Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 12-29-2012, 11:35 PM   #14661
mightymouse777
My Ride: 01 325Ci
Not sure where to look so ill just ask... why is my door lock seem like it doesn't want to turn when its really cold out? Seems like it almost freezes up...
Sent from my LG-P930 using Bimmer App
mightymouse777 is offline   Reply With Quote
Old 12-29-2012, 11:54 PM   #14662
kby88
My Ride: E46 318i 2.0 5MT
Just received if from US. ZHP Weighted Short Gear Knob 5 speed and alcantara gaiter.
However the boot gaiter was for left hand drive =( .The shape of plastic frame different. Got to modify it a bit.
kby88 is offline   Reply With Quote
Old 12-30-2012, 12:02 AM   #14663
NFSx328ci
My Ride: TiAg E46
Nothing for my E46 this time but to my friend's E46. I installed some Angel Eyes for him. So perrrty
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 12-30-2012, 12:16 AM   #14664
NightRaider93
My Ride: 2007 Z4 Coupe
Originally Posted by WDE46 View Post
Yeah those soaps are cool just know that you shouldn't use those brushes on any car. It'll put more swirl marks in your paint than you want to know.
I finally changed my PS fluid reservoir and refilled/flushed with Dexron III ATF. Steering feels smoother.
Knew I shouldnt have used those brushes...
-Spencer
NightRaider93 is offline   Reply With Quote
Old 12-30-2012, 04:43 AM   #14665
bizrar
My Ride: 2001 bmw 330ci
Installed all the door/side panels and any trim. Then installed front passenger seat. Painted the inside of the headlight matte black and put them together. Started sanding down the kidney grills (huge pain in the butt!!). Reorganized cables in the trunk and installed bass boost knob in the center under arm rest area, where the coin holder flips up.
bizrar is offline   Reply With Quote
Old 12-30-2012, 01:47 PM   #14666
DO_NOT_USE
My Ride: 330i
Got some kid in older Tiburon to "modify" the back of my car...
Not a huge amount of damage, but I still feel pretty bitter about it, especially because guys gf kept saying home much more their car was damaged. Both of them completely failed to acknowledge the fact he did not adjust his driving style to road conditions (heavy snow/slippery road) not to mentioned he probably had some old ass all season tires on the car.
DO_NOT_USE is offline   Reply With Quote
Old 12-30-2012, 03:08 PM   #14667
moiz21
My Ride: 1999 323i 5-SPD
Changed the oil, was a bit overdue :-/. Was pretty windy today too.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 12-30-2012, 04:03 PM   #14668
WDE46
My Ride: '13 128i, '04 330Ci
That body panel under the tail light is expensive. Make them pay for completely new panels.
Ordered my cooling system components.
Does anyone know why the AT realoem page does not have any part that the ET drain plug screws into. MY transmission cooler connection is leaking so I am replacing everything down there, but I can't find the part that the plug screws into. With the MT ET mounting plate, it is built in.
Old 12-30-2012, 06:02 PM   #14669
RKiepper
My Ride: 1999 E46 328I x2
The exhaust is also bent. That'd piss me off even more.
RKiepper is offline   Reply With Quote
Old 12-30-2012, 07:23 PM   #14670
ryannel2003
My Ride: '04 Cadillac Deville
Big day for the 323. New struts/shocks, mounts, end links, tie rods and sway bar bushings installed today. Took me some friends most of the day but I know I could do it again quicker. Car rides much better. Didn't want to get too hard on it cause we forgot to tighten the top strut bolt all the way so the car makes awful racket. Oops. Gotta take care of that tomorrow morning.
ryannel2003 is offline   Reply With Quote
Old 12-30-2012, 07:27 PM   #14671
DO_NOT_USE
My Ride: 330i
I'm definitely going to insist on getting all parts needed replacement swapped with new; no way I'm letting them fix it on a cheap
Old 12-30-2012, 07:27 PM   #14672
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by ryannel2003 View Post
Big day for the 323. New struts/shocks, mounts, end links and sway bar bushings installed today. Took me some friends most of the day but I know I could do it again kick quicker. Car rides much better. Didn't want to get too hard on it cause we forgot to tighten the top strut bolt all the way so the car makes awful racket. Oops. Gotta take care of that tomorrow morning.
Do you mean you forgot to tighten the 22mm single nut on the strut?
Or
The 3, 14mm strut mount nuts?
Old 12-30-2012, 07:28 PM   #14673
ryannel2003
The 22mm one on the top of the strut itself.
Old 12-30-2012, 07:38 PM   #14674
///MPR77
How tight did you torque it, and did you do pull out the whole assembly, or just tightened it from the engine bay?
Old 12-30-2012, 07:56 PM   #14675
ryannel2003
We had tightened it before we put it back in the car but once I got down the road and heard the noises I knew that it wasn't enough because you could tell something is loose. If I had a 22mm at my house I would go out and do it now but the biggest socket I have here is a 17mm -_-. I also looked at the top of the strut itself and it's obvious the nut isn't down enough. Oh well, I'll get it taken care of tomorrow.
Old 12-30-2012, 08:19 PM   #14676
sweetbro858
Banned User
My Ride: BMW
How can you tell if you seated the expansion tank all the way down?
The coolant leaks a little bit when I unscrew the exp tank cap... Releasing the pressure somehow makes it leak somewhere? Thoughts?
sweetbro858 is offline   Reply With Quote
Old 12-30-2012, 09:39 PM   #14677
WDE46
It should click into place with an audible and tactile feedback.
Old 12-30-2012, 09:40 PM   #14678
E46Enthusiast20
My Ride: 2016 F80 M3 Sedan
powerwashed all the salt off.
E46Enthusiast20 is offline   Reply With Quote
Old 12-30-2012, 09:41 PM   #14679
///MPR77
Good luck to you!
Sent from my SCH-R530M using Bimmer App
Old 12-31-2012, 12:13 AM   #14680
JTripper
My Ride: 3dirtyci
Slapped this in! And my HU IS UP NEXT got it and all the parts except the iPod wire! Taking my time, no rush no fuss!
ID:	484073   Click image for larger version
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Rate This Thread
