Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 11-29-2012, 08:55 PM   #14161
Hornung418
My Ride: '04 MB ZHP
Replaced my radiator today...
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
Old 11-29-2012, 10:26 PM   #14162
dude14
My Ride: '04 330CI ZHP
Replaced the rotted vacuum hoses on the fuel pressure regulator.
dude14 is offline   Reply With Quote
Old 11-29-2012, 11:05 PM   #14163
Daron666
My Ride: 02 330CI Coupe
Installed OEM SSK from a E60 545i. Loving it!! Also, upgraded all headlight bulbs from standard 4300k HIDs to 6000k... Looks amazing at night!
Daron666 is offline   Reply With Quote
Old 11-30-2012, 12:06 AM   #14164
sjacoby112
My Ride: 2002 325ci
how was the clip?
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 11-30-2012, 12:38 AM   #14165
e46ornothing
My Ride: 2005 BMW 325i
E60 545i ssk fits out cars? Can u give me more info please? How much etc
e46ornothing is offline   Reply With Quote
Old 11-30-2012, 01:39 AM   #14166
Mortification1
My Ride: 00 323ci or i?
I went with the z4 it's shorter than the e60.
Link:
http://forum.e46fanatics.com/showthr...4#post14939454
Mortification1 is offline   Reply With Quote
Old 11-30-2012, 02:11 AM   #14167
Hornung418
My Ride: '04 MB ZHP
Shorter isn't always better. Effort increases dramatically to shift a short lever.
Old 11-30-2012, 02:17 AM   #14168
darksideracer69
My Ride: 01 325ci
Are your headers in yet? And who cares? Shorter is always better.
Sent from my PC36100 using Bimmer App
IMAG02051
Old 11-30-2012, 03:04 AM   #14169
RKiepper
My Ride: 1999 E46 328I x2
Do they make a 'short shifter' for automatics?
RKiepper is offline   Reply With Quote
Old 11-30-2012, 04:05 AM   #14170
j_block
My Ride: 2003 325i
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 11-30-2012, 09:08 AM   #14171
Mortification1
Old 11-30-2012, 09:10 AM   #14172
WDE46
My Ride: '13 128i, '04 330Ci
Yeah, but you have to deposit $3000 into my Paypal account to get it.
Old 11-30-2012, 09:13 AM   #14173
xfixkaos
My Ride: 00' 328i
Originally Posted by WDE46 View Post
How long did the diff take you?
Did trans diff and engine fluids in under 45 mins give or take waiting or fluids to drain...
Make sure you can get the filler screw thing off first...would suck to drain it then not be able to fill...
xfixkaos is offline   Reply With Quote
Old 11-30-2012, 10:02 AM   #14174
RKiepper
Originally Posted by Mortification1 View Post
I should have worded that differently. Do they make a shorter shifter for autos.
I'd like something that is a bit more low profile since I put in a shift boot. Haven't had any luck looking.
Old 11-30-2012, 10:28 AM   #14175
wamcdonald
My Ride: 2002 330Ci
I upgraded my wheels to 19x8.5 and 19x9.5. The old 18x8 tires did not fit my new rims so I get new tires too . The only issue is with the rears rubbing a bit so it's parked until my fender roller shows up next week.
ID:	480207   Click image for larger version
ID:	480208   Click image for larger version
wamcdonald is offline   Reply With Quote
Old 11-30-2012, 10:51 AM   #14176
Hornung418
My Ride: '04 MB ZHP
Oil change. BMW 5W-30 @ $6.70/qt.
Shut your whore mouth! Headers won't be going in until I get my baseline update for the current set up. Then I get to spend a day cursing the BMW gods while I break every nut and bolt off the head and flanges...
Damn those are sweet! What model did they come off of?
Old 11-30-2012, 11:11 AM   #14177
LydMekk
My Ride: BMW 330CiA
Ordered 4 of these for my winter tires from ECS:
New pictures coming - this one is from 2009.
LydMekk is offline   Reply With Quote
Old 11-30-2012, 12:22 PM   #14178
ss_mikey101
My Ride: 04 325xi
had the following items replaced or added...
-power steering pump
-power steering hoses
-power steering flush
-radiator
-radiator hoses
-coolant expansion tank
-coolant expansion tank cap
-coolant expansion tank mounting plate
-auxiliary fan switch
-hub centering rings
-air filter
-micro filter
-liscense plate mount
-tightened the rear dif fluid cap (was leaking a bit)
-changed out my car lighter fuse
still waiting for my black kidney grills to come, in its been a while..
next up will be a debadge
ss_mikey101 is offline   Reply With Quote
Old 11-30-2012, 01:13 PM   #14179
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Blasted One Direction's new CD on my way to work.
This applies under the "what did you do to your E46".
Poor thing.
Schlag96 is offline   Reply With Quote
Old 11-30-2012, 01:40 PM   #14180
WDE46
Poor thing.
You may want to seek some professional help.
Rate This Thread
