Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 10-16-2012, 01:31 PM   #12981
filipinoise
My Ride: '02 325ci
Originally Posted by tock172 View Post
If I am not mistaken, it will work with other phones besides iPhones. Definitely a good investment. Probably the best thing I've purchased for my car yet.
Ah, now I'm starting to strongly consider a bluetooth integration kit for my E46 since I've already got my USA-Spec PA12-BMW for my audio and iPhone charging needs and I love it. I may be purchasing the Parrot CK3000 sometime soon, though, seems to give me all of the features I want for the right price.. And, not to mention, delmarco's DIY should make the install very easy to do. If I didn't have this USA-Spec PA12-BMW already, I'd probably be considering the DICE Mediabridge. I really want to use Siri at times but having to remove my hands from the wheel/shifter can be a bit inconvenient. And of course, bluetooth would just help me overall with answering calls, reading e-mails, etc.
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
filipinoise is offline   Reply With Quote
Old 10-16-2012, 01:38 PM   #12982
My Ride: 2016 Lexus
I want one too. Did you have to run it from the trunk cd changer connector? i already ran a dice module from there and the module sits beneath the radio. wonder if i can use the existing wire i ran? i am NOT running anymore wire down the center of teh car. PITA!!
BTW, I'm 10 posts away from 10,000 POSTS!!!!!!!!!!!!!! what to do what to do!
Old 10-16-2012, 02:30 PM   #12983
filipinoise
My Ride: '02 325ci
For my USA-Spec, what I did was run the data cable from the trunk through the rear driver's side firewall, under the backseats onto the other side, all the way up and into the glovebox where the unit sits. I then wired the iPhone cable through the inside of the dash, took the sunglass holder out, drilled a small hole into it, and that's now where the iPhone cable of my USA-Spec sits. So when I need to use it, I just open the sunglass holder, pull the cable out, connect it to my iPhone, and set the iPhone onto my Bimmian Mobile Dash Mount. When not in use, I just secure it inside of the sunglass holder, out of sight when looking into the car from the outside.
'02 325ci 5MT
www.eluisphoto.com
Old 10-16-2012, 02:33 PM   #12984
filipinoise
My Ride: '02 325ci
Oh, and I forgot to post this a while back: Last week, Drew from Swift Motorworks came down and installed my ST Coilovers, Meyle HD RSM's w/ Z3 reinforcement plates, OEM FSM's, OEM front strut reinforcement plates, Meyle HD RTAB's, Meyle HD FCA's w/ Meyle HD FCAB's, and OEM steering coupling. He got the job done very well and in a timely fashion. I highly recommend his services. Alignment will be done this weekend!
'02 325ci 5MT
www.eluisphoto.com
Old 10-16-2012, 03:08 PM   #12985
My Ride: 2016 Lexus
no DIY?
Old 10-16-2012, 03:31 PM   #12986
filipinoise
My Ride: '02 325ci
no DIY?
I know, I know.. This was literally the first time I've had someone else work on the car that wasn't tires/alignment/balancing/etc. I'm pretty big on DIY (to name a few off the top of my head: VANOS seals, VCG, plugs & pre-cat o2 sensors, overhauled cooling system [E46Mango brownie points lol], voltage regulator, etc.) but unfortunately school and work have been taking up ALL of my time. I'm a chem major at USF taking 16 units (ochem, physics, calc ii, and rhet) and wouldn't have been able to tackle the DIY until December/January.
'02 325ci 5MT
www.eluisphoto.com
Old 10-16-2012, 04:16 PM   #12987
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Finally picked up my spare wheel. Thing is new
Old 10-16-2012, 06:25 PM   #12988
My Ride: 2016 Lexus
Tsk tsk. Yes you got 50 MP for doing the cooling system, but you got 49 taken away for paying someone else to do the work. Usually I'd take away 50 but you get to keep one since you had an excuse.
1 MP is good for nothing, really. Well, ok, fine... you can get one free joke about DMAX All it's good for
Old 10-16-2012, 06:41 PM   #12989
98bimmer
My Ride: E90 330i, E36 328i
pics?
98bimmer is offline   Reply With Quote
Old 10-16-2012, 07:06 PM   #12990
kaldE46
My Ride: 2001 325i
Refreshed lower steering wheel trim. Kinda messed it up because I was too eager to put it back in the car before it cured, made a little blemish on it.
kaldE46 is offline   Reply With Quote
Old 10-16-2012, 07:16 PM   #12991
tock172
My Ride: '12 135i DCT
I did run the cable from the CD changer connector in the trunk, however I followed the BSW procedure on YouTube, which is to run the cable in the carpet under the seats, under the lower kick panels and up to the glove box. For the mic, I ran it up the A-Pillar and at the top of the windshield to the location of the BMW Assist mic which I left up there.
The install was surprising easy.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT
Old 10-16-2012, 07:17 PM   #12992
tock172
What'd you use to do this?
Old 10-16-2012, 07:34 PM   #12993
kaldE46
My Ride: 2001 325i
Sanded with 400 grit sandpaper, 2 coats of primer, 2 coats of the cheapest matte black paint I could find at home depot(4 bucks)
Old 10-16-2012, 09:43 PM   #12994
tock172
Wow I'm impressed. Looks good. By the way, are those Sperry topsiders you're wearing in the photo?
Old 10-16-2012, 10:22 PM   #12995
ZHPinthe103
My Ride: 325i Black on beige
Those look like sperrys...haha what about it?
ZHPinthe103 is offline   Reply With Quote
Old 10-16-2012, 10:54 PM   #12996
kaldE46
My Ride: 2001 325i
Thank you! I think I might redo it though because that blemish will bother me.
Haha yeah. Those are my worn out falling apart Sperry's I wear when I'm working on my car. I've got my better condition ones I wear every day too. I love them. Great shoes.
Old 10-16-2012, 11:06 PM   #12997
luc
My Ride: '04 325i
I use that sh#@ on everything
Just painted my homies miata with it a couple weeks ago hah
#franks
Sent from my ADR6350 using Bimmer App
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 10-16-2012, 11:47 PM   #12998
jrrwired
My Ride: 2001 BMW 330CI
This weekend I hard wired my HID lights in, and hard wired my halos to turn on when I punch the fog lights on.
jrrwired is offline   Reply With Quote
Old 10-17-2012, 01:19 AM   #12999
My Ride: 2016 Lexus
That sounds sketchy and dangerous...
Old 10-17-2012, 01:21 AM   #13000
tock172
They're a great shoe choice!
Sperry's are my absolute favorite shoe! I wear them daily and I have probably walked tens of thousands of miles in them. I have a beach pair and an every day pair and several retired pairs. All are pretty worn out, but I love them and they just fit perfectly. We just got another week of summer weather (90s today) I literally haven't worn socks for months! I have a terrible 'topsider tan' on my feet. It looks like I was spray painted!
Rate This Thread
