Rating:
#14981 |
Grand Superpatriot
False. It's common in all internal combustion engines. Open the hood of any 90s/early 2000s Camry or Corolla and you'll see it. Our engines handle this internally and don't require a separate valve. The whole idea is emissions control
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#14982 |
That thing is called a projector FYI. And what do u care no one was throwing u a bone
#14983 |
I was referring to the E46. EGR is achieved by valve overlap in non diesel E46s.
![]() Last edited by ImolaSix; 01-14-2013 at 01:39 AM. |
#14984 |
Replaced control arm bushings, diff. fluid, tranny fluid, coolant flush, new water pump, new belts, picked up a mint sport wheel to replace the worn one that came with it, touched up the rims as best I could (balanced as well) and cleaned the CCV. Runs great (and looks pretty good) sitting in the garage
.A few months of winter left to keep cleaning up the interior. Seems to have been neglected over the first 10 years of its life. |
#14985 |
Got my mirror replaced from Radar-Mirror. Looks great and fantastic service!
#14986 |
Tires. VCG. Some random o ring in the cooling somewhere. Oil filter. Oil.
All in preparation for 2,200 miles in 6 days. God damn it.
#14987 |
#14988 |
Theoretically, does EGR reduce power since part of the mixture are theoretically inert combustion byproducts? Do you think tweaking the VANOS tables so that EGR doesn't happen would improve hp at all?
#14989 |
Changed a tire, plasti-dip grill, added water to battery since it wouldn't start in the cold, had a Canadian laugh at me since I said it was cold. Yes 34 degrees is cold in Phoenix. all before 9am and class.
Alpine white looks so much better with blacked out grills IMO, updates the car to a more modern look not to mention the only other chrome part I have is door handles. Definitely recommend to anyone looking to do plasti-dip, much cheaper than 50.00 grills from Khoalty, or ecs, or mod. Last edited by college46; 01-14-2013 at 01:08 PM. |
#14990 |
installed corner light that popped off.
#14991 | |
Weagle Weagle
One thing to note is that most engines don't EGR during high loads/RPM because it DOES actually hurt peak performance. So, when you floor it on our cars, I imagine that the valve overlap is significantly reduced. It makes sense to EGR in partial throttle situations as this would reduce the emissions the maximum amount and not affect driveability. Last edited by WDE46; 01-14-2013 at 02:07 PM. |
#14992 | ||
![]() Last edited by ImolaSix; 01-14-2013 at 03:12 PM. |
#14993 | |
Weagle Weagle
2. So the lack of EGR at high RPM for us is really just a lack of ability to accomplish that function using valve overlap? |
#14994 |
#14995 |
Changed spark plugs, very easy took all of about 45 mins start to finish. And by the looks of the old ones glad I changed them.
#14996 |
Weagle Weagle
That's what mine looked like. My new Bosch plugs had a TINY electrode. I guess that's normal, they run great. Those are NGK replacements?
#14997 |
Yep ngk's bma had them really cheap got them all for $36
![]() Last edited by honkifyoubonk; 01-14-2013 at 04:06 PM. |
#14998 |
Yes. It's really a case of best of both worlds. You wouldn't want residual exhaust gases in the combustion chamber if you're trying to extract maximum power out of the engine.
#14999 |
Adjusted the allen head on my driver's side door to try and make the door open easier. Now the door won't open from the outside.
#15000 |
Mod
Washed my car, tuned my new cb antenna and took some pics
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 Pics from post 505 on! ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
| Rate This Thread | |
