Rating:
#13741 |
clean it
#13742 |
Thermostat and coolant flush.
![]() -2003 M3 Vert -1967 Mini Cooper |
#13743 |
#13744 | |
#13745 |
Slap on some STP-3 rims with some brand spank'n new tires (= and slam the hell out of it
#13746 |
I hate when it takes forever to heat up in this cold. I'm tryna get the heater on but I'm just freezing my balls off. Much better now. But my dumbas$ friend didn't tighten the top hose all the way and the b1tch started leaking. Luckily it didn't overheat but I still slapped him across the face. By the end of the month I'll have my valves adjusted, new spark plugs and new valve cover gasket. Then I'll be done with the motor for now. Feels good.
#13747 |
i had an issue with my fairing where it was doing that when i first put it on, then realized the inner clips were supposed to be in a different position and it worked perfectly. as for the bars i cut mine so that the end cap is against the outside of the foot where the bar slides through it. looks a lot cleaner now that all the angles match.
#13748 |
Did:
1. New spark plugs Old Bosch on right. New NGK on left. The Bosch ones had been on there since I bought the car at 50k miles, but probably before, now has 97,500. Bought on Amazon. FYI: do not use antiseize on these plugs, NGK has a tech bulletin. 2. Strut tower bar ECS carbon fiber Probably 15 minutes to install. Instantly tell the difference, whole car feels solid. 3. Sprint booster Sport mode is perfect for quick, smooth heel/toe downshifts. Race mode turns the car into an animal! Loving all three already |
#13749 |
In the past week
Installed -SuperSprint Race Muffler -SuperSprint X-Pipe -K&N Intake (haven't decided if I'm going to keep this yet) -Goodyear Eagle F1 Asymmetric to the rears Repaired -RTABs replaced -Inside wheel well (drivers front) -Ambient temp sensor replaced Updated -120GB SSD in glovebox now wired to dynavin completely stealth ![]() To come next spring (hopefully) -SuperSprint Stepped Headers (anyone selling theirs? )
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein Last edited by morningisbad; 11-13-2012 at 08:58 AM. |
#13750 | |
Weagle Weagle
#13751 |
Removed the old, nasty cabin air filter and installed a new one.
Replaced the old license plate lights with complete LED inserts.
#13752 |
NWS
#13753 |
My Ride: '03 325i --> '13 GTI
#13754 |
#13755 | |
Also had to modify some of the dynavin code to auto mount the hard drive by tricking it into thinking it's an SD card.
-Karl Welzein |
#13756 |
Weagle Weagle
Nice. So you are a bit of a computer nerd too. Good to know.
#13757 |
My VCG and spark plugs come Friday. Hope to have my valve adjustment Monday. I have no clue the last time it was done.
#13758 |
The 36F air outside gave me a new idea for the chrome trim.. Anyone ever consider frosted trim?
#13759 |
Ordered brake pad sensors and brake retaining bolts from pelican parts...brakes and rotors come Friday along with sensors hopefully get it done Saturday afternoon
#13760 |
Ordered exhaust CPS, o-ring, bolt.
Extra: VANOS line washers, hose clamps for intake boots to reach the free shipping cap(no sense in spending $9 in shipping and receiving it the same day as free shipping does if I can just add $4 worth of stuff). I have a ton of extra o-rings, nuts, bolts, screws, clips, washers just because I am cheap and add them for free shipping when I reach near that amount. lol. Now just praying that the CPS bolt is not stripped, because it felt like it was stripped by PO.
| Rate This Thread | |
