Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-22-2012, 08:07 PM   #13201
bono975
My Ride: 325i, X5 35d
Fixed a passenger door handle...cable popped out of the clip. Disconnected the battery, pulled the door apart, put the cable back in place et voila! All is good. I also cleaned the ac compressor and air vents.
A good day all in all.
bono975 is offline   Reply With Quote
Old 10-22-2012, 08:07 PM   #13202
bono975
Old 10-22-2012, 08:16 PM   #13203
Zchild
My Ride: 2000 BMW 3XXi ZSP
Changed out my old EBC front "Green Stuff" brake pads for a new set, replaced my old PIAA silicone wiper blades and my purchased a new fuel filter and a fuel pressure regulator. Should be able to install both fuel parts on Wednesday afternoon.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 10-22-2012, 08:30 PM   #13204
NOVAbimmer
My Ride: E60M
parts will be here wednesday
NOVAbimmer is offline   Reply With Quote
Old 10-23-2012, 07:47 AM   #13205
WDE46
My Ride: '13 128i, '04 330Ci
The filter and regulator should be one part. Anyway, buy some new fuel hose (1-2 ft) with that because you will probably have to destroy the old ones to get them off. Also get hose clamps. Go to the parts store and get 5/16" (7.9mm) internal diameter FUEL INJECTOR hose. Do not get regular fuel line. Me and the guy at the store were talking about the pressure in the line (50 psi). He was not okay with using regular fuel line at that pressure and neither was I. Also pick up some new clamps that fit the hose. The stock BMW clamps are stupid.
Old 10-23-2012, 08:44 AM   #13206
jerseyrider
My Ride: 2001 330Ci-06 K1200s
Just did my cooling system overhaul. Not a bad DIY, but the expansion tank was a b!tch. I can't understand how two o-rings can have that much grip on plastic.
I don't know how old the water pump and expansion tank and upper and lower hoses were that I replaced but they look to be in excellent condition so if anyone needs an emergency spare, let me know.
Next project is the fabric on the "B" pillars. If they come out better than the "A" and "C" pilllars, I'm going to re-cover them as I'm trying a different adhesive. If they come out like crap, I'm just going to bite the bullet and order all new ones.
jerseyrider is offline   Reply With Quote
Old 10-23-2012, 08:50 AM   #13207
jerseyrider
When I replaced my fuel filter, it looked like the hex heads on the clamp screws weren't symmetrical. Correct me if I'm wrong, but it looked like they need a special socket. When I got my filter, the parts guy threw in new hose clamps and a length of the correct hose for the fuel lines.
Old 10-23-2012, 12:43 PM   #13208
WDE46
Correct. They are a stupid design. You have to use pliers to retighten them. You can loosen them with a flathead but the bolt is designed so it can only be turned counterclockwise with a flathead (stupid). It's the most infuriating simple thing I've ever seen. There is absolutely no reason for these retarded clamps. Whoever specified them ought to be shot.
Old 10-23-2012, 12:47 PM   #13209
My Ride: Lexus
I believe they're one time use clamps not designed to be re-used. You can see the safety aspect of it. Replacing fuel filter and they don't want you reusing old rusty weak clamps only to leak gas all over the hot exhaust area. Just cut them off. no biggy. need to be replaced anyway
Old 10-23-2012, 12:54 PM   #13210
trj
My Ride: 325Ci
Wash, clay and polish.
Will head out to wax it in a bit.
Possibly I will do the VCG and oil change if I am really in the mood.
Snow in the forecast for thursday
Old 10-23-2012, 01:09 PM   #13211
JokerElite
My Ride: 95 M3, 04 M3, 09 328
Already? I guess it starts early in Denver.
1995 BMW M3 - Avus Blue | 2004 BMW M3 - Jet Black | 2009 328xi - Alpine White
JokerElite is offline   Reply With Quote
Old 10-23-2012, 01:10 PM   #13212
My Ride: Lexus
Me too TR. I stripped, clayed, and waxed my car. i should post pictures and a wax review.
I used this:
Amazon.com - Collinite 845 insulator wax
My friend who does pro detailing recommended this to me. Apparently, it's extremely durable and rock hard for super long-term. I'm told it's good up to two years and again is extremely extremely tough.
Paint feels so awesomely slippery and shines bright like a diamond.
Old 10-23-2012, 01:12 PM   #13213
trj
My Ride: 325Ci
We already had a first shot of snow 2 weeks ago. Now its officially the start of snow.
Even some ski mountains are open now.
Old 10-23-2012, 01:14 PM   #13214
trj
My Ride: 325Ci
I used this:
I just used a regular hose and car wash soap.
3m clay bar.
turtle wax compound to polish.
And going to use meguirar's carnabura wax.
I have a lot left in them, so may be after they are done I will switch the one you recommended. It surely looks nice though.
Old 10-23-2012, 01:27 PM   #13215
My Ride: Lexus
3m clay bar.
Yep my friend says to stay away from auto parts store stuff. figured why not try something good for a change. i also use chemical guys hybrid v7 spray wax/sealant.
Amazon.com - Chemical Guys Hybrid V7 Optical Select High Gloss Spray Sealant
Old 10-23-2012, 01:39 PM   #13216
Beamer Creamer
My Ride: 2005 bmw m3
All i do is wash car, wax twice a year( which is only 6 months in saskatchewan)with meguires in between use (forgot brand name) spray on wax. F&$in awesome stuff. Car looks great. I like to have it look good but how much time does it take to clay, polish, then wax. And have basically same look unless your eyeball is touching car? ( not against it just asking)
Beamer Creamer is offline   Reply With Quote
Old 10-23-2012, 01:47 PM   #13217
WDE46
Screw rationality. I want to hate something.
Old 10-23-2012, 01:51 PM   #13218
WDE46
A wash/cut/polish/wax job is an all day thing for sure. It will be noticable from a distance. If you do it right it's like a mirror. Look at your paint now and I am sure there are swirl marks. You don't do this often. It's best to do this once, then keep a good sealant and wax over the good paint plus treating it well. That way you don't have to do this but maybe a handful of times while you own the car.
Old 10-23-2012, 02:14 PM   #13219
My Ride: Lexus
Clay makes a big difference. You think your car looks clean to the touch but when you clay it after a year, the clay bar ends up a different color (even if your paint is smooth to the touch) truth is so much stuff just sticks to the surface not visible to the naked eye. a compromised finish is one that doesn't reflect well and won't be as smooth. it's worth it!
Old 10-23-2012, 03:06 PM   #13220
RKiepper
My Ride: 1999 E46 328I x2
Got this in, looking good for an automatic. Don't have to worry about those little shutter things anymore.
RKiepper is offline   Reply With Quote
Rate This Thread
