Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-08-2013, 09:05 PM   #15741
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Left my baby at home while I took the beater out to work in the snow.
Old 02-08-2013, 09:26 PM   #15742
caleb6
My Ride: 2005 330XI
Why? Your sig shows it all salted up.
caleb6 is offline   Reply With Quote
Old 02-08-2013, 11:28 PM   #15743
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Finally done the tans swap! ZF shift gates are way different then the getrag they are way closer on the ZF keep miss shifting 2nd to 3rd and hitting 5th
325CiMaN is offline   Reply With Quote
Old 02-08-2013, 11:31 PM   #15744
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by 325CiMaN View Post
Finally done the tans swap! ZF **** gates ate way different then the getrag they are way closer on the ZF keep miss shifting 2nd to 3rd and hitting 5th
I think I know what you said there, but perhaps a translation will help clarify.
Old 02-08-2013, 11:33 PM   #15745
325CiMaN
Oops fixed!
Old 02-09-2013, 12:19 AM   #15746
325CiMaN
Me and buddy went for a cruise after the Trans swap, and all its good Trans shifts smooth no issue.
Thanks to Mango for the 5th/reverse fix link!
ID:	489984   Click image for larger version
Old 02-09-2013, 01:13 AM   #15747
My Ride: Lexus
My battery died this morning. Had to push-start. 2-year old Autozone 49-DL. Autozone deemed it bad and replaced it with a 94R. $200 inc. tax less a $78 pro-rated credit later and I now have juice again. My only concern is that the battery has TWO vent holes. I did some digging and it turns out i need an L-connector to connect to the vent hose. I need to buy a 3-pack at Autozone. right now the vents are not connected. hope it doesn't do any damage. I understand I have to plug the hole at the negative terminal and vent the positive one using the L-connector? If so how do I plug the 2nd vent hole?? the battery didnt come with ANY tubes, connectors, or anything. i saved the one off the old 49DL but it doesn't seem to fit
Old 02-09-2013, 01:17 AM   #15748
My Ride: Lexus
Oh I forgot to mention, Autozone does NOT offer the 49DL anymore. The only available one is $200 inc. tax!!
Old 02-09-2013, 03:30 AM   #15749
The Thomas J
My Ride: 2002 325Cic
Parked it until the road conditions improve.
The Thomas J is offline   Reply With Quote
Old 02-09-2013, 03:42 AM   #15750
TerraPhantm
My Ride: M3 & ZHP
I have a hard time believing autozone would stop carrying 49-DLs. A lot of cars use group 49 batteries.
Old 02-09-2013, 04:41 AM   #15751
Alpine
My Ride: 2002 E46 BMW 330Ci
I reset my electronic adaptive throttle! Ignition ON (without starting engine) for 10 seconds, switch to OFF for 10 seconds, then start engine. Car feels more responsive now!
Alpine is offline   Reply With Quote
Old 02-09-2013, 08:52 AM   #15752
TT330i
My Ride: 2003 330i
Digging... it's under there somewhere
TT330i is offline   Reply With Quote
Old 02-09-2013, 09:09 AM   #15753
zhenkaaaM3
My Ride: Fst'r then your e46
Pushed through the snow and got out
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 02-09-2013, 09:23 AM   #15754
Solidjake
Zero. Leaks.
Solidjake's Avatar
With the amount of snow we go, no thanks.
Old 02-09-2013, 09:38 AM   #15755
limpiabota809
My Ride: 330 XI
Took her out and got to work, glad I got an XI
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 02-09-2013, 10:47 AM   #15756
Vertical_Flight
My Ride: '03 330i 6-spd ZHP
Installed:
WeatherTech digital fit front and rears
MY own design custom condenser/radiator protective aluminum mesh grill (mounts on the 4 studs on the frame in front of condenser) - Don't want to have to ever to replace the condenser again
New A/C condenser and receiver/drier (The old one had a tiny pinhole, presumably from a rock, and would spurt PAG oil all over the car once I got up to speed if the system was pressurized)
New radiator
New thermostat
New cooling hoses
New expansion tank
Switched to Zerex coolant, bled system
Performed oil change, switched from Castrol to Royal Purple 5W-30 - WOW what a difference!!
Switched to a magnetic oil drain plug
Removed:
Ugly-@ss black PlastiDip from wheels, back to sexy stock silver wheels
@Mango, thank you for your cooling plethora of information, it helped point out a few little nuances that I wouldn't have noticed!!
Projects for next week:
Getting a Dynavin on Monday, be playing with installing that
Gonna try to find a good place to stealth-mount my V1, got a concealed display coming in that I want to integrate into my mirror - Like this, but these guys are farking retarded if they think I'm gonna pay $600+ for something I can do myself! LOL!
Anyone attempted this yet, or found a good place to stuff their V1? While everything's out I'll be hard-wiring the detector to the car, and pre-wiring for a Laser Interceptor kit that I'm planning on getting once I get my tax refund
2003 330i ZHP - 152K and loving it.
Last edited by Vertical_Flight; 02-09-2013 at 01:15 PM. Reason: Auto-save 1360433703
Vertical_Flight is offline   Reply With Quote
Old 02-09-2013, 11:05 AM   #15757
caleb6
My Ride: 2005 330XI
Have a diy for the a/c work you did?
Sent from my Galaxy 10.1 Tablet on bimmer app.
RIP Bach: 11/4/2003 - 3/9/2013
Old 02-09-2013, 11:10 AM   #15758
Blueandwhite85
My Ride: E46
Boy am I glad I live in Texas after seeing some of those snow pictures. You guys are troopers for sure!
Blueandwhite85 is offline   Reply With Quote
Old 02-09-2013, 11:32 AM   #15759
TT330i
My Ride: 2003 330i
You guys in NY got lucky this time around, anybody have a shovel?
Old 02-09-2013, 11:36 AM   #15760
Keez2MyBimmer
My Ride: 330xi
Garaged it and took the 4wd to play some ball
Keez2MyBimmer is offline   Reply With Quote
Rate This Thread
