Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.00 average.
Old 01-15-2013, 06:44 PM   #15041
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Just ordered V1 Connection
Old 01-15-2013, 06:46 PM   #15042
trey30
My Ride: 2004 330ci
Picked up car from shop today.
I have a 2004 330ci. 135k miles. Originally took it in to have the flex disc replaced. I couldn't get the heat shield off to do it myself. Good thing too- it turned out to not be the flex disc at all. It was the rear drive shaft center mount/support.
Also, while my car was there I was informed that my front lower control arm bushings went bad. Which surprised the crap out of me because I had them replaced about two years ago - just before I upgraded to 20" rims - coincidence that they are now shot?? I think not. I attribute the fact that my replacement bushings went bad so quickly to the 20s.
Now something useful - I initially thought I needed a valve cover gasket and almost did it myself. However while in the shop they checked it out and turned out to be the actual valve cover plastic. There were cracks around the coil holes which were causing vacuum leaks and oil leaks. You can remove the whole thing and examine yours. Also, there are rubber gasket pieces that sit under the coil holes - they essentially rot or turn to a plastic-like material. If that occurs I recommend replacing the top. It's about a $230 part.
Next, putting in Scorpion exhaust and Warrior intake.
trey30 is offline   Reply With Quote
Old 01-15-2013, 09:13 PM   #15043
trentcdrums
My Ride: BMW 323i Sedan
Ordered my P46's. Spent an hour on the phone with ECS tuning over the second wrong part they sent me. They have horrible service and this is the last time I will order from them. Except for the $11 that they will not refund me and only give me store credit on.
Old 01-15-2013, 09:30 PM   #15044
college46
My Ride: Alpine White
The problem is that it is only 11 dollars. Seems common on Angel eyes, leds, grilles. I feel your pain but if you look at it from their end, they will always put the smaller orders on the backburner, especially customer service wise. It is the same thing with khoalty (at least ecs has a phone number). Doesn't make it right, but that seems to be peoples experiences. My .02
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 01-15-2013, 09:39 PM   #15045
trentcdrums
Well the $11 dollars is what they owed me from the old part, I paid $102 for the camshaft sensor and they said that I needed another (which was cheaper) hence the wrong part. Stupid sales reps don't take their time. I'd rather do it right than rush.. You feel? They wouldn't refund me the $11 so they just store credited it. Those sensors get so pricey.
Old 01-15-2013, 09:44 PM   #15046
mikeetastic
My Ride: 323i 99
today!
BEFORE:
AFTER:
from here: http://forum.e46fanatics.com/showthr...7#post15064857
mikeetastic is offline   Reply With Quote
Old 01-15-2013, 09:46 PM   #15047
college46
Ecstuning has gone downhill, last good thing I got was a CAI for a jetta mk5(in terms of the order, delivery time, communication) 3 years ago just saying .
I misinterpreted your post. sorry. But that refund policy is terrible but refund policy is something that all stores have the power to set unfortunately. Thats the risk you take when you order from Ecstuning and now everyone on the forum knows that. So thank you.
Old 01-15-2013, 09:58 PM   #15048
trentcdrums
+1, glad you understand.
Old 01-15-2013, 10:12 PM   #15049
ruskisky
My Ride: slower than yours
Got rid of my square fuglies for oem m3 side swag mirrawse!!!
ruskisky is offline   Reply With Quote
Old 01-16-2013, 01:33 AM   #15050
tuscan1205
My Ride: 325CI
Replaced my starter and it was a major pita. Hopefully this fixes my problem. Thanks newtuner for your awesome DIY writeup.
http://forum.e46fanatics.com/showthread.php?t=732743
tuscan1205 is online now   Reply With Quote
Old 01-16-2013, 01:33 AM   #15051
tuscan1205
My Ride: 325CI
good ole iPhone double post.
Old 01-16-2013, 08:44 AM   #15052
RickyZone
My Ride: 2003 330ci M-Sport
Ordered a pair of these from my BMW Dealership, OEM of course:
My old ones were quite yellow/matte.
Next up: New DSC-wheel sensors, unless the old ones are just dirty. Need to troubleshoot as soon as the snow's gone!
RickyZone is offline   Reply With Quote
Old 01-16-2013, 09:03 AM   #15053
moiz21
My Ride: 1999 323i 5-SPD
Ordered a pair of Bosch Icons to replace my OEM windshield wipers.
Bought a pair of 323/328 headers of a fellow member.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 01-16-2013, 10:29 AM   #15054
honkifyoubonk
My Ride: E 6666
New much needed lenses
honkifyoubonk is offline   Reply With Quote
Old 01-16-2013, 10:59 AM   #15055
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
^ Where'd you get the lenses? Just curious because it has a lot of writing on the corner.
Old 01-16-2013, 11:18 AM   #15056
Platinum Plus Quality
My Ride: M54B30
Those new lenses look twice as blurry/stained as my "old" lenses. you sure those are new, OP??
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 01-16-2013, 11:26 AM   #15057
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
+1 they look used.
Old 01-16-2013, 11:41 AM   #15058
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
Hit em with an orbital buffer and some cutting compound, then a finishing polish. Then seal them with some synthetic sealant. They'll look better than new.
Old 01-16-2013, 12:09 PM   #15059
My Ride: M54B30
But he said they're new. Oh well
Old 01-16-2013, 12:37 PM   #15060
Rudy540
My Ride: E46
You can't even tell they, look new to me
Rudy540 is offline   Reply With Quote
Rate This Thread
