Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-13-2013, 09:17 PM   #15921
kpeng
Banned User
My Ride: E46 330 and E30 325
I looked at it.
kpeng is offline   Reply With Quote
Old 02-13-2013, 09:29 PM   #15922
jonel1225
My Ride: 02 325ci
Originally Posted by kpeng View Post
I looked at it.
Did it look nice?
Untitled
jonel1225 is offline   Reply With Quote
Old 02-13-2013, 10:01 PM   #15923
McDeshen
My Ride: '99 323i
Originally Posted by I_LOVE_MY_330Ci View Post
Looks good now lower that bad boy!
Thanks! I plan on lowering it soon when I get some money $$
McDeshen is offline   Reply With Quote
Old 02-13-2013, 10:13 PM   #15924
kpeng
Banned User
It looked VERY nice
Old 02-13-2013, 10:26 PM   #15925
Chaplian
My Ride: M56 SULEV
I installed the diy aux cable and then watched the passenger side window regulator break. Time to learn how to replace the window regulator!
Chaplian is offline   Reply With Quote
Old 02-13-2013, 11:07 PM   #15926
Zatarain
My Ride: 2000 323Ci
Lemfoerder CAB's shipped today.
Zatarain is offline   Reply With Quote
Old 02-13-2013, 11:24 PM   #15927
RKiepper
My Ride: 1999 E46 328I x2
Installed led trunk lights, ran a wire to the rear fog socket that didn't have a connection, fixed my intermittent front turn signal bulb, and cleaned the MAF.
RKiepper is offline   Reply With Quote
Old 02-14-2013, 07:19 AM   #15928
Sammy325xi
My Ride: 05 325xi Dark Green
LED license plate bulbs, cffl angel eyes, led interior lights, control arm bushings driver side and passenger.
Sammy325xi is offline   Reply With Quote
Old 02-14-2013, 09:54 AM   #15929
My Ride: Lexus
Originally Posted by TerraPhantm View Post
I wouldn't worry about replacing the ballasts unless yours specifically shows some issues. I know there are a lot of other people running these bulbs on E46s without any issues. I've had some bad luck with the E46 ballasts, so I got frustrated and chucked them (buying a brand new one would've been more expensive anyway). Actually I'm sure my passenger side one was still good - so I'll put that up for sale one of these days. I'll probably throw in the "bad" one for free since it might still be fine for "regular" bulbs.
Yeah I used the E39 (facelift) ballast brackets on the passenger side (and on a non-M you could probably use them on the driver side as well)-- they are a little more expensive than they should be. If you can find them on eBay or some classifieds for cheap, get them there. They're just pieces steel shaped/cut appropriately.
There's a small 3-pin cable connecting to your existing ballast along with the 9006 connector. The center pin is +12V. No one seems to know what the two outer pins are for -- and late model cars (2004+ or so) don't even have those outer pins. The ground comes from the 9006 connector. Then internal to the ballast there's some fancy circuitry. Basically the E46 bixenon shutter has 2 solenoids - "strong" and "weak." The weak one can hold the shutter open, but cannot open it by itself. The strong one does the opening -- it obviously can hold it open, but it consumes a lot of power (I've heard as much as 30W) -- that would way too much to sustain for long periods.
So basically what happens is that when you flick on your highbeams, the weak solenoid is immediately energized via the the +12v and ground (which are essentially directly connected). The ballast senses the the slight current increase through the ground, and it quickly energizes the strong solenoid for a split second. This is enough to keep the solenoids open until you cut power. If you use a non-E46 ballast, you need a circuit to emulate that functionality. The Wolstentech circuit is compact and cheap, so it makes sense.
As far as wiring it up goes... Since I've got my car coded to fire up the halogen highbeams anyway, what I'm going to do is just use a 9005 splitter, keep one end in the high beam bulb, and the other end going to the wolstentech adapter (which will ultimately end up going to the shutter itself). Alternatively you could get a couple wiretaps, tap into the center (or only) wire of the 3-pin plug for the positive, and then tap into any ground for the negative. Main reason to do this would be if you wanted to use the US-style high beams for some reason or if you have DRLs enabled.
Oh and the reason I used the E39 bulb gasket/cover is because the ballasts are external. The wire is rather thick, so it'd be just about impossible to put the stock cap on with an external ballast (or specifically, an external igniter). The E39 gaskets are sized about right and designed for a near identical setup (even the bulb holder is similar). So That seemed ideal. You do have to stretch it *slightly* for it to fit over the hole, but I think that's true of the E39 as well.
Also -- even though I went with brand new Hella Gen 3s, that probably isn't strictly necessary. Every report I've read indicates that they are ridiculously reliable ballasts, and are able to ignite bulbs that are far past their intended lifespans. A used one would probably be fine. The Philips LVQ-212 is the same ballast with a sticker.
Thanks for all that info. I'll try my luck with CBIs and my existing ballasts. My driver's side ballast was swapped with one from a 2005 M3 that had 200 miles on it when totalled(flipped over end on end @ 90 mph--no injuries!) I swapped it over cause the plastic clips on the red D2S plug broke.
So it's sort of a fresh start for my headlight system...
Old 02-14-2013, 10:54 AM   #15930
RKiepper
What good does a brand new cooling system do if you hit a pole at night because you cannot see?! Rofl!!
Old 02-14-2013, 10:56 AM   #15931
My Ride: Lexus
Met up with Megalocnous last night to borrow his gun. time to get this subframe reinforcement thing on the road. need to go to hardware store to look for a stepped drill bit (necessary to be stepped?) and some tubing for the seam sealer
Old 02-14-2013, 10:56 AM   #15932
My Ride: Lexus
oh believe me, i can see
Old 02-14-2013, 11:04 AM   #15933
kpeng
Banned User
Mangolingus.
Old 02-14-2013, 11:10 AM   #15934
///MPR77
My Ride: 02 ///M3 Tri-Ped
That expiration date is creeping up.
Old 02-14-2013, 11:18 AM   #15935
My Ride: Lexus
i'm gonna try to do it tomorrow morning. will you be around?
Old 02-14-2013, 11:24 AM   #15936
///MPR77
I am teaching 3 classes tomorrow (12hrs) but I may be able to get out of the first one, and If so, I will be free from 8a-11ish.
How early would you like to start?
Sent from my SCH-R530M using Bimmer App
Old 02-14-2013, 11:27 AM   #15937
My Ride: Lexus
hmm i'm not sure yet. i have to see if i can get a hold of all the materials/tools and my other friend to help me. if so around that time might be good. i can't imagine the whole thing taking more than an hour. i have to jack up the car get under it and tape the hole that might take the longest as i'm paranoid getting under a lifted car.
i'll text you. text me so i know i have your correct #. i've been through a few phones since haha
Old 02-14-2013, 11:33 AM   #15938
///MPR77
Me too...I think we both ended up on the SGSIII....did you root it/ROM or you going to keep it stock as fawk? Lol!
Old 02-14-2013, 11:35 AM   #15939
My Ride: Lexus
Yup rooted and rommed out i love my current rom. working perfectly. Infamous S3
yours?
Old 02-14-2013, 11:36 AM   #15940
college46
My Ride: Alpine White
yours?
Cyanogen mod all day long...
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Rate This Thread
