Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 05-08-2013, 12:48 AM   #18841
bmdubalicious
My Ride: 03 325i
Found out that I need a new trunk handle bar because one of the light plate light holders decided to bend and drop he bulb and the lense. Causing a stupid electrical issue as well though lol.
BMWCCA Member #461128
2003 Jet Black 325i ZPP, ZCW
Mods: P46's with Orion V2's | Cosmos Racing Cold Air Intake | UUC Underdrive Pullies | H&R/Koni | Staggered Style 119's | Clear Corners/Sidemarkers/Tails | Bimmerbrakes Stoptech Slotted Brake Upgrade | BimmerBrakes Headers | Magnaflow Catback Exhaust
Soon to Come: Shark Injector
bmdubalicious is offline   Reply With Quote
Old 05-08-2013, 05:53 AM   #18842
ClaytonL
My Ride: 2003 325i
* What did you do to/for your E46 today? *
just finished up my major suspension refresh. well, mine and my friend's 330i. one after another.
did struts, shocks, tie rods, M3 rtabs with Vorshlag's limiters, all-around mounts (OEM), sway bar bushings and links(OEM).
replaced everything I touched and took off from bump stops, to strut cover, down to every last washer and bolt I took off. he went with koni yellows and I went with Bilsteins.
finished at 3am. boy am I beat and does my back hurt. I'd recommend others to do this in sections per day.
the rtab tool worked AMAZING! I took more time unscrewing bolts to get the rtab carrier down. the limiters were sure a tight fit. hopefully I will only see positives out of this.
alignment on Thursday with weights. can't wait for the final product.
Feels great to have ALL and EVERYTHING on the suspension replaced and back to BMW's specs.
ClaytonL is offline   Reply With Quote
Old 05-08-2013, 09:31 AM   #18843
My Ride: Lexus
Awesome! You're about halfway there though (in terms of numbers of suspension parts). Even I haven't done the whole suspension.
The whole rear axle needs to be dropped down to finish the suspension. 15 more pieces to go in the rear.
Old 05-08-2013, 09:58 AM   #18844
Imola.ZHP
My Ride: Imola ZHP
^ Mango, have you (or someone else) done a similar photo and numbering system for the front suspension components?
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 05-08-2013, 10:05 AM   #18845
My Ride: Lexus
I could, I guess. but there's not much to the front. I'll get started on that i guess
Old 05-08-2013, 10:47 AM   #18846
JZambrano7
My Ride: 2003 325xi
Well I've encountered a new problem. My door handle doesn't seem to work. I looked at the little screw on the side of the door that is used to tighten or loosen up so that the door handle can be smoother and it seems to be threaded. Suggestions?
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 05-08-2013, 12:41 PM   #18847
ClaytonL
My Ride: 2003 325i
Halfway or 15 parts? ALL my front has been changed (except the brackets on the sway bar but I'll do that when I get back from LA). I can only count 11 in the rear I have left to do. (4subframe, 3 diff, and 4 wanna-be control arm ball joints)
When the time comes to do all those stage 3 bushings, Ill drive up and we can knock out both of our cars at the same time.
Can not wait for the alignment tomorrow to feel how the car is going to handle after. Right now my wheels look like \ |. I marked them as best as I could but its not perfect.
Old 05-08-2013, 12:44 PM   #18848
Blueandwhite85
My Ride: E46
Front pads, sensor and rotors. Ah yes the feeling of fresh brakes.
Blueandwhite85 is offline   Reply With Quote
Old 05-08-2013, 12:45 PM   #18849
Llink78
My Ride: 2002 330i
I can't wait to get the bushings and stuff done. Bought the car and it had 136k on it. Had to replace struts/shocks and springs. Finished that now doing a engine overhaul. Including VCG, Vanos seals and line, oil filter gasket. Then while its apart UUC pullies and headers. And am sending out for a AA flash of the ecu. Then full rear refresh kit. Then front. Figure ill do one a month.
Llink78 is offline   Reply With Quote
Old 05-08-2013, 12:56 PM   #18850
My Ride: Lexus
That would be fun. I have most of the parts sitting in my closet already. just haven't had the time to do it. After I come back from vacation next month i'll knock out some more projects. the outer control arm balljoints and bushings can be done without lowering the axle. even the rear inner lower can be done easily as well (as far as access goes) the upper inner is the b!tch.
I also have front wheel bearings to put in (rears done) list goes on...
Old 05-08-2013, 01:12 PM   #18851
ClaytonL
My Ride: 2003 325i
Exact same here for front bearings. I'll start buying the final bushings for the rear once summer is over.
Also, just placed my final order of $200 worth of items to get ready for Bimmerfest!!!!
Hopefully it gets here in time or Ill be really upset since I upgraded the shipping.
Old 05-08-2013, 01:55 PM   #18852
Adionik
My Ride: Bavarian Panzer
Where are you getting the alignment?
Originally Posted by Brinkley View Post
I tried to start my car without my undertray today. It exploded in a ball of fire. I put the tray back in, hoping that will fix the issue.
Adionik is offline   Reply With Quote
Old 05-08-2013, 02:18 PM   #18853
RKiepper
My Ride: 1999 E46 328I x2
Finally got the CCV out. Good thing I did too.
RKiepper is offline   Reply With Quote
Old 05-08-2013, 02:54 PM   #18854
tcphoto
My Ride: E92 335 MT Coupe
I did not pass my emissions test, the mechanic told me it had a P1071 code. I replaced the vacuum hose on the air check valve and the vacuum control switch yesterday. He told me to just drive it and retest but it would not even go past the O2 sensor heat display. I went by the auto parts store and picked up a bottle of Seafoam and put it in the gas tank then drove it some more. I had no smoke and it drove with no issues. The last month has been all O2 pre cat sensor, misfires and catalytic efficiency codes so I replaced the two pre cat sensors, cleaned the ICV and disa then replaced the intake boots. The car just passed 120K and this has been the first issue with emissions. Any ideas?
tcphoto is offline   Reply With Quote
Old 05-08-2013, 03:02 PM   #18855
effay
My Ride: 323Ci
Originally Posted by Hollywood516 View Post
That trim needs help
Originally Posted by hizhinezz View Post
Yikes.
Originally Posted by THECLEANERBEAMER View Post
The carbon fiber cloth looks horrible why not just vinyl wrap it?
currently waiting on my acutal carbon fibre piece to come in. not wrap but its been molded. I needed somehting in there for the 2weeks it takes to get here
edit*
also installed LED's in my interior and license plate. waiting for nightfall to take pics
effay is offline   Reply With Quote
Old 05-08-2013, 03:34 PM   #18856
My Ride: Lexus
Got my grillez from ECS Tuning. I'll post a pic later. A good one.
Old 05-08-2013, 03:43 PM   #18857
Eisenheim
My Ride: 2002 PY E46 M3
lemme know if they're worth the price. I've seen cheap ones on Ebay, and I'm debating whether or not buying the ECS ones or going cheap :X
Eisenheim is offline   Reply With Quote
Old 05-08-2013, 03:45 PM   #18858
My Ride: Lexus
They're not "ECS grills" they're Genuine BMW. Genuine BMW body parts, if no OEM option exists, is always worth the price.
Old 05-08-2013, 03:52 PM   #18859
Eisenheim
OHHH I thought you meant the blacked out grilles.....ma bad.
Old 05-08-2013, 03:54 PM   #18860
My Ride: Lexus
it's cool. Only blacked out grills that are good in my opinion would be BMW Performance ones. Aftermarket ones don't fit right and are very brittle. They'll work for 95% of people but then again i'm not 95% of people. They should be fine as long as you aren't very picky
Rate This Thread
