Thread Tools Search this Thread Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Old 05-14-2012, 10:25 PM   #21
ZANIESXD
My Ride: 2002 325i Sedan
Ill be doing this tomorrow! thanks!
ZANIESXD is offline   Reply With Quote
Old 05-15-2012, 06:11 PM   #22
ZANIESXD
Originally Posted by Scott87 View Post
I have tried to construct this image to show a little better how the connections all hook up and basically you could do the DIY with this 1 image i think!
But it may be cr@p, let me know!
Scott.
just got mine out! still waiting on new clutch though so it will be a little while before i can test it. thanks for the tutorial!
Old 10-15-2012, 09:31 AM   #23
E46BAV90
My Ride: 330ci & 325xi
This is a great CDV delete DIY. I just did a clutch slave cylinder replacement write up and linked your CDV delete thread to it, incase people want to kill two birds with one stone.
2002 330ci & 1987 325i vert
SIG PIC
Clutch Slave Cylinder Replacement DIY
E46BAV90 is offline   Reply With Quote
Old 12-26-2012, 05:50 PM   #24
jason330cic
My Ride: 2001 330cic
Originally Posted by e4Tsex View Post
I've owned my car for over three years and have always wanted to remove the CDV. Finally got everything ready and went under the car last weekend for removal but the CDV was not there! What a relief, but now I am curious if someone else had alredy removed it or if some early e46 (like my '00 preface-lift sedan) just didn't come with it.
Same thing happened to me today. I finally got under my car to pull the CDV and it wasn't there . I think there was someone else on here that said their 2001 330ci didn't have one either, so maybe no 2001's have CDV's. I still changed out the brake fluid and bled out the clutch slave cylinder which made a huge improvement in the clutch pedal. It seems to shift much smoother now.
Jason330cic
jason330cic is offline   Reply With Quote
Old 05-13-2015, 06:12 PM   #25
diggerdeat
My Ride: bmw 320 ci
i tried this but..
i tried this but after removing the valve i found coupling the two pipes together leaks, the ends are not compatible, any ideas ?
diggerdeat is offline   Reply With Quote
Old 06-03-2015, 02:58 PM   #26
CabrioPassion
My Ride: 330Ci Cabrio M.T. II
What are year/month production of your 320ci?
CabrioPassion is offline   Reply With Quote
Old 06-03-2015, 03:01 PM   #27
diggerdeat
My Ride: bmw 320 ci
November 2001
Old 06-04-2015, 04:41 AM   #28
CabrioPassion
Originally Posted by diggerdeat View Post
November 2001
http://www.realoem.com/bmw/enUS/show...diagId=21_0094
In which parts did you have problem? Didn't part number 14 fit with part n. 12 without part n. 15?
Old 06-04-2015, 07:25 PM   #29
diggerdeat
My Ride: bmw 320 ci
Yes they fit and screw tight but the end of the pipe wont seal
Old 06-05-2015, 08:38 AM   #30
CabrioPassion
So will you get UUC's CDV?
Old 06-05-2015, 08:52 AM   #31
diggerdeat
My Ride: bmw 320 ci
What does that mean?
Old 06-05-2015, 02:46 PM   #32
CabrioPassion
Will you buy UUC's CDV instead original one?
http://store.uucmotorwerks.com/unloc...kit-p1382.aspx
Old 06-05-2015, 02:48 PM   #33
diggerdeat
My Ride: bmw 320 ci
Ah i see, i take it that is an unrestricted fitting to replace the CDV?
Old 06-06-2015, 05:38 AM   #34
CabrioPassion
It replaces original CDV and is totally unrestricted:
"Replacement of the valve with the no-restriction replacement Unlock Valve in these cars results in very crisp and firm shifts. With the lightweight flywheel, the engagement is so positive and quick that passengers are pushed into the seat with greater force than ever before. Installation is as simple as unscrewing the original lock valve from the slave cylinder line, replacing it with the Unlock Valve, and bleeding the slave hydraulics."
Old 06-06-2015, 05:40 AM   #35
diggerdeat
My Ride: bmw 320 ci
Ah ok thanks I'll look into that
Old 06-06-2015, 05:42 AM   #36
CabrioPassion
You're welcome
Old 08-17-2016, 03:24 PM   #37
alexs.lens
My Ride: 2003 BMW 330i
THREAD REVIVAL POWERS ACTIVATE
Nice write-up... Use flash next time, but this is very helpful!
2003 Japanrot 330i 5MT
1998 Avus Blue 318ti 5MT - SOLD
alexs.lens is offline   Reply With Quote
Old 11-14-2016, 09:01 PM   #38
rlordjr
My Ride: 2001 325Ci
More thread reviving. Rather than paying UUC why not just drill out the inside of the OEM check valve and put it back in? Might solve some people's leak issues when the fitting is not in place.
rlordjr is offline   Reply With Quote
