Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 12-21-2012, 04:39 PM   #14561
My Ride: 2016 Lexus
those arms... ehh =/
Old 12-21-2012, 04:54 PM   #14562
777eThOd*
My Ride: spins too much
Yeah yeah lol, I didn't want to buy the UUC ones cause I liked the red ones more, and they work great and still lightweight. There pretty good tho..
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 12-21-2012, 05:08 PM   #14563
My Ride: 2016 Lexus
No I mean they weren't necessary to begin with. Stock arms allow for plenty of camber adjustment.
you'll probably say, "but, i'm stanced."
to which, i'd reply, ""
Old 12-21-2012, 05:18 PM   #14564
777eThOd*
Noooo lol, the stock ones would still rub with my fenders, I didn't exaggerate the camber, I only put what's necessary to where it won't rub lol. I'll camber it out for you one day lol.
2006 BMW M3 - SOLD
Old 12-21-2012, 05:27 PM   #14565
My Ride: 2016 Lexus
you are too low and using improper wheels.
and no, please don't.
Old 12-21-2012, 05:46 PM   #14566
tock172
My Ride: '12 135i DCT
Got my oil analysis back:
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT
Old 12-21-2012, 05:47 PM   #14567
777eThOd*
Lol. It looks good tho so I ain't trippin lol..
2006 BMW M3 - SOLD
Old 12-21-2012, 06:00 PM   #14568
Imola.ZHP
My Ride: Imola ZHP
Few weeks back with a new camera...
Yesterday...
Next week (Wednesday)...
Clutch assembly plus rear main seal
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 12-22-2012, 01:46 AM   #14569
Mr_325
My Ride: 2007 X5 3.0Si
Originally Posted by Mr_325 View Post
replaced stock speakers with Polk Audios and added a Separate JVC amp to run them.
don't have pic's of the speakers as they were professionally installed
will upload a pic of the temp Amp install until i get a custom sub box made to mount it too.
here's a pic of the JVC Amp
Mr_325 is offline   Reply With Quote
Old 12-22-2012, 12:09 PM   #14570
Miko_10
My Ride: 330i 5 Spd
Took a drive out to cars n coffee.
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 12-22-2012, 01:05 PM   #14571
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Cleaned MAF, and air filter, installed aFe intake elbow and RPI intake scoops.
Do you ride a sportbike?
Old 12-22-2012, 02:16 PM   #14572
Mr_325
fixed my EE LED tails
kept showing bulb out on left after my speaker install
ended up being the ground pulled loose in the harness
i took the ground wires out on both sides and connected them outside the harness
good to go
all wires for the tails are so thin and crappy, also the contacts they join to inside the harness are very short making it easy for them to come loose
i think i may delete the harness if i have any more problems in the future
Old 12-22-2012, 02:24 PM   #14573
WDE46
My Ride: '13 128i, '04 330Ci
Finally put my thermostat in. I had a disaster when bleeding the system though. I managed the snap the ET level indicator into 3 pieces (float and 2 sticks). I ended up having to remove the whole ET to get the pieces out. Duff city. Anyway, I was putting off my system overhaul until January, but I'm buying the parts Monday and installing them asap.
Old 12-22-2012, 04:06 PM   #14574
sledg77
My Ride: 2002 330ci
Finally set my clock to EST - LOL
sledg77 is offline   Reply With Quote
Old 12-22-2012, 05:05 PM   #14575
///MPR77
My Ride: 02 ///M3 Tri-Ped
Did that happen, by using a turkey baster when extracting excess coolant after the bleed?
Either way kinda good that it snapped, under your nose...if it was that brittle, then it possibly indicates the condition
of ET.
Sent from my SCH-R530M using Bimmer App
Old 12-22-2012, 07:28 PM   #14576
USAFJERMAINE
My Ride: 2001 e46 325ci
I replaced the head gasket, while upgraded the vanos seals. If you ever get the chance to take out the two vanos bolts prior to reading the directions, don't, as I snapped one of the two LEFT HAND bolts. Luckily my metals tech friends on base can fix the bolt. Life happens (smiley faces)
Sent from my PG86100 using Bimmer App
USAFJERMAINE is offline   Reply With Quote
Old 12-22-2012, 07:44 PM   #14577
JTripper
My Ride: 3dirtyci
I got my PA Soft 1.4.0 BMW scanner today, I'm catching my @ss to get it to work on W7 prem. 64!!
Also got the correct aftermarket wiring harness (after one prior attept the dude at the mobile A/V shop I went to gave me the wrong sh!t and connected it to a Pioneer AVH-P6600 dvd HU... probably'll slap it in in the morning.
*cost 24.50 free s/h!!* Happy like apiginshit about that though
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Old 12-22-2012, 08:02 PM   #14578
tock172
I emulate Windows XP SP3 in parallels on my Mac and I have not had one single issue with my PA Soft.
Old 12-22-2012, 08:53 PM   #14579
Mr.Makeveli
My Ride: 2001 325i(sedan)
Just reached 140k miles
Sent from my SPH-L710 using Bimmer App
Mr.Makeveli is offline   Reply With Quote
Old 12-22-2012, 08:55 PM   #14580
HyeWarrior
My Ride: '03 325i --> '13 GTI
You know what they say about 141K miles...
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Rate This Thread
