaced mine about 5 years ago.
jayb328i is offline   Reply With Quote
Old 10-12-2012, 04:53 PM   #12908
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Yup. Much needed since my fuel gauge is all whacky lately.
Old 10-12-2012, 05:26 PM   #12909
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Got underneath it to replace the inner control arm balljoints (bolted to the subframe and easily replaceable on the XI) when I realized that they tore because the bushings were completely and totally destroyed. So, placed an order with Powerflex. The RTABs should probably be done too, but oh man, I'm beat.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 10-12-2012, 06:44 PM   #12910
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Seems like my vcg leak is gone. Drove her today having some fun.
Btw, 17k...
Old 10-12-2012, 06:56 PM   #12911
Nickvjr
My Ride: 2004 330Ci Conv.
Drive my 330Ci with the top down through Vegas... averaging 28 MPG after VCG and VANOS seal replacement. ;0)
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 10-12-2012, 07:17 PM   #12912
Ice Cold
My Ride: 2005 330xi
Send a message via AIM to Ice Cold
Muffler delete
Follow Me On Instagram: JamesMarshall_E46
My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
Ice Cold is offline   Reply With Quote
Old 10-12-2012, 07:50 PM   #12913
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
Found out my HK tweeters are totally shot. I can't hear it though. Only found it while looking for a rattle in the door panels. **** they are expensive. Anyone know how the Bavarian Soundwerks tweeters sound? They are supposed to be an upgrade but they are cheaper than 2 tweeters.
Old 10-12-2012, 08:52 PM   #12914
Mflara20
My Ride: 2002 330xi
Originally Posted by Crestwood1001 View Post
FYI save the money on shipping and buy the coolant from your local dealer, I just got a gallon for 18$, so from wherever that list is from your overpaying AND adding a lot of weight which will bump up your shipping costs
It was free shipping on all of this...
Mflara20 is offline   Reply With Quote
Old 10-12-2012, 08:53 PM   #12915
Mflara20
My Ride: 2002 330xi
Originally Posted by tock172 View Post
Forget those brakes. Don't buy brakes on ebay.
So I made a huge mistake?
Old 10-12-2012, 08:55 PM   #12916
Mflara20
My Ride: 2002 330xi
Why u say this?
Old 10-12-2012, 10:15 PM   #12917
Hollywood516
Hollywood516's Avatar
My Ride: 02 330i
I got run into the jersey barrier on Meadowbrook pkwy on Long Island by a couple kids racing. I think I bent both front and rear drivers side wheels (they are all rashed up), or messed something up front in the suspension. Car shakes at 40 mph, and pulls to the left pretty bad.The whole thing just sucks.. I finally got the car running perfect (just spent $2,700 couple months ago going over everything) looking the way I wanted,and now this happens..
Hollywood516 is offline   Reply With Quote
Old 10-13-2012, 06:36 AM   #12918
WDE46
Weagle Weagle
WDE46's Avatar
Originally Posted by Mflara20 View Post
Why u say this?
Because you don't know who made them. I wouldn't cheap out on something like rotors. If they are forged poorly then they are dangerous. They will crack under repeated braking (heating) and cooling. Then you hit the car in front of you at 70 mph off the interstate ramp. At least get a brand so you can sue someone when they fail hahaha.
Just read the Ebay pic. You got cross drilled/slotted. That means the rotors are going to be further weakened even more than the lower quality metal would have done. I wouldn't use these. $200 for 4 rotors and pads is way too cheap. Hell, my Grand Cherokee fronts only were $300 (though those are bigger than our 330 brakes). Get the $400(Brembo rotors) kit from TurnerMotorsports and don't buy cross drilled. I would return them. Brakes are way too important to cheap out on. They can save your life when they work or kill you if they fail. Those type of items need quality parts. You can cheap out on other things less important.
Old 10-13-2012, 06:43 AM   #12919
WDE46
Weagle Weagle
WDE46's Avatar
Did you file a police report so you can get insurance paid?
Old 10-13-2012, 07:00 AM   #12920
DeL2000
My Ride: BMW 323i
Replaced my valve cover gasket, but broke the crank valve breather hose.....taped til I can get a new hose.
DeL2000 is offline   Reply With Quote
Rate This Thread
