Rating:
#1741 |
it sat in the shop and i drove my moms 2011 camaro hahah. My CSL bumper is at the UPS dock, just have to go pick it up on monday!!
///M
#1742 |
Replaced split power steering hose, replaced resevoir cap, and sparks plugs.
#1743 |
put on coilovers and Valentine V1/RadarActive setup on my ///M3
![]() coilover review: http://forum.e46fanatics.com/showthread.php?t=821214 V1/RadarActive install: http://forum.e46fanatics.com/showthread.php?t=821336
![]() 2004 TiAg ///M3 2003 Imola Red 330i ZHP 1999 Electric Red 323i - SOLD Last edited by cak323i; 02-05-2011 at 08:36 PM. |
#1744 |
I finished installing a uuc stage I ltw flywheel with e36 m3 pressure plate and e34 m5 clutch this week. It is really great so far!
I also installed uuc adjustable rear control arms (time for an alignment) and transmission mounts. Everything seems to be working really well so far, but my engine mounts and guibo are going to need to be replaced really soon. Upon visual inspection of both they are pretty much done.
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II - - RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI - - M3 Motor Mounts - For Sale |
#1745 |
today i changed the fluid in my rear differential, also replaced my passenger side output seal
#1746 |
Removed chrome plastic around the headlights, removed the leather steering wheel cover . . . and found out I need new ignition coils, new front window regulators, and a new a/c resistor
#1747 |
holy 22 pages.
won't read responses to this. but I installed an OEM first aid box today!
#1748 | |
did you order it or get it from hendrick?
#1749 |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
Bought new xenon headlights and had to wash it in 25* weather after my garage sprung a leak and sprayed crap all over it
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#1750 |
My Ride: Touring, and others
Mine started throwing the 1421 and 1423 codes for low air flow to 02 sensors. I checked, and the Secondary air pump was not running. Jump wired the motor, and it ran just fine. Ordered a new Salmon color Relay, and changed it this morning. All is fine once more.
[/SIGPIC]I'm fluent in 3 languages:
English Sarcasm Profanity |
#1751 |
Mod
delmarco
![]() damn right
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#1752 |
Drove her everywhere, might get her washed later if I have time before the Super Bowl.
![]() ** '07 Armada LE l '00 GS300 l '93 Talon TSi l ^would u? ** |
#1753 |
Washed her. Shes so fresh now.
#1754 |
Replaced front brake pads.The easiest DIY ever.
#1755 |
installed custom fit all weather mats from Bavauto, much better fit then the cheap universal mats the PO had
#1756 |
Took off the oil filter housing today. That gasket was beyond gone.. I'm taking the housing to school with me tomorrow to clean it up in the engine parts cleaning room. Then I'll put the new gasket on and reinstall when I get home.
#1757 |
Changed oil and filter. Went from Amsoil to Mobil1. I'll see how it holds up. I used Royal Purple before and I didn't like how dark it was after 6k miles, Amsoil held up alright after about the same miles, but don't feel too comfortable with it. Since I have to mail order my oil and can only get it USPS, I can't find a place to order Castrol.
r e d d e m o n
#1758 |
Had the dings on the front passenger, rear driver, and driver's doors p.d.r.'d. The car is dentless as of today.
#1759 | |
Are you sure you installed right on the right and left on the left. It looks like they are the other way around... There is a marking on the rotors to say left or right... |
#1760 |
My Ride: 05 M3 Coupe,89 325iX
Today I did my ZHP a favor and left it in the garage, and took our Explorer out into the ice and snow.
| Rate This Thread | |
