Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 02-14-2013, 12:38 PM   #15941
My Ride: 2016 Lexus
Originally Posted by college46 View Post
Cyanogen mod all day long...
i've never tried but heard its good. i'm using tmobile and my particular problem is 1 out of 20 roms render my wifi calling/MMS over wifi useless. for some reason nobody is able to figure out why. so i'm scared to touch my phone as my Wifi calling/MMS is working brilliantly. i feel even if i reset my phone it might trigger something to disable my wifi calling feature (i get bad reception where i live so i need the wifi calling for all texts/mms/calls to go through.) its an awesome feature!
Old 02-14-2013, 12:50 PM   #15942
college46
My Ride: Alpine White
Had it since Sgs1. Used to be very unstable and thats exactly what would happen, i belonged to like three android forums and non of the devs could figure out how to get mms to work over wifi. That was the only issue I've ever had with cyanogen mod, but that was fixed on the s2, and now with the s3 its super stable not one issue, and no bloatware and overclocking is worth it. Plus I've had panorama photos since my sgs 1 Iphone users! one of many advantages rooting and roms are worth it. I also prefer to use wifi over regular 3g/4g because even though I have unlimited data, its faster and saves battery. 4g is worthless.
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 02-14-2013, 01:02 PM   #15943
rudycoop
My Ride: 3 pedal 330i
I am on jelly bomb on my s3 lte. I really like it.
rudycoop is offline   Reply With Quote
Old 02-14-2013, 01:09 PM   #15944
///MPR77
My Ride: 02 ///M3 Tri-Ped
+1 CM10 here.
Most AKOP ROMs are built off Cyanogen Mod framework, from what I have read.
Uh oh, thread derailment is near.
Old 02-14-2013, 01:24 PM   #15945
trj
My Ride: 325Ci
Originally Posted by ///MPR77 View Post
+1 CM10 here.
+1 Thread derailment is very near.
I think I just derailed the Iphone 5, sg3 or note 2 thread.
In the context of this thread:
I was messing around with bmw scanner settings and got an airbag light on passenger side. lol.
Back to fixing it.
Old 02-14-2013, 04:03 PM   #15946
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Ugh, there's some metallic rattle coming from the center of my car. Idk if I hit some ice or something to mess up the exhaust or something
Old 02-14-2013, 04:04 PM   #15947
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
heat shield mehbeh?
VALMONT is offline   Reply With Quote
Old 02-14-2013, 04:06 PM   #15948
My Ride: 2016 Lexus
Jake is that the same rattle from a few months back?
I went to hardware store to buy all the supplies for my subframe job. unfortunately no stepped drill bit... we'll see how the one i bought works out
Old 02-14-2013, 04:08 PM   #15949
WDE46
My Ride: 2004 330Ci OBM
Order one from McMaster Carr. They ship fast.
Old 02-14-2013, 04:09 PM   #15950
Solidjake
Zero. Leaks.
Solidjake's Avatar
Originally Posted by VALMONT View Post
heat shield mehbeh?
Possible, I might go out now and jack up the side of the car and see what's up.
No different.
Old 02-14-2013, 04:10 PM   #15951
My Ride: 2016 Lexus
I'll be doing this tonight or possibly tomorrow morning. any idea why BMW would specify a stepped drill bit? as long as the hole is made right? 10mm hole
Old 02-14-2013, 04:12 PM   #15952
VALMONT
The De46vil's Army
VALMONT's Avatar
because stepped bits are AWESOME, i have many. and when they get through you don't risk jamming a spinning 4" drill bit where it shouldn't be.
Old 02-14-2013, 04:19 PM   #15953
My Ride: 2016 Lexus
Do you think I will be ok with the 3/8 drill bit i got? (I think that's the size, i have to go check)
Old 02-14-2013, 04:20 PM   #15954
VALMONT
The De46vil's Army
VALMONT's Avatar
stepped bit are made to widen existing holes evenly, standard bits are not.
Old 02-14-2013, 04:21 PM   #15955
My Ride: 2016 Lexus
True but its very thin sheet metal I'm going through? I'll stop by home depot if you don't think the regular bit won't do it. just let me know.
Old 02-14-2013, 04:24 PM   #15956
WDE46
If it is a new hole, you could get away with just using a bit suitable for steel (it won't be fun, be warned). It won't be as clean as a stepped bit, but it'll work. You'll probably want to get a narrow file so any plugs you put in will sit flush. If you are widening an existing hold, I would use a stepped bit. A regular bit will just get caught on the edges and I seriously doubt you have a drill that will be able to turn the bit once it has seized.
The fact that it's thin sheet makes it harder for a standard bit actually. The bit will cut into an edge, bend it up into the spiral and will not shear the metal.
Old 02-14-2013, 04:36 PM   #15957
My Ride: 2016 Lexus
I'll look for a stepped bit
Old 02-14-2013, 04:40 PM   #15958
WDE46
Figured you would since you are always about doing it right. The stepped bit will make this go flawlessly. Best of all you can just use a standard battery powered drill with it.
Old 02-14-2013, 05:07 PM   #15959
My Ride: 2016 Lexus
I wonder if home depot sells it? Do they come in sizes like 10mm? TIS specifies a "10mm stepped drill bit" wondering exactly what to look for?
Old 02-14-2013, 05:16 PM   #15960
college46
gas. 3.39 at costco.
Rate This Thread
