Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 05-16-2013, 12:05 AM   #19181
TerraPhantm
My Ride: M3 & ZHP
If you had a shop pull your wheels for any reason, double check their torque.
I just discovered that 3 of mine were extremely over tightened (breaker bar was bending), and one of them was way under tightened (I would estimate 30 lb-ft). Probably explains why my front end has been feeling loose around hard turns. Next time I'm just going to keep my breaker bar and torque wrench with me and retorque those lugs in their parking lot.
Probably going to buy new lugs too since these bolts have most likely been over stretched. Actually, I think I'll just buy a stud conversion kit
Old 05-16-2013, 12:11 AM   #19182
My Ride: Lexus
Yep. Today I went to a tire shop to get my rear m68 installed. i made sure they used MY OWN torque wrench from start to finish. the guys actually prefer it cause they dont have to drag the air tools/hose all the way to the working area. Demand it. be in their face about it. dont let them torque it to 200 lbs only for you to unload it and retorque it in the parking lot. make sure your bolts are never torqued that high.
i'd just do bolts unless you're a track freak. keep it pure. Personally i trust the bolts more and they just plain look 1000x better.
Old 05-16-2013, 12:21 AM   #19183
TerraPhantm
My Ride: M3 & ZHP
Yeah I'll do that next time. I could have sworn I saw them use a torque wrench last time, but that's probably because I was watching.
Meh, I'm not a track nut, but I do prefer studs. I work on the car enough that it is worth it to me. And as far as I'm aware, they aren't any less safe than bolts. If I do go with studs/nuts, I intend to go with a set that doesn't look terrible
Old 05-16-2013, 12:25 AM   #19184
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
* What did you do to/for your E46 today? *
Originally Posted by trentcdrums View Post
Attachment 505670
Bought these for my 323i. Are they shortys or long!?
Neither
Old 05-16-2013, 12:35 AM   #19185
My Ride: Lexus
Eh I dunno. I don't like the idea of dropping nice aluminum wheels on stud threads (letting them hang). Also any exposed part of the thread is going to be subject to corrosion just like the back of the wheel bolt is but at least the wheel bolt is hidden.
I love working on my car with wheel bolts actually. I've got it down extremely well and I'm very very fast and accurate. I plop it on, thread one boltall the way on with my extended 1/2"/17mm socket combo and voila. The one bolt holds it flush and i take my time threading the rest. Just used to it i guess.
Old 05-16-2013, 12:35 AM   #19186
RKiepper
My Ride: 1999 E46 328I x2
Since we're on the topic of wheels.
I dropped off my square M3 fronts at a shop so I can get a warranty exchange on tires that turned out to be junk.
Not crazy about one of the employees though. Watching him try to put a full size spare into the trunk of a Mercedes. He couldn't get the liner up with the wheel in his hands so he dropped the wheel onto the concrete and heard it hit the back of the rim against the concrete. Pretty damn loud too. Didn't even care that he had done it.
Def gonna make a point to not let that kid touch my wheels tomorrow.
RKiepper is offline   Reply With Quote
Old 05-16-2013, 12:51 AM   #19187
briangl92
My Ride: VQ37VHR
I had the same thing happen to me after the dealership refinished my wheels. They subcontracted it, and the outside company is the one that reinstalled the wheels.
I had to use a breaker bar plus the jack handle to break them loose. The breaker bar was bending. I also found 3 bolts that were literally finger tight. I checked them after I got a horrible vibration under braking on the way home. Can't trust anyone...
Sent from my iPhone
briangl92 is offline   Reply With Quote
Old 05-16-2013, 12:54 AM   #19188
briangl92
My Ride: VQ37VHR
Not to mention they didn't clean powder coat out of the bolt seats so I've had an issue with the bolts not holding torque and within 200 miles I'd have vibration under braking.
Sent from my iPhone
Old 05-16-2013, 01:05 AM   #19189
TerraPhantm
My Ride: M3 & ZHP
The wheel should still hang off the hub, but the studs would make it much easier to actually line up properly. Especially if you have spacers
I imagine a set of coated bullet nose studs wouldn't have any visible rust even with open ended nuts
Sent from my iPhone
Damn man that really sucks. I would see if you can get them to replace the afflicted hubs since that is a safety issue IMO
Old 05-16-2013, 08:25 AM   #19190
bostonsthename
My Ride: 2003 Jet Black 330xi
Not sure why you are posting angry things.
http://forum.e46fanatics.com/showpos...56&postcount=2
I'm not sure why either, I just happened to get the link from his sig. Either way, I plan on doing electric fan swap, cooling overhaul, VCG, vanos seals, and fluid changes in the near future (money permitting)
bostonsthename is offline   Reply With Quote
Old 05-16-2013, 08:46 AM   #19191
WDE46
My Ride: '13 128i, '04 330Ci
I thought I had seen it all, but apparently you document every good thing someone says about you...wow.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-16-2013, 08:53 AM   #19192
Blueandwhite85
My Ride: E46
Re: * What did you do to/for your E46 today? *
His life is this website, what did you expect?
While you may have compiled the information into one thread, none of this e46 cooling system knowledge of yours would exist if it wasn't for bmw. Also I didn't post anything angry, was just pointing out that you didn't create the cooling system or a single component for it, therefore you have no posession of it or the knowledge of it since afterall it's free information that can be found throughout the Internet and beyond.
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Blueandwhite85 is offline   Reply With Quote
Old 05-16-2013, 09:25 AM   #19193
trentcdrums
My Ride: BMW 323i Sedan
Originally Posted by peytonracer4 View Post
Neither
Elaborate?
Old 05-16-2013, 09:37 AM   #19194
briangl92
My Ride: VQ37VHR
Well it's been less than 6 months and the clear coat is already starting to peel on at least one, and they're guaranteed for life against peeling so it's going back, unfortunately, at some point. I've had a problem with this dealership every single time I've gone and even filed complaints against them with BMWNA over their stupidity. This next time, I'll have a torque wrench and breaker bar in hand. I might even go as far as to have them show me the bolt seats before I leave.
Old 05-16-2013, 09:37 AM   #19195
BABY
My Ride: 2005 BMW 330 Cic
Getting back on track... Finished leather clean condition...
My BABY! 2005 330 Cic, premium & sport package, style 71's.
BABY is offline   Reply With Quote
Old 05-16-2013, 09:39 AM   #19196
My Ride: Lexus
coincidence you threw a tantrum @ me the other day now this?
you just wandered in, scrolled two pages back and had to randomly pick out someones nice post to say "ERM DAT'S NOT MANGO'S INFO FYI"
and no, wde, i don't save nice things people say. it's called google. took me two seconds to pull that quote up.
And FYI, my info on the cooling system was well before I read TIS. It's also featured on the Bimmerfest Wiki so yeah I guess it must be repeated information huh?
putting you on ignore. indefinitely.
Old 05-16-2013, 09:41 AM   #19197
My Ride: Lexus
Definitely back on track. What did you use? I use UK's Gliptone. Will be doing that and a bunch of stuff tomorrow. just got my new refreshed wheels put on.
Old 05-16-2013, 10:31 AM   #19198
E46inthe206
My Ride: 2003 BMW 330Ci
Getting the CSL bumper+trunk painted/installed today. Pictures will be up tonight.
E46inthe206 is offline   Reply With Quote
Old 05-16-2013, 12:28 PM   #19199
Blueandwhite85
My Ride: E46
Filled it with smoke. Purptrainwreckyumftw
Sent from my S4 using BimmerApp mobile app
Old 05-16-2013, 12:37 PM   #19200
WDE46
How would you even google that? Needs pretty specific search terms don't you think?
Rate This Thread
