Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 11-26-2012, 12:05 AM   #14041
serdar255
My Ride: '01 325ci / '90 325i
Originally Posted by RKiepper View Post
Tomorrow is going to be a good day.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 11-26-2012, 02:09 AM   #14042
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Originally Posted by NFSx328ci View Post
Swapped out my cup holders for the Euro Tray
What up Snik?! I see you left VA aswell.
Yeah. Hopefully not for too long tho
Do you ride a sportbike?
Old 11-26-2012, 03:45 AM   #14043
mightymouse777
My Ride: 01 325Ci
Are you able to replace just the padding on top of the door armrest? If so does anyone know where to get 1
Sent from my LG-P930 using Bimmer App
mightymouse777 is offline   Reply With Quote
Old 11-26-2012, 09:23 AM   #14044
TT330i
My Ride: 2003 330i
Thanksgiving weekend maintenance - got car back from body shop after having some dents taken out, pressure washed engine bay, replaced idler and tensioner pulley, replaced (again) upper and lower intake boots, changed power steering, rear differential, and manual transmission fluid, new air filter, then washed, clayed, and polished.
TT330i is offline   Reply With Quote
Old 11-26-2012, 10:25 AM   #14045
Hornung418
My Ride: '04 MB ZHP
Bought oil from the dealer at $6.70/qt. New filter and some coolant to go along with that. Radiator, oil change and headers going on this week. : excited:
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 11-26-2012, 10:58 AM   #14046
RKiepper
My Ride: 1999 E46 328I x2
Have fun getting those headers in.
RKiepper is offline   Reply With Quote
Old 11-26-2012, 11:14 AM   #14047
darksideracer69
My Ride: 01 325ci
Seriously about Damn time you get some headers man.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 11-26-2012, 11:18 AM   #14048
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Finalizing my DIY vid on the morimoto retrofit then uploading to youtube!
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 11-26-2012, 11:22 AM   #14049
briangl92
My Ride: VQ37VHR
Originally Posted by Solidjake View Post
[IMGhttp://imageshack.us/a/img7/2029/img5669h.jpg[/IMG]
[IMGhttp://imageshack.us/a/img696/9392/img5672s.jpg[/IMG]
[IMGhttp://imageshack.us/a/img849/4497/img5671k.jpg[/IMG]
[IMGhttp://imageshack.us/a/img801/96/img5674z.jpg[/IMG]
[IMGhttp://imageshack.us/a/img11/8625/img5675a.jpg[/IMG]
looks sweet Jake!
briangl92 is offline   Reply With Quote
Old 11-26-2012, 11:22 AM   #14050
trj
My Ride: 325Ci
Yah, in for the DIY on the wiring.
No more flash function I guess?
Old 11-26-2012, 11:23 AM   #14051
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yea flash is gone, but I still have my OEM lows which are bi-xenon (still a highbeam technically)
For the wiring you have to wait a week. I plan to run a wire harness to the battery and use the trigger wire going to a switch so I can turn on these lights manually.
Old 11-26-2012, 11:25 AM   #14052
Hornung418
My Ride: '04 MB ZHP
Can't be that hard. Already deleted the washer tank and the SAP. And I have swivel extensions and an impact wrench. Can't be any harder than pulling the intake manifold or changing the engine mounts.
Old 11-26-2012, 11:44 AM   #14053
briangl92
My Ride: VQ37VHR
I'd just get rid of the cutoff shield and run them as normal highbeams lol. Jake, was it a labor intensive job or did you get something that was a plug and play job (in terms of fitting the projectors and shrouds).
Old 11-26-2012, 12:27 PM   #14054
trj
My Ride: 325Ci
Yah, I have the similar setup on the lows.
Still need to get the projectors for high beams(already have the shrouds and HID kit). Will the OEM projectors fit on the high beam bowls?
I believe you have done retrofit on your lows as well.
I have OEM bixenon retrofit(with the bixenon bowls) on the halogen housings with cheap HID kit(I know, will upgrade the bulbs soon). Bi-xenon projector function connected to the high beams for now.
Also, I would like to see where are you mounting your ballasts for both high and low beam.
Old 11-26-2012, 03:32 PM   #14055
HBizzo88
My Ride: 2002 bmw 330ci
Road it hard/left it wet :wink:
HBizzo88 is offline   Reply With Quote
Old 11-26-2012, 05:30 PM   #14056
RKiepper
I have a new love for this car after the M3 wheels went on... Finally.
Old 11-26-2012, 06:07 PM   #14057
Solidjake
Zero. Leaks.
Solidjake's Avatar
The first shroud was a pain to file down (took an hour+ manually) For the second one my friend has a Dremel with the sanding end so it took 10 min lol
Still working on how to wire it to a separate switch. They also point down a bit but I'm not sure to how to raise them.
Old 11-26-2012, 06:08 PM   #14058
Nerdy46
My Ride: 328i
Out old...
In new:
Nerdy46 is offline   Reply With Quote
Old 11-26-2012, 08:30 PM   #14059
pauljohnbaker
My Ride: 2001 M3 486RWHP
Plasti Dip hood
Paul Baker
486WHP/375WTQ (pump gas)
AA LVL 2 SC, AA METHANOL INJECTION, UUC CLUTCH & FLYWHEEL, DINAN 3.91 LSD, AA HEADER, SS HIFLOW CATS, SS RES X-PIPE, SS RACE MUFFLER, TURNER SUBFRAME KIT, TURNER REAR CAMBER ARMS, POWERFLEX BUSHINGS, GC FRONT & REAR SWAY BARS, ACS SPORT SUSPENSION, ACS SHORT SHIFT KIT, VORSTEINER HOOD & FRONT BUMPER, ESCORT 9500CI
pauljohnbaker is offline   Reply With Quote
Old 11-26-2012, 08:31 PM   #14060
pauljohnbaker
Plasti Dip hood
Paul Baker
Rate This Thread
