Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 05-09-2013, 12:55 PM   #18921
serdar255
My Ride: '01 325ci / '90 325i
* What did you do to/for your E46 today? *
Originally Posted by Stiggles View Post
The OEM radio blows chunks, Lol.
My non HK system compares to a BSW upgrade with the Kenwood headunit.
What do you have other than the HU
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 05-09-2013, 02:31 PM   #18922
Guest021715
Account closed.
Originally Posted by Mango View Post
No doubt you added functionality (does your volume controls work?)
I'm not totally against aftermarket radios. I'd consider a nicely molded/installed double din screen. It's just a lot of headache to mod the ducting. i want to though one day.
And i didn't stare at the pics too long. i'll look again. if you want to be busted!
If you recall the last time you scolded me for my floor mats and headunit, I had just spent a few hours getting the steering wheel controls reprogrammed to the M3 wheel. So yes, they work
- Had an 1000w RMS Alpine amp. Sucked, always overheated, so I sold it.
- Got a Hifonics Brutus 2100w RMS. Amazing amp, never overheats, 1 Ohm stable.
- Have 2 Alpine Type-R subwoofers in a ported box (2+2Ohm DVCs)
..But I recently took all the equipment out, minus wiring. Too heavy, and its damn-near impossible to stop the trunk-lock actuator from rattling.
Old 05-09-2013, 02:34 PM   #18923
My Ride: Lexus
and type-r subs are pretty nice
Old 05-09-2013, 03:47 PM   #18924
tock172
My Ride: '12 135i Dinan S2
Drove it over 500 miles. No issues.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 05-09-2013, 03:52 PM   #18925
My Ride: Lexus
like a champ
Old 05-09-2013, 04:01 PM   #18926
Mr.Makeveli
My Ride: 2001 325i(sedan)
Re: * What did you do to/for your E46 today? *
Replaced window regulator.
Sent from my SPH-L710 using BimmerApp mobile app
Mr.Makeveli is offline   Reply With Quote
Old 05-09-2013, 04:30 PM   #18927
ClaytonL
My Ride: 2003 325i
after one day my brand new VDO fuel pump took a dump. :-(
happy that FCPeuro stepped up and is sending me out a new one. hopefully it gets here by Thursday before I leave for LA as they said it would.
ClaytonL is offline   Reply With Quote
Old 05-09-2013, 05:01 PM   #18928
lszlszx
My Ride: 1.8T, XC70
I treated the paint with Meguiar's ultimate compound.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-09-2013, 05:05 PM   #18929
illestminimike
My Ride: Project Drama
Looking good. What do you use your roof rack for? I really want the snowboard one now that I have a coupe.
Old 05-09-2013, 05:06 PM   #18930
effay
My Ride: 323Ci
Installed my $58 junkyard sport seats to match the M3 wheel
*Cheap yes, but took me lots of labor to get them in shape. Started by steam cleaning the heck out of them, and redyed the cloth black with duplicolor. Texture is the same after applying dye, I was afraid it wouldn't be.
so minty
effay is offline   Reply With Quote
Old 05-09-2013, 05:33 PM   #18931
illestminimike
Stiggles just needs a Dynavin. But great work anyway!
Old 05-09-2013, 05:34 PM   #18932
Blueandwhite85
My Ride: E46
I don't disagree but I think the HU he has now is great. If he could have found a custom center mounted bezel that would have of course been better, but those are hard to come by.
Blueandwhite85 is offline   Reply With Quote
Old 05-09-2013, 06:00 PM   #18933
illestminimike
I had a kenwood bt-900 in my vert and loved it but I put a dynavin in coupe and let's just say it's definitely worth it.
Old 05-09-2013, 08:14 PM   #18934
CK325
My Ride: 323Ci, 325xi
makes both of us
CK325 is offline   Reply With Quote
Old 05-09-2013, 08:15 PM   #18935
WDE46
My Ride: '13 128i, '04 330Ci
Did the electric fan swap in about 1.5 hours. My car is so smooth now. I can hardly even feel it idling in neutral and the vibrations in drive are diminished. Best mod ever.
I did get a good look at my VCG. It's a victor reinz. You guess it. It's leaking like a mofo. So that and VANOS is next on my list.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-09-2013, 08:23 PM   #18936
JZambrano7
My Ride: 2003 325xi
Hmm is that the only thing to look out for when having a rough idle? ^
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 05-09-2013, 08:28 PM   #18937
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Car is getting a ton of work done at the shop... needed for for a 5800 mile trip within two weeks
Old 05-09-2013, 08:33 PM   #18938
lszlszx
My Ride: 1.8T, XC70
That is an awesome road trip!
Old 05-09-2013, 08:35 PM   #18939
lszlszx
My Ride: 1.8T, XC70
I am looking forward to doing this, there are so many benefits to it!
Old 05-09-2013, 08:36 PM   #18940
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yup...
Items being done are the following; (and yes it hit my wallet hard)
- Rtabs
- New rear e-brake lines
- Oil pan gasket
- Oil change
- Power steering line/new fluid
- Oil filter housing gasket
- Differential fluid
- Engine mounts
- Broken bolt removal from head (water pump bolt, someone broke it off...)
- Coolant drain and refill
- Thermostat
Rate This Thread
