Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 05-02-2013, 12:19 PM   #18621
Buck Henry
My Ride: 2009 Corvette Coupe
Bent rim replaced; what a difference!
When I had my left rear wheel bearing replaced by my Indy, I found out that the left rear wheel was bent and needed to be repaired / replaced. I went to Metro Wheels in Marietta, GA tidayt to inquire about repair and they owner happen to have a ready to go Style 68 rear wheel sitting on his shelf. He swaped me wheels for just a few bucks more than the repair would have cost and saved me from having to wait several days for the repair turnaround.
30 minutes later I was back on the road and the difference is nothing short of amazing! I cannot believe how much that bent rim was affecting the entire ride and feel of the car. With the wa-wa sound and the bent rim shimmy's all gone, I am just pleased as punch today!
Buck Henry is offline   Reply With Quote
Old 05-02-2013, 02:16 PM   #18622
RKiepper
My Ride: 1999 E46 328I x2
Got some wax on her. I can see my reflection again!
RKiepper is offline   Reply With Quote
Old 05-02-2013, 02:52 PM   #18623
My Ride: Lexus
Picture speaks for itself. Rebuild time. (Crush washer in hand but not pictured)
Old 05-02-2013, 03:03 PM   #18624
Riverbmr3
My Ride: MB E350 & BMW 325i
Originally Posted by Mango View Post
bad idea. that will cause it to hang and fail. eventually eats up the rollers on the regulator when it puts tension on the cable. trust me
Which regulators are you installing? and how often are they failing
if it goes bad, ill replace it again, i replaced it every two years anyway..
Riverbmr3 is offline   Reply With Quote
Old 05-02-2013, 03:06 PM   #18625
Riverbmr3
Just had her changed oil and replaced oil level sensor . My car needs TLC every week.
Old 05-02-2013, 04:29 PM   #18626
Russian172
My Ride: e46 sedan e46 m3
Finally tackled the taillights ground problem super easy and found the PO's ghetto rig (stripped wire that's bolted)
Russian172 is offline   Reply With Quote
Old 05-02-2013, 04:36 PM   #18627
RKiepper
Washed/waxed it as previously mentioned...
Then it got covered in pollen...
Wiped the pollen off...
And it started raining.
WTF!!!!
Old 05-02-2013, 04:38 PM   #18628
Russian172
Nvm
Old 05-02-2013, 04:42 PM   #18629
ClaytonL
My Ride: 2003 325i
Why are you rebuilding the chain tensioners? Are you having problems?
ClaytonL is offline   Reply With Quote
Old 05-02-2013, 04:48 PM   #18630
ZeeZoo
My Ride: '99 323i
* What did you do to/for your E46 today? *
WTF!!!!
You speak on behalf of a lot of other guys who wash their cars every week haha.
ZeeZoo is offline   Reply With Quote
Old 05-02-2013, 04:52 PM   #18631
WDE46
My Ride: '13 128i, '04 330Ci
Are you exhibiting symptoms? No way I would touch the chain or the tensioners if it isn't showing signs or wear. Do you have to redo the timing if you do this? If not, have at it. If so, damn that's gonna be a bitch.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-02-2013, 05:04 PM   #18632
My Ride: Lexus
no symptoms. just PM. Nothing needs to be done except unbolting the thing. easy in easy out. the old spring will be about 1/4" shorter due to age/wear. A chain that flops around tends to exhibit excess wear at the joints making it stretch, apparently. so i figured i'd do this for a few bucks.
Old 05-02-2013, 05:13 PM   #18633
ClaytonL
My Ride: 2003 325i
are you changing out the tensioner piston and cylinder also? or just the spring?
Old 05-02-2013, 05:14 PM   #18634
My Ride: Lexus
just the spring.
Old 05-02-2013, 05:19 PM   #18635
ClaytonL
My Ride: 2003 325i
just the spring.
cool. ive have wondered why the older a BMW gets, the louder it gets. I wonder if this is why?
you can now stop with teaching me new things to replace on my car!
Ill get this ordered and replaced on mine.
Old 05-02-2013, 05:24 PM   #18636
My Ride: Lexus
Possibly. Everyone that's replaced it reported the new spring to be considerably taller than the old one.
Oh I have a long long list of things not even in my threads. lol
Old 05-02-2013, 05:36 PM   #18637
Ivan77cb
My Ride: Bmw 323i 00 sedan
Originally Posted by Solidjake View Post
Put together my Thule fairing last night. Just waiting for an afternoon to install it.
Looking good man
Ivan77cb is offline   Reply With Quote
Old 05-02-2013, 05:39 PM   #18638
j_block
My Ride: 2003 325i
Re: * What did you do to/for your E46 today? *
Bought some white style 5s with tires from ebay. I can't wait to get them
j_block is offline   Reply With Quote
Old 05-02-2013, 06:12 PM   #18639
lszlszx
My Ride: 1.8T, XC70
Replaced thermostat - again.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-02-2013, 06:13 PM   #18640
My Ride: Lexus
leaks, codes, or temps?
Rate This Thread
