Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 12-18-2012, 08:29 PM   #14521
DavidDee
My Ride: 2004 325xi
Oil filter housing gasket and replaced the serpentine belt and AC belt. Was pretty easy, and was a good chance to clean up the engine a bit.
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 12-18-2012, 08:50 PM   #14522
Nico16
My Ride: 2000 323i
ID:	482656 still pretty clean right? Did my fuel filter i got 166k miles on my car
Nico16 is offline   Reply With Quote
Old 12-18-2012, 08:53 PM   #14523
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by Nico16 View Post
Attachment 482656 still pretty clean right? Did my fuel filter i got 166k miles on my car
You can't really tell by the color of the fuel dripping out. That fuel has left the sediments inside the filter. Cut it open and see how black it is. Of course we don't know the original color.
Has anyone even thought of that?
Old 12-18-2012, 10:21 PM   #14524
Nico16
My Ride: 2000 323i
Ill try cutting it open tomorrow, see if its black or what,
Old 12-19-2012, 01:16 AM   #14525
Nerdy46
My Ride: 328i
Search?
http://forum.e46fanatics.com/showthread.php?t=950552
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 12-19-2012, 07:11 AM   #14526
WDE46
Originally Posted by Nerdy46 View Post
Negative, Ghostrider. I mean, has anyone ever cut open a brand new fuel filter? What if the brand new filter element is black? That would mean these things aren't as dirty as they seem when we cut them open.
BTW, the pictures in that thread don't work anymore anyway.
Old 12-19-2012, 09:28 AM   #14527
CT Bimmer
My Ride: 09' e90 zmp 335i
Originally Posted by .DatBlackBM. View Post
--Pic with the 20mm on??? I was thinking of doing the same!!
here ya go, could probably fit a 25mm in there. tried 30 but that rubbed to much even with fender work... just realized your car is an M3 tho and sadly mine is not
ID:	482686   Click image for larger version
CT Bimmer is offline   Reply With Quote
Old 12-19-2012, 02:52 PM   #14528
Dionne11
My Ride: 2004 325i
Cleaned Air injection valve, cleaned spark plugs, checked my disa, cleaned ICV and found out my CCV was leaking oil. So next project is to put a new ccv on.
Dionne11 is offline   Reply With Quote
Old 12-19-2012, 07:34 PM   #14529
BBBoy323i
My Ride: 01' 325ci
Got the car detailed, but it's been rainy and poured on the way home oh well, at least they got rid of my bad water spots.
BBBoy323i is offline   Reply With Quote
Old 12-19-2012, 08:21 PM   #14530
Snik
Snik's Avatar
My Ride: IR M3 Vert.
AFe intake elbow and diff drain plugs came in. Woot woot for fluid changes.
Also ordered water pump, t stat, expansion tank and cap for this beast too.
Do you ride a sportbike?
Old 12-19-2012, 10:52 PM   #14531
hizhinezz
My Ride: 01 330i
Swapped entire cooling system except radiator without ever referring to DIY thread. Used tap water. It will all work great? Bet.
hizhinezz is offline   Reply With Quote
Old 12-19-2012, 11:42 PM   #14532
DavidDee
My Ride: 2004 325xi
Installed Bosch Icons. It rained a little today and I'm loving them so far!
Sent from my DROID X2 using Bimmer App
Old 12-20-2012, 12:05 AM   #14533
///MPR77
My Ride: 02 ///M3 Tri-Ped
Tap water?
That stuff is bad news, and you know this.
It's not some myth that was created here on e46f.
Certain regions tap water will have less minerals than others, but those minerals at higher concentrations are harmful to the aluminum, and plastics.
I lived in Phoenix AZ and the water there straight from the tap isn't suitable to use to brush your teeth.
Hope it all works out as you have planned.
Old 12-20-2012, 01:18 AM   #14534
Mr_325
My Ride: 2007 X5 3.0Si
replaced stock speakers with Polk Audios and added a Separate JVC amp to run them.
don't have pic's of the speakers as they were professionally installed
will upload a pic of the temp Amp install until i get a custom sub box made to mount it too.
Mr_325 is offline   Reply With Quote
Old 12-20-2012, 04:45 AM   #14535
xcar360
Past Site Sponsor
My Ride: BMW 318i
so hot
xcar360 is offline   Reply With Quote
Old 12-20-2012, 05:46 AM   #14536
trentcdrums
My Ride: BMW 323i Sedan
Cf strut. Ecs tuning. Attachment 482826
Old 12-20-2012, 08:21 AM   #14537
mightymouse777
My Ride: 01 325Ci
Was considering this also let me know what you think please!?
Sent from my LG-P930 using Bimmer App
mightymouse777 is offline   Reply With Quote
Old 12-20-2012, 05:21 PM   #14538
WDE46
Looked at it out the window at work all day. I WANNA DRIVE HOME
Old 12-20-2012, 05:29 PM   #14539
My Ride: Lexus
Someone works at a correctional facility!
Old 12-20-2012, 05:32 PM   #14540
WDE46
Lol no just a really massive assembly plant.
Rate This Thread
