Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 10-27-2012, 03:12 AM   #13341
hizhinezz
My Ride: 01 330i
Post below phone is doubling down
hizhinezz is offline   Reply With Quote
Old 10-27-2012, 03:18 AM   #13342
hizhinezz
My Ride: 01 330i
first off aside from the fact that you installed the wrong parts on your car, you installed used parts on your car. particularly stock M3 shocks/struts. is this correct?
Omfg yes used parts like my used exhaust and used airbox and used tires and all the other great used parts I've installed and enjoyed thoroughly with no ill affects whatsoever.
So obviously I misspoke and there is no e46 m3 sedan honestly I'd never researched and was unawares given later models. So yes I've got 20k mile m3 suspension(4 springs and shocks/struts with all related hw and new/used turner sways/links) in my car vs 80k factory suspension and boy does it seem to work great and it swapped right on like a glove.
I love that this outrages you and will thus enjoy it all that much further you uptight dickwad. People like you with limited vision make living a life of open opportunities that much better, go hide somewhere safe and ill just go around you.
Old 10-27-2012, 10:22 AM   #13343
tock172
My Ride: '12 135i DCT
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 10-27-2012, 11:04 AM   #13344
Beamer Creamer
My Ride: 2005 bmw m3
I love the attitude. Thanks for the morning laugh.
Beamer Creamer is offline   Reply With Quote
Old 10-27-2012, 11:18 AM   #13345
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by Beamer Creamer View Post
Do the hybrids use friction surfaces or just electrical field to stop? I wont even start in that,im for sure wrong one way or another. Electrobraking has been used since 20th century, i just thought bit diff about it.Anywayz the abs was designed for people who cant drive and hold brakes to floor and turn steering wheel. Cant even be a debate about it, they dont stop you as fast as unassisted braking. The theory is there but ive never driven 1 vehicle that has a functioning system on ice. They all suck. Ive had to feather on the handbrake to stop couple of times. It was supposed to give you steering if you lock em all up. Many times the abs will delay way to long between braking again or it applies to much force immediately and results in kicking out to quick its ok im done. Good posts from you though
They use a mix of both. For light braking they can use just the electric motor, but for real braking they use conventional brakes.
ABS was designed to prevent locking the brakes under a panic stop. For 99% of people they are going to stop faster than regular brakes that will lock up. I don't know what cars you've driven, but every one I have tested ABS on has worked flawlessly. My Jeep's ABS worked perfectly on mud and snow.
Old 10-27-2012, 11:24 AM   #13346
My Ride: Lexus
lol have you read the fit ///m parts on non-m thread? its common knowledge that the m3 suspension parts arent meant for non-ms. nothing is gained from it anyway.
those struts/shocks you installed are OE (great when new) but seriously degraded (if not completely dead) when used. Do you really think the seller was truthful when he said it has 20k miles on it? oldest trick in the book when selling used suspension components
Old 10-27-2012, 12:13 PM   #13347
Beamer Creamer
Ok. I worked at chrysler dodge for bout a year. Maybe we have different ice in canada.lol. I do find that 4x4 vehicles have more effective brakes cause there is equal drag from drivetrain on all wheels instead of locking front up as soon as brakes are touched( with 4x4 activated). I have had alot of hemis that i felt like sticking a foot on the ground to stop and i owed a 323ci that one time made abs noise for about 300 yards and went off end of road before i got it stopped. Good thing it was ramped. I was only going about 25 mph when started braking. Sure driver error too but i always test every vehicle skid control in parking lots to know how they will react. Ive found sometimes you can no doubt stop faster using handbrake with abs for fronts. Also the vehicles without abs working sure seem alot better for me anyway. You havent noticed the change in pulse rate when you step on brake harder? Abs works on same principle as traction control and ide say i can pickup speed faster without it, so should be same for stopping( on ice) on dry pavement i think the abs system is fast enough to keep up but ice is noticeable to me how much lag there is in activation( why it kicks out so quick, cause it gives to much pressure when it kicks in)
Old 10-27-2012, 01:07 PM   #13348
WDE46
I said my Jeep worked fine on snow not ice. Nothing works on ice, ABS or not. You slid off the road b/c of the ice not your ABS. ABS is similar to TCS in that it controls wheel slip, but it does it in a different manner. ABS controls brake force and TCS controls engine torque.
Also, thats a parking brake, not a handbrake.
Old 10-27-2012, 02:17 PM   #13349
Beamer Creamer
Ok. So abs is made for when you have grip.ahhh i see now.i didnt mean ice wasnt the cause of brakes not working properly, just that abs was big contributer to overshooting corner. Also meant similar in that they both retard the systems.just cause theory is there doesnt mean system automatically works. Look at trucks with 1 sensor on diff for both back tires and 1 for the front wheels. How is that good? And the parking brake also has gone through names such as the e brake( emergency brake) along with handbrake because its used with your hand i guess they should change footpedal name to normal braking applicator
Old 10-27-2012, 04:27 PM   #13350
WDE46
I don't even know what you're trying to say. ABS reacts hundred of times faster than any human can.
Old 10-27-2012, 06:49 PM   #13351
limpiabota809
My Ride: 330 XI
Getting muffler delete done now
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 10-27-2012, 07:23 PM   #13352
Pete_repete
My Ride: 98 Civic, 02 M3
Sound clip when your done please
Pete_repete is offline   Reply With Quote
Old 10-27-2012, 07:30 PM   #13353
darksideracer69
My Ride: 01 325ci
There's so many sound clips, search.
Oem bmw all weather mats, active shift knob and license plate cover thingy. Yay!
Sent from my SGH-T959 using Bimmer App
IMAG02051
Old 10-27-2012, 07:32 PM   #13354
hizhinezz
My Ride: 01 330i
I know the rebound was significantly stiffer than that of the 85k+ oem suspension in mine and that along with new sways it resulted in a much better ride... what's the downside? Parts were noticeably not that used, especially compared to mine.
For a few hundred bucks I feel like I got a much firmer suspension that will last me until I can afford Bilsteins. Now you tell me how it's going to blow up and destroy my car...
And just because you can say the shop lied doesn't mean it did, I mean, I paid less than $200 for all the pieces, what do they really gain from that if they are f'g me? Lunch money? There are 50k, 100k race cars in their shop as we speak, wouldn't it be easier to pad some work for one of those customers? You must be a Republican.
Go study your manuals, I'll be enjoying my new suspenders.
Old 10-27-2012, 08:18 PM   #13355
zabalzae
My Ride: 01 330ci
Painted rims
Sent from my SAMSUNG-SGH-I747 using Bimmer App
zabalzae is offline   Reply With Quote
Old 10-27-2012, 08:29 PM   #13356
darksideracer69
My Ride: 01 325ci
I wanna polish the lip on my hartge rims. But I'm being lazy.
IMAG02051
Old 10-27-2012, 10:44 PM   #13357
hizhinezz
My Ride: 01 330i
Mango inspired me (see sig) to put off the cooling system refresh another week or two and buy off on some CKs that have been haunting me on CL for a little while.. Fn thrilled:
Old 10-27-2012, 10:50 PM   #13358
jgold47
My Ride: 2004 X5 3.0
made a deal to trade it in on an x5. Time to upgrade. Picking it up monday. Trading one set of problems for another. Will post details as they develop. Was able to pull a few things off the car before I worked out the deal. Will have a pretty healty f/s thread popping up here shortly. Kinda sad to be moving on, but this car was never the right fit for me.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 10-27-2012, 10:56 PM   #13359
limpiabota809
My Ride: 330 XI
How much?
Old 10-28-2012, 12:55 AM   #13360
hizhinezz
My Ride: 01 330i
A gentleman never tells but I paid about a third of what he paid new for full package a year ago and tires are good and still 60% there...
Rate This Thread
