Rating:
#15421 | |
#15422 |
So I woke up a coolant light this morning. Opened up the tank and saw it empty. Refilled it up but then noticed this. I just had the expansion tank replaced this summer. Should I be worried? I did notice a slight leak nothing crazy regardless taking it to the shop tomorrow
![]() -JZ7- Last edited by JZambrano7; 01-28-2013 at 02:01 PM. |
#15423 | |
#15424 | |
Weagle Weagle
Wait I'm a moron. That is the OEM hose, but you need a new one. That's gonna fail soon. Don't have the dealer do this. They'll charge you $200 for a 20 minute job and a $30 part. Last edited by WDE46; 01-28-2013 at 02:14 PM. |
#15425 | |
![]() -JZ7- |
#15426 | |
Do not drive with the hose cracked like that. You can get one from the dealership or from NAPA. NAPA one will cost you around $30, dealership will cost you around $50. That was last year around this time. I know because I cracked the same hose when I hammered the fanclutch nut and the wrench hit the hose. Got one from dealership and one from NAPA to compare. I used the one from the dealership just to be safe and returned the NAPA one. But both looked the same except for the BMW marking.
#15427 |
The leak is minimal but I won't be moving the car until tomorrow. Don't want to risk it too much. I just hope it holds up on the way to the mechanic
![]() -JZ7- |
#15428 |
#15429 | |
Weagle Weagle
Just watch the temp needle the whole way. If it so much as thinks about moving, pull over. The $100 tow will be worth it. You don't want to buy a hose AND a headgasket replacement. Last edited by WDE46; 01-28-2013 at 02:42 PM. |
#15430 |
It's a $30 fix and takes about 30 minutes including clean up, testing and the first beer. Why pay someone to do such a simple task?
#15431 | |
Get a radiator hose from NAPA or dealership(a good idea to get a gal of coolant) and ask your mechanic to drive to you when he is free. It will take max 30 mins to replace including toping(or bleeding) coolant. Give him an hours worth of labor. Just 0.2 cents. You will spend more if you overheat or even if you have to tow your car there. You may get away with duct tape and coolant top up before you drive to your mechanic, but it will need a proper bleed anyway as air has been introduced to the system. When I cracked that hose, I was in a friend's shop trying to DIY. I left the car there for a night and asked his employee to replace the hose later next day. I didnt even start it after I cracked it.
#15432 |
Please take off the eyelids and red angel eyes.
![]() -2003 M3 Vert -1967 Mini Cooper |
#15433 |
Weagle Weagle
#15434 | |||
![]() -JZ7- |
#15435 |
Yah, he was so keen on driving the car with cracked hose that I thought a full cent wasnt worth it.
#15436 | |
If air is present in a sealed system your temp needle will go whacko and may over heat the engine. Why risk it? Get a radiator hose and DIY or ask a mechanic or some fellow member near you to help you out. Pay him the amount you were going to pay for the tow.
#15437 |
Weagle Weagle
#15438 |
Platinum Plus Quality
Just ordered the last BMW structural foam in stock for the subframe reinforcement from Mike @ bmwpartstore. All I need now is seam sealer, mega's injection gun, a drill bit, and some nerves of steel as I undergo this intimidating project. Fairly simple but I don't want to waste $200 worth of foam :/
BMW part# 83190445721 I also hope no cracks had developed from the last time i "checked" the subframe area until now (couple months??)
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#15439 | |
Sent from my SCH-R530M using Bimmer App |
#15440 | |
| Rate This Thread | |
