Sponsored by The Tire Rack
Old 05-08-2010, 08:52 PM   #1
bimminge46
My Ride: 323Ci, 89 325i ETA
Help choosing wheel spacers csl 18x8.5 square
I have the CSL style 18X8.5 +40 and am running a 235/40/18 all around. I have a stock sport suspension. I was wondering what a good spacer setup would be. I want a more aggressive look so the tires are close to flush with the fender without any rubbing/rolling fenders. I am thinking 12mm to 15mm for a flush fitment in the rear. It is 7/8's from the tire sidewall to the outer fender.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 05-10-2010, 01:42 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The best option is to mount them to the car and measure using this guide:
However, based on those offsets and tire sizes, a 10mm spacer for the rear should work well.
Old 05-10-2010, 01:50 PM   #3
djnekkon
My Ride: MB3ci & z33 HR
^^^^^+1
Right now? even 25mm will do it, if you're not dropped. I'll try 10 mm in case I want to drop it.
Old 05-10-2010, 02:00 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
id run 10s up front, because i rub a tad with 18x8.5 245/40 et28, (which is what youd be at ET40 + 12mm), so id aim for ET30.
For the rear, with 235s, id take a shot at a 15-20mm with a coupe.
Do you ride a sportbike?
Old 05-11-2010, 02:11 AM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
I would recommend measuring the gap as well.This will guarantee yourself a correct size spacer for your specific application.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
