Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 04-16-2013, 02:58 PM   #18021
tcphoto
My Ride: E92 335 MT Coupe
Originally Posted by WDE46 View Post
Your cats are fine if it's only the precat O2 sensors giving an error. You probably just have a vacuum leak. CCV hoses maybe.
I will definitely check the CCV hoses. I have been getting 18.6MPG in town and I just installed the new O2 pre cat sensors, reset the MPG gauge and ran a quick errand. The gauge now reads 25.8 but I'm sure that it will lower a bit in a couple of days.
tcphoto is offline   Reply With Quote
Old 04-16-2013, 03:11 PM   #18022
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Is that MPH or MPG in the pic?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 04-16-2013, 03:33 PM   #18023
tcphoto
It is MPG. Although, the MPH is similar since I live in downtown Atlanta.
Old 04-16-2013, 03:38 PM   #18024
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Originally Posted by Mango View Post
Looks great! way better. It looked like your car was into mud wrestling before. Now that's how a B2 Stealth Bomber pilot's car should look!
Operational Security
Schlag96 is offline   Reply With Quote
Old 04-16-2013, 04:02 PM   #18025
Adionik
My Ride: Bavarian Panzer
Gathering courage and patience to do the CCV
Adionik is offline   Reply With Quote
Old 04-16-2013, 04:13 PM   #18026
Blueandwhite85
My Ride: E46
Using the zoom and enhance option on my Eturbotronic46 keyboard I was able to determine that it is MPG.
Blueandwhite85 is offline   Reply With Quote
Old 04-16-2013, 05:10 PM   #18027
Schlag96
Schlag96's Avatar
My Ride: 1999 323i
Soon you will be ready, grasshopper.
Old 04-16-2013, 05:19 PM   #18028
My Ride: Lexus
hey why are you posting my picture?
Old 04-16-2013, 05:57 PM   #18029
vbfronkis
My Ride: 2001 325iT
Been a busy day in total:
1. Replaced the hood latch so that the handle properly retracts into the grille
2. Replaced the parking brake boot
3. Replaced the shift boot
4. Properly cleaned my summer wheels. If anyone thinks that spray-n-wash **** works, you're delirious. Elbow grease, bitches.
5. Went ballistic on my interior. If it wasn't carpet, it got scrubbed with this purple-y Lysol scrubs. What. A. World. Of. Difference. Even shoved the wipes into the crevices with q-tips.
6. Decided to shadow line wrap my window trim.
Tomorrow I'll wash and wax. Today it was drizzle-y.
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 04-16-2013, 07:09 PM   #18030
auto180sx
My Ride: '02 Steel Blue 330Ci
Finally got the car registered in the state I've been living in for the past year and a half. (Tags from my former state finally expired.)
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 04-16-2013, 07:23 PM   #18031
tcphoto
After watching a couple videos on CCV's I don't know if I would attempt it. Good luck!
Old 04-16-2013, 07:28 PM   #18032
E46Moonlight
My Ride: 2000 323i
I did mine last year, took me like 4 hours from opening the hood and closing the hood. But I did also change my dip stick guide tube at the same time. Wasn't too bad just need to be patient
E46Moonlight is offline   Reply With Quote
Old 04-16-2013, 07:37 PM   #18033
Blueandwhite85
My Ride: E46
LED that hoe up!
Old 04-16-2013, 09:18 PM   #18034
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Order new wheels and shoes to replace the OE 16s; Should arrive by Friday. 17x7.5 Drag DR37 - Hyper Black, 225/45-17 Pirelli Cinturato P7 All Season Plus.
Going to use the 16s for winter tires.
HacksawMark is offline   Reply With Quote
Old 04-16-2013, 09:33 PM   #18035
Russian172
My Ride: e46 sedan e46 m3
More cooling things
Mango was right again
so got a new water pump and return pipe from the heater core in to the ET also fully flushed out the system again( 1 week old fluid) and refilled with BMW blueLOL
so the only thing in my cooling thats original is the lower hose so it should be Ok for now will need to focus on control arms since mine are from "master pro" and failed with in a year if not less(small loose feel) also will have to do the Trailing arm bushings that have been sitting in the trunk for weeks
Russian172 is offline   Reply With Quote
Old 04-16-2013, 10:17 PM   #18036
trentcdrums
My Ride: BMW 323i Sedan
Got knocked with quarter sized hail for a mile on my way home :/
Old 04-16-2013, 10:18 PM   #18037
Russian172
it hailed ? today ? in Chicago land ? srs ?
Old 04-16-2013, 11:04 PM   #18038
Adionik
That doesn't seem too bad. I don't think I'll be taking out the IM so it's gonna be a tight install for sure.
Old 04-16-2013, 11:40 PM   #18039
E46Moonlight
My Ride: 2000 323i
Yea, I didn't take the IM either but you can wiggle it into place with no problem. Just gotta have patients especially if your installing the insulated version
Old 04-17-2013, 08:25 AM   #18040
trentcdrums
Down in Central IL. Open country land. Rain all week..
Rate This Thread
