Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 12-06-2012, 10:24 PM   #14321
limpiabota809
My Ride: 330 XI
^ I will definitely look into it thnx
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 12-06-2012, 10:43 PM   #14322
Johal E32
My Ride: BMW's
Bad alternator? Bad pulleys? Any ideas? This noise came out of nowhere earlier today..
Johal E32 is offline   Reply With Quote
Old 12-07-2012, 05:06 AM   #14323
HallisterJ1
My Ride: 2001 325i, 2003 M3
First time...
I recently bought a decent tool kit with mostly everything...Never tore anything from my engine apart before, or followed a DIY for car maintenance.
2001 325i
I cleaned my Idle Control Valve after 190k miles, it took two bottles of throttle body cleaner (CRC) and then it eventually started making the knocking back and forth noise, essentially moving freely again. It was disgusting and so grimed up I thought I had to buy a new ICV.
I took a look at my DISA, and did tests to see if it's going bad and it's still good, everything was tight and firm...even after 190k miles. I didn't bother cleaning it, it wasn't that bad at all.
My air boots were recently replaced brand new by an independent shop so they're in perfect condition nearly.
I will be doing an all around brake job tomorrow (Rotor-works Slotted/Drilled Rotors, Centric Brake Pads, Wear Sensor, Flush), and an Oil Change.
In the last 5k miles I've payed the independent shop to do the following:
1. NGK Spark Plugs
2. Spark Plug Boots
3. Valve Cover Gasket
4. Oil Filter Housing Gasket
5. Front Control Arms/Bushings (Lemforder)
6. Air Filter (OEM)
7. Pre Cat o2 Sensors (Friend tock172 helped me out)
8. Fuel Filter/Fuel Pump
9. Cooling System Overhaul (Hoses, Water Pump, Thermostat, Coolant Expansion Tank, Bleeder Screw, my radiator is already months new)
I'm hoping to do my rear differential bushing, engine mount and tranny mount next week. I hope the car will run near new, and yes it's an automatic.
Any thoughts?!
Last edited by HallisterJ1; 12-07-2012 at 05:21 AM. Reason: Forgot cooling system...
HallisterJ1 is offline   Reply With Quote
Old 12-07-2012, 06:22 AM   #14324
m3unit07
My Ride: 1999 328i
Decided to change out my shift boot...had a beige one before, kinda liking the two-tone thing I have going on in the interior...also put some decals on the whip
Next up: changing out the rear drivers and front passenger's window regulators, then figure out what the heck is going on with my locking cylinder
ID:	481247   Click image for larger version
ID:	481248   Click image for larger version
m3unit07 is offline   Reply With Quote
Old 12-07-2012, 01:42 PM   #14325
ryannel2003
My Ride: '04 Cadillac Deville
New c-pillar came in. Old one was broken from when I painted my rear deck last week. Also, my rear speakers were rattling and it turns out it was from the foam piece between the speaker and the speaker cover. Took it out and all is well.
ryannel2003 is offline   Reply With Quote
Old 12-07-2012, 08:02 PM   #14326
jakksfor20
My Ride: ZHP,Slow 323ci
Completed the OFHG and associated stuff that I posted yesterday. Took the subframe reinforcement off and cleaned it along with wiping down everything I could that was covered in oil.
jakksfor20 is offline   Reply With Quote
Old 12-07-2012, 08:18 PM   #14327
mightymouse777
My Ride: 01 325Ci
Got them in and new corners also. rotors and pads tomorrow!
Sent from my LG-P930 using Bimmer App
ID:	481301   Click image for larger version
mightymouse777 is offline   Reply With Quote
Old 12-07-2012, 08:30 PM   #14328
lakedude90
My Ride: 03' 325i
Got a pretty good size order in today.
upper & lower intake hoses
new DISA
power steering reservoir
power steering hose
Osram CBI bulbs
ZKW-r projector lenses
and just put in a order for some V2 halo rings umitza
got a pretty decent "work on the car day" coming up it would seem.
_____________
Jacob
03' 325i
lakedude90 is offline   Reply With Quote
Old 12-07-2012, 10:01 PM   #14329
BimmerFool1
My Ride: 02' BMW 325i 5MT
Had a tire blow out this morning at 4 AM down the freeway, spent the day replacing the tire. Finally up and running again, but now a new problem emerged right after.. The lock in the door broke and now I can't get into my E-46 :-( just my luck! Life sometimes throws me some screwballs
lol.
BimmerFool1 is offline   Reply With Quote
Old 12-07-2012, 11:18 PM   #14330
2003 325i
My Ride: '03 Orient Blue 325i
What I should've done 2 years ago. MACHINED MY ROTORS! Also serviced my brakes.
Holy crap I'm ticked I didn't do this before.
Pro-Cut on car lathes FTMFW.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 12-07-2012, 11:27 PM   #14331
cocolo9uno
My Ride: 2003 325xi
Nice lights! What brand?
cocolo9uno is offline   Reply With Quote
Old 12-07-2012, 11:30 PM   #14332
cocolo9uno
My Ride: 2003 325xi
Put on full Yakima roof rack system on the Xi. Also bought a Thule snowboard rack to put on it. Ready for snowboarding season!
Old 12-07-2012, 11:55 PM   #14333
Russian172
My Ride: e46 sedan e46 m3
OOOO how i wish if mine was a manual
Russian172 is offline   Reply With Quote
Old 12-08-2012, 12:37 AM   #14334
mightymouse777
My Ride: 01 325Ci
Umnitza. Well built also. I have no complaints
Old 12-08-2012, 01:01 AM   #14335
RKiepper
My Ride: 1999 E46 328I x2
Found out why my car shakes at 80-85mph with my 16" spare.
RKiepper is offline   Reply With Quote
Old 12-08-2012, 01:48 AM   #14336
TerraPhantm
My Ride: M3 & ZHP
Enabled shift lights (and sport mode memory, but you can't see that)
Old 12-08-2012, 02:49 AM   #14337
serdar255
My Ride: '01 325ci / '90 325i
Decided to spend some money on her I've been on a handling spree, what do you guys think front camber plates and a Carbon fiber sunroof insert, or front and rear camber plates, or sunroof insert and gopro3?
Not so sure of the last one.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 12-08-2012, 04:17 AM   #14338
j_block
My Ride: 2003 325i
Buy my camber kit that I have for sale
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 12-08-2012, 03:34 PM   #14339
cak323i
My Ride: ///M3 & 330i ZHP
Updated my projects thread...
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 12-08-2012, 04:17 PM   #14340
Zchild
My Ride: 2000 BMW 3XXi ZSP
I finally got around to clearing one of the last remaining set of codes after adding a M54B30 block, injectors and crankshaft to the mix. I had an E3 and E4 which are O2 sensors pre-cat cylinders 1-3 and 4-6. I pulled both old pre-cat sensors and they were scorched beyond recognition. I put in the new sensors cleared the codes and the car woke-up from it's come-like slumber... Only new front and rear bumpers to go and I'll be done for a minute, I think; 337,947 miles and rollin!
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Rate This Thread
