Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-23-2011, 07:06 PM   #1901
juvis
My Ride: 2000 bmw 323i
found vacuum leak, install both front controll arms, put in new shift boot, and did the rear brakes...
juvis is offline   Reply With Quote
Old 02-24-2011, 09:09 PM   #1902
tifreak
My Ride: sdfgsdf
managed to slam the door on the seat belt buckle just perfectly that it jammed the buckle between the door panel and the door, put a big mark on the edge of the panel
tifreak is offline   Reply With Quote
Old 02-24-2011, 09:45 PM   #1903
auto180sx
My Ride: '02 Steel Blue 330Ci
Met up with another fanatic and got some coding done on the car.
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 02-25-2011, 08:28 PM   #1904
Sundaii323ci
My Ride: Ri
got this today still waiting on my shocks to get here and then it will be 100%
Sundaii323ci is offline   Reply With Quote
Old 02-25-2011, 08:30 PM   #1905
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Should put one pic of the antenna I got on wednesday
Old 02-25-2011, 08:34 PM   #1906
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
euro plate came in today
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 02-25-2011, 08:36 PM   #1907
Sundaii323ci
My Ride: Ri
What kind of bumper is that?
Old 02-25-2011, 08:37 PM   #1908
Sundaii323ci
My Ride: Ri
I'm really loving this bumper man nice!!
Old 02-25-2011, 08:38 PM   #1909
Solidjake
Zero. Leaks.
Solidjake's Avatar
Mtech I
Old 02-25-2011, 09:18 PM   #1910
E46_330i_Stud
^^ what he said. Its a little roughed up but I like it. Thanks!
Old 02-25-2011, 09:32 PM   #1911
e46rage
My Ride: 330ci 2001
Got the best mod there is !!!! A speeding ticket
Sent from my PC36100 using Bimmer App
R.I.P. E46RAGE.
e46rage is offline   Reply With Quote
Old 02-25-2011, 09:41 PM   #1912
ccagle
My Ride: 02' 325i
Installed new windshield washer pump, fixed side mirror cover via DIY zip tie trick and fixed my trunk lip thingy (I know, real technical term). Its the black handle you pull to open the trunk. It had broken away from the bolts... All better now!!
Sent from my Droid using Bimmer App
ccagle is offline   Reply With Quote
Old 02-25-2011, 09:44 PM   #1913
ccagle
My Ride: 02' 325i
Should have done a DIY on the trunk handle repair... Nothing like a dremel, 1 1/4" washers and some patience. I think its now stronger than OEM and looks as good as new
Old 02-25-2011, 11:18 PM   #1914
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Installed Meyle HD CAs & CABs. BTW, they came with CABs already on CAs with correct distance from inner ball joint to the bushing's edge - 290 +- 1 mm.
Source: www.oembimmerparts.com
Nervous is offline   Reply With Quote
Old 02-26-2011, 12:33 AM   #1915
andrewlcraft
My Ride: '03 325Ci, '04 X3
Verified my check engine light doesn't come on, ever, by instrument cluster test.
Figured I ought to scan it, since it had ran rough briefly yesterday for the first time. And my cruise control has been inop since we bought the car last month, and all the forum threads say MAF. I always thought that was weird since I had no check engine light, but now I know why that is.
Guess what code was set? P0102, MAF. Checked the data stream, MAF reading was 0 at all times. So new MAF tonight and all is well and cruise works.
Also had pending cyl #5 and #6 misfire codes, which explains the rough run yesterday. Picked up a set of plugs, since I'm about 700 miles away from 100K anyway, and that'll give me a chance to check out coils, etc while I'm at it.
2003 325Ci
andrewlcraft is offline   Reply With Quote
Old 02-26-2011, 01:36 AM   #1916
SMUUUUUV
My Ride: 330CiC X5 4.4-MBS550
Finally got around to painting these... might install them tomorrow... ..
SMUUUUUV is offline   Reply With Quote
Old 02-26-2011, 01:59 AM   #1917
rcsummers
My Ride: M3
spray wax, and put her under the cover for the weekend. Supposed to get rain and snow all weekend so she wont be going out much.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 02-26-2011, 02:33 AM   #1918
reddemon
My Ride: 2004 325i
doesn't that hit your roof or window when you open the trunk? is that wire on the left there just for fit test, will you route it through the inside of the truck?
r e d d e m o n
reddemon is offline   Reply With Quote
Old 02-26-2011, 10:46 AM   #1919
Keith330i
My Ride: 01 TiAg 330i
This..
3lb hammer and DONT swing your purse at it. You really gotta beat the hell out of 'em sometimes
Keith330i is offline   Reply With Quote
Old 02-26-2011, 11:14 AM   #1920
theinfamousdrew
My Ride: 911 Turbo / E70
BMW performance rear rotors to match the fronts
theinfamousdrew is offline   Reply With Quote
Rate This Thread
