235 35 19 on 9.5? Yes/No? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 05-10-2010, 09:01 AM   #1
Don B
My Ride: 325i (RHD)
Have searched, can't quite find the answer!
Put Linea Corse L22s on my car at the weekend, and am getting a little
rubbing on the rears.
My current setup is 255 30 19 on the 9.5 ET42 rears (photo below).
Would a 235 35 19 tyre stop the rubbing I'm getting? Don't want to roll the
fenders, as I don't trust a shop here to do it correctly.
Would putting 235 35 19's on the 9.5's be a valid option, or would it be
dangerous (and look ridiculous)?
Any advice greatly received!
Current setup.
Don B is offline   Reply With Quote
Old 05-10-2010, 01:21 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Looks like camber or a narrower tire would be the only option if you are not looking to fender roll. Adding about a half degree or a 245 tire will help.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-11-2010, 11:23 AM   #3
Don B
My Ride: 325i (RHD)
-Charles@VMRWheels
Thanks for the reply!
Have to get a 4 wheel allignment done anyway, as I've installed Eibachs, will see what they can do.
Also, would machining 3mm off the back of the wheel to bring the offset from ET42 to ET45 present problems?
I contacted a shop that said they could do safely as long as there was enough material to work with.
Sponsored Links
Advertisement
Old 05-11-2010, 12:46 PM   #4
VMRWheels
VMRWheels's Avatar
Machining of the rear hub can be done but IMO, fender rolling is a much easier process then machining the rear hub of a wheel.
-Charles@VMRWheels
Old 05-11-2010, 12:53 PM   #5
Don B
My Ride: 325i (RHD)
-Charles@VMRWheels
Thanks for the further thoughts.
I really want to bring the wheels in a little, as they stick out too far imo...and I'm not lowered
enough to pull off the look.
Old 05-11-2010, 09:15 PM   #6
VMRWheels
VMRWheels's Avatar
Adding a hair bit of camber may help that. You can still run some slight camber and have the correct toe for perfect alignment and even tread wear.
Depending on how thick the back pad is, machining is possible, but definitely double check with the manufacturer before doing so.
-Charles@VMRWheels
Old 05-12-2010, 01:21 AM   #7
ZeHP
My Ride: 330i ZHP
i ran a 235/35/19 on my 9.5 lm rep. the mild stretch looks really aggressive yet classy it will fit on the wheel fine it is within spec. however I did have my fenders rolled so I cant attest to your situation with possible rubbing-- however i do know others on this forum that run 255/30 and have no rubbing whatsoever as long as you roll the fender. it's your decision. good luck
ID:	359993   Click image for larger version
ID:	359994   Click image for larger version
330i ZHP
"It's pretty much an M!"
"No it's not."
ZeHP is offline   Reply With Quote
Old 05-12-2010, 02:12 AM   #8
Penguin Koolaid
Banned
My Ride: Inline Six
Rolling your fenders and a slight increase of negative camber on the rears should take care of your problem.
Penguin Koolaid is offline   Reply With Quote
Old 05-12-2010, 02:49 AM   #9
Don B
My Ride: 325i (RHD)
-Charles@VMRWheels
I presume machining the back of the wheel would void any warranty?
Thanks for the photos, gives me a good idea, same brand of tyre I'm running too. What offsets were those rear wheels?
Going to explore my other options first, getting someone to do a good job at
fender rolling where I am could prove difficult.
Old 05-13-2010, 01:08 PM   #10
VMRWheels
VMRWheels's Avatar
Most if not all manufacturers would void the warranty if any modifications are done to the wheels that could compromise the strength and safety.
-Charles@VMRWheels
