Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 02-19-2013, 01:47 AM   #16161
trj
My Ride: 325Ci
Originally Posted by ///MPR77 View Post
How, or rather in what pattern did you torque the studs?
Did it many times already because of broken studs, leak at the VANOS and what not, I had to redo the VCG.
Torqued in a star pattern from middle bolt passenger side with torque wrench.
I am waiting to another VCG till the weather gets a little warmer.
This time its going to be OE or Goetz.
Old 02-19-2013, 01:47 AM   #16162
Dahlyla
My Ride: 03 325xi Premium Pac
What's the link for the 3m tape nice mod
Sent from my Note 2
Dahlyla is offline   Reply With Quote
Old 02-19-2013, 02:20 AM   #16163
RKiepper
My Ride: 1999 E46 328I x2
Apparently my old track tires are soo worn that they throw sparks... Time for new track tires.
RKiepper is offline   Reply With Quote
Old 02-19-2013, 04:52 AM   #16164
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
Deep clean of the interior. Looks brand new now. Exterior needs a lot of work
Originally Posted by VaderDave View Post
I'm having a hard time imagining any set of responses that ends with anyone expressing admiration for Marshmallow.
Perhaps you should stop responding. It's a no-win for you here. :dunno:
Five_seveN is offline   Reply With Quote
Old 02-19-2013, 06:35 AM   #16165
GSherbs
My Ride: 2002 330 xi
I highly recommend GENUINE BMW ONLY on VCG. It's not that much from the dealer. I had 3 VRs go out in a row. Now using BMW and dry as a bone on the desert floor in the middle of summer!!!!
i'll be sure to chime in if i run into problems.... i did get a quote from the dealer for the vcg - was more than 3x what i paid for non-genuine... still not what i would consider expensive but comparatively so, yes...
there have been enough success stories with non-genuine on these boards that i felt ok going that route (other than with the reinz gasket)... we'll see how it works out... if non-genuine fails early, genuine won't seem like such a bad deal then...
i was kind of surprised not to see any sign of rtv in the prescribed locations once i got the cover off... anyone else notice that? this was first vcg job on this car
GSherbs is offline   Reply With Quote
Old 02-19-2013, 07:40 AM   #16166
WDE46
My Ride: '13 128i, '04 330Ci
What did I do for my car? Nothing, but my car did save me on the interstate this morning from a hydroplane...
Old 02-19-2013, 09:18 AM   #16167
NightRaider93
My Ride: 2007 Z4 Coupe
Originally Posted by trentcdrums View Post
How soon did the problem come back after they fixed it? If it was under a year, they should warrant what they did.
It was around a month later.
-Spencer
NightRaider93 is offline   Reply With Quote
Old 02-19-2013, 10:05 AM   #16168
JZambrano7
My Ride: 2003 325xi
So I found a puddle of coolant under my car this morning, dashboard lit up and low and behold my tank is empty. Filled her up again and i seem to be losing coolant at a fair amount of time. I just changed the expansion tank and upper hose about a month ago. What should I be expecting?
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 02-19-2013, 10:06 AM   #16169
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Won't know till you get under and look.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-19-2013, 10:07 AM   #16170
WDE46
Could be any number of things. That's why many people just replace everything at once. You could have blown up another ET if you overfilled it though.
Old 02-19-2013, 10:33 AM   #16171
My Ride: Lexus
getbmwparts.com
Old 02-19-2013, 01:53 PM   #16172
serdar255
My Ride: '01 325ci / '90 325i
Header install stuff came, oe header gaskets, oe cat back gaskets, oe studs, oe nuts.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-19-2013, 01:55 PM   #16173
Solidjake
Zero. Leaks.
Solidjake's Avatar
I just had to laugh at that
Old 02-19-2013, 02:09 PM   #16174
Andrew99328i
My Ride: 328i 99
today i decided to stop reading this forum so much spending money on upgrades and things that my car really doesnt need because its burning a hole in my pocket decomissioning my car and creating stress(fun) for unnecessary reasons. which is why we should all just be oem whores.
Andrew99328i is offline   Reply With Quote
Old 02-19-2013, 02:19 PM   #16175
My Ride: Lexus
Siemens/VDO crank sensor is only $66 on sale @ BMA.. so tempted..
Old 02-19-2013, 02:29 PM   #16176
serdar255
You saying you dont like genuine german nuts?
hahah
Old 02-19-2013, 03:32 PM   #16177
///MPR77
My Ride: 02 ///M3 Tri-Ped
Did you replace your cap?
Can you see coolant collecting on the top seams of the ET? or is it strictly from the bottom?
Fan switch, or lower radiator hose will leak on the left side of the car.
Right side can be many things, and either way, you will need to pull the splash shield off, and inspect while engine is cold.
I replaced my cooling system 12k miles ago, (all but hard pipe, and I forgot a new ET cap)
Below is an example of my bad cap vs. new cap on the left:
Notice the lip is sheared, so it won't seal properly.
Old 02-19-2013, 03:37 PM   #16178
My Ride: Lexus
Attachment 491406
Also the O-rings have a tendency to flatten out on a bad cap. they're $12 and good to replace. i remember car and driver's test of a brand new E46 back in 2001 had to visit the dealer due to a bad cap (when new!) so it can happen even when new.
Old 02-19-2013, 03:38 PM   #16179
My Ride: Lexus
be careful! serdar is 16.. we need you at Bimmerfest, not in jail!
ugh i keep double posting. bad habit. i wish it automerged like on bf.c
Old 02-19-2013, 03:42 PM   #16180
///MPR77
Yep, the bad one on the right O ring had flattened completely, and looked like a black dry rotted rubber band. I attempted to seal it temporarily with a random O ring, that I had in the trunk; just to get me to Bavarian Auto.
Rate This Thread
