Old 05-08-2010, 04:02 PM   #1
RXATE
My Ride: 2001 BMW 330i Sport
oil seeping from filter housing
This started after doing the oil filter housing gasket project...the gasket that goes between the block and the oil filter housing assembly. Now it is leaking from the oil filter cover, as in where you slide the the actual oil filter out.
It seems like I screwed something up and perhaps there is increased oil pressure. Ever hear of this?
Thanks for any help, Mat
RXATE is offline   Reply With Quote
Old 05-08-2010, 04:06 PM   #2
ChasCan
My Ride: 2001 330xi
Could be a bad o-ring on the oil filter housing cap. Or could be a break in the CCV hoses to the valve cover when you did the of housing gasket. Chas.
ChasCan is offline   Reply With Quote
Old 05-08-2010, 04:13 PM   #3
oc330cic
My Ride: 2002 330 CiC
Another possibility is that the oil filter housing itself has cracked. I've heard of this happening when the cap is over torqued.
oc330cic is offline   Reply With Quote
Old 05-08-2010, 04:15 PM   #4
ChasCan
My Ride: 2001 330xi
The cap is plastic. The housing is aluminum. Chances are the cap would crack first. Just my .02. Chas
Old 05-08-2010, 04:47 PM   #5
oc330cic
Oops, absolutely right. The cap can crack if overtorqued.
Old 05-08-2010, 05:18 PM   #6
RXATE
Appreciate the feedback so far.
I'm going back out to check it over again. It doesn't seem like there would be any way to put this back on incorrectly. The rubber o-ring on the filter cap itself looked ok and I'll check the actual cap for cracking. Appreciate your help -Mat
Old 05-09-2010, 02:26 AM   #7
RXATE
got it
Thanks guys. A fresh oil filter o-ring did the trick. I was thrown off because before I replace the oil filter housing gasket attaching the housing to the block the part that houses the filter didn't leak. My guess was that the leak next to the block lowered the pressure in the part that houses the acutal filter...had the gasket on the block been ok, then the oil filter part would have leaked weeks ago. While there was an o-ring there it was more rectangular than a true round o-ring and not as tight as the fresh one. Thanks, Mat
oil filter, oil filter housing leak, oil leak
