Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 11-17-2012, 02:01 AM   #13841
illestminimike
My Ride: Project Drama
Drove it down to San Diego and met with some forum members. Ran good!
Old 11-17-2012, 08:14 AM   #13842
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
One of my led license plate bulbs went whacky. Thing is flickering like the strobes on a cop car lol.
Ordered Morimoto Mini projectors, a hid kit with 3000k bulbs and E46 shrouds. Going QUAD XENON
Old 11-17-2012, 10:33 AM   #13843
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Helped a friend throw on a cat-back, then took some pics. AA exhaust for the n55 sounds way nice.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 11-17-2012, 10:52 AM   #13844
tock172
My Ride: '12 135i DCT
How does your car stack up against that thing?
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 11-17-2012, 11:54 AM   #13845
deadwood83
The results are surprisingly positive. From 60 it has me because of gearing, but at any other time...
Though at 6900 I'm hitting 10.7psi with an altitude density of 7000ft. I think I'll need to detune it a bit if I go to sea level or else risk engine damage.
Idle vac at my pressure is -16 which is -18/-19 at STP, so the engine is definitely healthy! The entire top end looks like this (90k miles):
BTW, RE050A's in the snow? Puckered anus.
Old 11-17-2012, 12:26 PM   #13846
tock172
Idle vac at my pressure is -16 which is -18/-19 at STP, so the engine is definitely healthy! The entire top end looks like this (90k miles):[/URL]
So awesome. How's the trans fairing so far? If I recall, you posted about some shudder at high RPM?
Old 11-17-2012, 12:32 PM   #13847
serdar255
My Ride: '01 325ci / '90 325i
Good luck. Should be awesome.
Sent from my A500 using Bimmer App
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 11-17-2012, 01:10 PM   #13848
limpiabota809
My Ride: 330 XI
Result of adding piezo buzzer with a white fleece *edit* da wife will be upset...now just have to code her to actually have it work
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 11-17-2012, 02:13 PM   #13849
deadwood83
It still occasionally shifts hard under .5-.7 throttle, but shows zero signs of slipping nor gear hunting. I still haven't gotten around to changing the trans fluid, and it's still running lean (though 1 quart torco/fill keeps the knock goblins away) but I have what I think I need to bump the fuel pressure. Might throw that in tomorrow when I put my A/S back on and change oil if there's time.
But there's also a broken window regulator (driver's window), a squeaking pulley (A/C idler probably, hopefully not one of the AA idlers, though their support has been fantastic so far), and I still don't have wheels of my own. I am using my friend's 193M summers because he loves seeing them on my car and I do too! But they're so insanely heavy. I think Sportlines are for me.
Here's some AA exhaust goodness. Major props to Viral for putting up with my friend and making sure things arrived on time. If I had one suggestion for the system though, it would be regarding the clamps. The clamps that came on the mufflers are super weak and strip easily. IMO all four clamps should be the incredibly beefy midpipe clamps. We also encountered the section 1 or 2 being about .5" too short, resulting in the pipe not covering the slip fit cuts at the section one-two junction. Luckily some clever fiberglass taping and clamping over the tape over the gapped areas then heat treatment cured it and ensured it should last for at least a couple years.
Not sure if there are any weld junkies here, but here are some shots of the system. I've been impressed with AA's stuff.
Old 11-17-2012, 07:50 PM   #13850
olivierE46M3
My Ride: E46 M3 2003
Keep or remove colors?
olivierE46M3 is offline   Reply With Quote
Old 11-17-2012, 07:51 PM   #13851
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Remove.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 11-17-2012, 09:31 PM   #13852
HyeWarrior
My Ride: '03 325i --> '13 GTI
Traded lm reps for stockers, time to make a for sale ad
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 11-17-2012, 10:56 PM   #13853
BimmerFool1
My Ride: 02' BMW 325i 5MT
Replaced the coolant, its getting colder out!
lol.
BimmerFool1 is offline   Reply With Quote
Old 11-17-2012, 11:01 PM   #13854
Dreamwerke
My Ride: 2001 m3 6spd
Found a coolant leak, still trying to fix it
Dreamwerke is offline   Reply With Quote
Old 11-17-2012, 11:11 PM   #13855
NightRaider93
My Ride: 2007 Z4 Coupe
:'( I really wish I could've traded my 119s...
Sent from my SGH-I777 using Bimmer App
-Spencer
NightRaider93 is offline   Reply With Quote
Old 11-17-2012, 11:20 PM   #13856
tock172
Installed an M3 steering wheel and replaced my C pillar cover.
Old 11-17-2012, 11:34 PM   #13857
serdar255
Old 11-17-2012, 11:40 PM   #13858
HyeWarrior
Sorry man
Wow
So Amaze
Much Torque Steer
Such FWDoge
Old 11-18-2012, 12:46 AM   #13859
RKiepper
My Ride: 1999 E46 328I x2
Bought snikwad's aero kit for my sexy ass ferg.
Keepin' it OEM, ah yeah!!
RKiepper is offline   Reply With Quote
Old 11-18-2012, 12:24 PM   #13860
ELCID86
My Ride: 2004 330i (ZHP) x2
Reconnected the tube from the F-connector to the fuel filter that somehow came loose when I broke the F-connect. Oh, and ordered two f-connectors and two new front tires.
http://forum.e46fanatics.com/showpos...2&postcount=35
ELCID86 is offline   Reply With Quote
Rate This Thread
