Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-25-2013, 09:32 AM   #16341
My Ride: Lexus
Originally Posted by fgump View Post
I replaced CCV and all hoses in January 2012. My oil consumption has not diminished (between 800-1000 miles b/w additions of German Castrol 5W-40). OFHG replaced at same time, as was VCG. Old-style dipstick tube was cleaned at replacement in 2012, but was not clogged.
Saturday I disassembled it all, and found lots of oil in the upper tube going back to the intake. Found less oil in tube going down to dipstick. Found evidence of water in cyclone. Disassembled diaphragm and it all looked intact (it was a BMW-branded, non-cold weather version). Found a URO parts version on Autohoss's site (misspelled intentionally) for $29, and a matching URO hose to the intake.
Also observed small leak at Vanos banjo near oil pressure switch, so purchased new vanos line and crush washers.
Will replace when it arrives, but I'm frankly at a loss as to where all this oil is going. Pulled undertray and it's dirty, but did not see leaks enough to add up to 1 quart in that few miles (about 20 days).
I'm sad to say I'm getting good at removing all the crap to get to the CCV.
I would advise against aftermarket CCV stuff. It doesn't fit together nicely as OE does. OE is well worth the extra $50 or so. Especially the upper pipe that connects to the valve cover.. that HAS to be OE. no exceptions or it will not fit correctly
Old 02-25-2013, 09:49 AM   #16342
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Originally Posted by serdar255 View Post
Originally Posted by Schlag96 View Post
Yeah removing the seats takes 5 minutes. I did it twice when I was troubleshooting the driver side tensioner. Super easy.
How did you fix the tensioner i have the same problem???
I replaced the tensioner with a new one. And the wiring harness as well. And it didn't fix it. The light's still on and code still there. I have yet to trace the wire, but that's the only part left so...
Schlag96 is offline   Reply With Quote
Old 02-25-2013, 10:09 AM   #16343
E46Enthusiast20
My Ride: 2016 F80 M3 Sedan
Originally Posted by Snik View Post
How did u do that?
PA soft is your best friend.
E46Enthusiast20 is offline   Reply With Quote
Old 02-25-2013, 10:11 AM   #16344
JZambrano7
My Ride: 2003 325xi
Originally Posted by E46Enthusiast20 View Post
They blink twice quickly instead of once.
I went to my local shop and they said e46's couldn't be coded for euro hazards. How'd you do it?
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 02-25-2013, 10:18 AM   #16345
Miko_10
My Ride: 330i 5 Spd
took a drive out with the wife and scarred her driving on some of the local twisties...I need to clean my car, hurry up already spring weather.
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 02-25-2013, 12:16 PM   #16346
RKiepper
My Ride: 1999 E46 328I x2
Pinched the **** out of my finger putting in the new dip stick...
Little bastard is a tight fit.
RKiepper is offline   Reply With Quote
Old 02-25-2013, 12:19 PM   #16347
My Ride: Lexus
you sure you didn't jam your finger in the dipstick hole?
Old 02-25-2013, 12:24 PM   #16348
Leprocket
My Ride: 2003 BMW 325I
At CHP office. Vehicle is getting an out of state inspection. Hopefully I will be able to get the plates today.
Leprocket is offline   Reply With Quote
Old 02-25-2013, 12:55 PM   #16349
RKiepper
:ROFL:
The o-ring on my old one was shot... The new one stopped at the neck, took a bit more force then I thought it needed and finally popped in, with my thumb in between the metal rim and the cap.
Wouldn't stop bleeding for an hour.
Old 02-25-2013, 01:08 PM   #16350
My Ride: Lexus
:ROFL:
i replaced the o-rings on the dipstick as PM. surprisingly my old ones weren't bad. they cost pennies so just replaced them anyway
Old 02-25-2013, 03:52 PM   #16351
serdar255
My Ride: '01 325ci / '90 325i
link to the specific one? there are so many sites
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-25-2013, 04:09 PM   #16352
Leprocket
I can finally drive this thing. Got the tags today.
Old 02-25-2013, 04:10 PM   #16353
Leprocket
Got the tags today, I can finally drive this vehicle.
Old 02-25-2013, 04:16 PM   #16354
satx e46
My Ride: non-M E46
dropped it
1/4in front and 1/2in rear
'02 325Ci (currently sitting @ 174hp-dyno tested)
Current changes:
Angel eyes, smoked front corners, rear smoked led lamps, trunk lip, rear visor spoiler, blacked out headlamps, more coming soon.
Current mod:
19 CSL reps, Evo Technix Coil-overs, muffler deleted, injen cold air filter.....
My Build Thread
satx e46 is offline   Reply With Quote
Old 02-25-2013, 04:50 PM   #16355
E46Moonlight
My Ride: 2000 323i
Witnessed a pigeon dumping on my car, I proceeded to throw my McDonald French fries at the b!tch! Fcuking NYC Pigeons!
E46Moonlight is offline   Reply With Quote
Old 02-25-2013, 05:07 PM   #16356
RKiepper
This seems counter productive...
What did you do when the other 400 pigeons flew in for the fries and crapped everywhere...?!
Old 02-25-2013, 05:30 PM   #16357
HiHoBrian
My Ride: 05 M3
^ Made a post about it.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 02-25-2013, 05:50 PM   #16358
E46Moonlight
My Ride: 2000 323i
Lolz, yea I was long gone by then!!
Yep.
Old 02-25-2013, 05:59 PM   #16359
E46Enthusiast20
It was under one of the menus.
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
Old 02-25-2013, 07:21 PM   #16360
jdny516
My Ride: Oxford Green M5
Ordered:
Koni yellows
Rear shock mounts with reinforcement plates
Eisenmann exhaust
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Rate This Thread
