Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 03-24-2013, 02:17 PM   #17321
Guest021715
Account closed.
Originally Posted by RKiepper View Post
I have CCFL, no issues. :hater:
Yea, but you keep an extra E46 in your stable just in case.
Old 03-24-2013, 02:20 PM   #17322
trey30
My Ride: 2004 330ci
"You very likely ruined your car. Just cause you have "cold air" doesn't mean you properly fixed it. You might want to get it professionally serviced so you don't blow your $1,500 compressor. Professionally servicing your system also ensures the proper lubricant is added (proper amount as well)"
Whats Mango. Wow, ruined the entire car?! I had a tech check it out before i added the refrigerant. The compressor is solid. The system i used was equipped with lube however, the one gray area yet is whether or not the level is sufficient. That's the one thing i do need to have checked. Thanks for the advise.
trey30 is offline   Reply With Quote
Old 03-24-2013, 02:24 PM   #17323
My Ride: Lexus
That's not quite how that works. Why would you have a tech "check" your ac only to go to the store, buy a can of DIY refrigerant and DIY?
What exactly did you have him "check"? A proper A/C service includes complete evacuation of the system under vacuum (that alone takes 30 minutes) and a proper charge to volume spec on both high/low sides as well.
By simply "adding" freon, you simply don't know what you just did.
Old 03-24-2013, 02:47 PM   #17324
THECLEANERBEAMER
My Ride: 2002 325i
On the way to washing my car this beautiful tiag m3 drives on opposite lane and I quickly turned around and followed it for a while that was the first time that I've seen oem 19's in person and there so sexy
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 03-24-2013, 03:26 PM   #17325
billyons
My Ride: 2001 325i 5-Speed
I replaced both trunk shocks and the windshield wiper motor cover.
Next week; the oil filter housing gasket, motor mounts, and clutch.
2001 BMW 325i, 5-Speed, Sport & Premium Packages
2001 Mercedes Benz C320
1960 Ford Ranchero
For high quality synthetic oil products: http://www.amsoil.com Dealer# 5042781
billyons is offline   Reply With Quote
Old 03-24-2013, 04:23 PM   #17326
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Originally Posted by illestminimike View Post
And if he doesn't get an alignment soon with the steering wheel off a little bit, he will get codes for the steering angle position sensor which will cause the DSC, Brake and ABS light to come on. So get that taken care of ASAP!
Originally Posted by Mango View Post
yeah i think he knows
I got ot exactly in the right spot so I don't need it.
J/K I'll go see Bjorn sometime this week. I have sway bar end links coming as we speak.
Schlag96 is offline   Reply With Quote
Old 03-24-2013, 04:40 PM   #17327
trey30
My Ride: 2004 330ci
Mango, he checked that there were no leaks and that the compressor wasnt shot. The "check" was just that a check. With 137k miles and it being an 04, im not paying techs for much these days. Only paying for major engine items that I cannot perform. You're sounding like a BMW or Firestone tech right about now. It is a simple DIY. Why not take advantage of that?
Old 03-24-2013, 05:24 PM   #17328
wildirish317
My Ride: 2004 325Ci vert
Let her rest today. Weather is crappy, rain turning to snow tonight. Spent the day building a workbench and some shelves in the garage.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-24-2013, 05:32 PM   #17329
My Ride: Lexus
It's not a simple DIY. Your ability to go to an auto parts store and screw on a fitting and pull a trigger does not mean you did the job right. This has been discussed several times before and it is consensus to never DIY when it comes to A/C unless you have the proper training and/or equipment. The alternative is to take it to a qualified shop w/ the right equipment. You can also land yourself in jail or prison if you vent refrigerant into the air. Some barnyard guys will chime in and say "But I've done this before it's no problem" but that doesn't make it right.
I'm all for DIY, but the A/C is one system I don't d*ck around with. Same w/ alignment and tire balancing. Everything else nobody touches my car. Nobody
Old 03-24-2013, 05:34 PM   #17330
My Ride: Lexus
Awesome. Make sure you sit in the driver's seat and hold the steering wheel perfectly straight as the alignment is performed.
Old 03-24-2013, 07:08 PM   #17331
dancmos
My Ride: BMW 323i
Driver's side front window regulator installed successfully! No airbag warnings. Victory!!!
dancmos is offline   Reply With Quote
Old 03-24-2013, 08:05 PM   #17332
trentcdrums
My Ride: BMW 323i Sedan
This deserves to be seen. A mate on Instagram plasti dipped his e46 he bought for $100.. This is it weeks later. Amazing. Attachment 496987
Old 03-24-2013, 08:38 PM   #17333
THECLEANERBEAMER
My Ride: 2002 325i
He bought it for $100?
Old 03-24-2013, 08:59 PM   #17334
Chaplian
My Ride: M56 SULEV
Changed the oil, then had the tires balanced. Now to clean out the ICV/or get a new one if my damn red oil light flicker doesn't go away. After that, gonna try to locate the leak for my windshield washer fluid. Replaced the pump on top already. Anybody know if it could leak from the connector thing in the bottom that is horizontal? Haven't really had a chance to look at it, and if it does need replacing, is it a pump like the one that is vertical?
Chaplian is offline   Reply With Quote
Old 03-24-2013, 09:18 PM   #17335
JZambrano7
My Ride: 2003 325xi
Anyone wanna pshop my wheels gold, put on ambers and warm AE's for me? Please
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 03-24-2013, 09:50 PM   #17336
E46Snowball
My Ride: 330i
I inspected my engine bay and found my oil filter housing gasket to be leaking after one year. Went to BMA to pick up a new gasket. Tomorrow putting it in.Fun.
Victor Reinz gasket huh....?
I have a Victor OFHG, and throttle body gasket laying around...after reading about their reputation wondering if I should just toss them, and go oe.
2003 330i
Imola Red
Zhp Package
6 speed
E46Snowball is offline   Reply With Quote
Old 03-24-2013, 09:52 PM   #17337
E46Moonlight
My Ride: 2000 323i
give me like 15 mins ill do it
E46Moonlight is offline   Reply With Quote
Old 03-24-2013, 10:05 PM   #17338
RKiepper
My Ride: 1999 E46 328I x2
Could be the grommet/seal the pump seats into.
RKiepper is offline   Reply With Quote
Old 03-24-2013, 10:35 PM   #17339
trj
My Ride: 325Ci
This is complete ****ing BS. It's March for Christ sakes!!!!
I feel your pain man. We got dumped with a feet of snow yesterday and I had washed, waxed and detailed the car on Thursday.
Went to brush off the snow just now so it will be easier for tomorrow morning's drive. Might just head to car wash before going to work and have a spray at it.
Old 03-24-2013, 10:36 PM   #17340
trj
My Ride: 325Ci
Rate This Thread
