Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-06-2013, 03:13 PM   #15661
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by Kvasi View Post
New oil and filter. 300 dollars well spent.
Whoa! Wah?
New oil and filter. 225 dollars too much.
Fixed.
Old 02-06-2013, 03:19 PM   #15662
My Ride: Lexus
Received:
Expires 3/22/13
Old 02-06-2013, 03:19 PM   #15663
tock172
My Ride: '12 135i Dinan S2
Originally Posted by ///MPR77 View Post
Yeah I'm definitely enjoying these, despite the fact that I am running them with Bilstein Tourings, which are not valved for these, but I just hadn't been able to justify buying the Koni adjustabales when these struts only had 10k miles on them.
Honestly, I haven't hit the bump stops once, while driving in the canyons, and the car feels planted and stable.
At the very worst these struts will blow out early, and then I will replace with Konis
I have got the strut replacement DIY down to an hour a side, I know its not super quick, but its really become an easy job for me, so I figured I would slap them in there, and see what happens.
I must say this set up doesn't feel as incorrect, as it is supposed to be...
a bit bumpy at low speed on bad graded roads, I will say.
I do expect them to be shot in another 30k based on theory, and then on to the "proper" setup.
Interesting. Well the ultimate test is a combination of how it feels to you and how long it lasts. I wouldn't at all be surprised if the struts last longer than you'd expect. Bilstein design and manufacturing are both top notch. Either way I'm glad they're working for you! Strut replacement definitely isn't too difficult but it will still are me longer than you. I'll be curious to know how the Koni dampers feel in the future.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 02-06-2013, 03:28 PM   #15664
///MPR77
Indeed, at least they don't feel sketchy even if they do blow out sooner. I know the Konis will be much better, and better for the long haul.
If you are correct, and they do end up lasting longer, I will probably just replace them by April, regardless.
Old 02-06-2013, 03:30 PM   #15665
///MPR77
Received:
Expires 3/22/13
Nice let's do it! Only a bit over a month left... is right.
Old 02-06-2013, 03:31 PM   #15666
My Ride: Lexus
yes sir. i'll gve you a call. asking megalognous for his gun/dispenser then i'm still waiting for seam sealer. also need a stepped drill bit and some tubing for the seam sealer.
Old 02-06-2013, 03:39 PM   #15667
Kvasi
My Ride: 320D touring
Originally Posted by j_block View Post
$300 for oil and filter?
Sent from my SPH-D700 using Bimmer App
Actually 1550.- NKR = Norwegian kroner. But yeah, exhanged to dollars its aprox 300.
Kvasi is offline   Reply With Quote
Old 02-06-2013, 03:44 PM   #15668
limpiabota809
My Ride: 330 XI
This and coolant temp sensor on the upper rad hose that was giving me the SES light
Edit: Thanks Jake!!!
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 02-06-2013, 04:59 PM   #15669
Blueandwhite85
My Ride: E46
Ouch.
Blueandwhite85 is offline   Reply With Quote
Old 02-06-2013, 08:07 PM   #15670
tock172
Replaced my AUC sensor with a used unit from eBay. Probably a mistake. We'll find out in a few hours after I do some driving and scan it.
Old 02-06-2013, 09:15 PM   #15671
trentcdrums
My Ride: BMW 323i Sedan
Hid fogs. Attachment 489682
Old 02-06-2013, 09:17 PM   #15672
ryannel2003
My Ride: '04 Cadillac Deville
Getting to the rear wheel bearing was a bust. Didn't have the proper sized socket to get the nut off the hub so I gave up on that. I did however replace my steering guibo , install my new passenger side splash guard and fix the strut which wasn't mounted all the way in the nuckle. Car will have new tires installed Friday and I'm getting an alignment at BMW saturday morning.
ryannel2003 is offline   Reply With Quote
Old 02-06-2013, 09:33 PM   #15673
///MPR77
Lol. Finally got that bugger into the knuckle.
Old 02-06-2013, 09:36 PM   #15674
ryannel2003
Haha I know right! Car finally sits level and it looks great. Question, can I get an alignment on Saturday and replace the wheel bearing Sunday and it not mess the alignment up? I'm pretty sure I can but I want to make 100% sure before giving BMW $150 to align the car.
Old 02-06-2013, 10:22 PM   #15675
trentcdrums
Old 02-06-2013, 10:23 PM   #15676
trentcdrums
Attachment 489697 ^^
Old 02-06-2013, 10:38 PM   #15677
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Got my baby new Trans with only 30k miles on it! And its a zf trany out of a 330 not a getrag out of a 325.
325CiMaN is offline   Reply With Quote
Old 02-06-2013, 11:15 PM   #15678
My Ride: Lexus
I hope you service the pins before reinstalling. refresh the shifter linkage too
Old 02-06-2013, 11:25 PM   #15679
325CiMaN
What pins? And ya I'm using my uuc short shifter off my current blown Trans, which is a getrag and I also got new bushings
Old 02-06-2013, 11:27 PM   #15680
My Ride: Lexus
you might wanna look into it:
http://forums.bimmerforums.com/forum....php?t=1196171
Rate This Thread
