Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 05-10-2010, 09:56 PM   #1
Iceman00
Banned User
My Ride: E90 6MT
Dyno Test on why Short Ram intakes don't work
Makes sense to me, I've also seen something like this before.
Old 05-10-2010, 10:01 PM   #2
HardPark'd TT
My Ride: is parked hard.
Send a message via AIM to HardPark'd TT
Yet we still will get threads on "what intake gives you the most hp..."
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
HardPark'd TT is offline   Reply With Quote
Old 05-10-2010, 10:05 PM   #3
JJR4884
My Ride: BMW
question..... when you look at the design of the k&n 57 series intake... that comes with a heat shield and also the air from the kidney grills is channeled in through that way
looking at the 350z... i see no intake snorkels or anything to push outside air to the filter, and clearly no heat shield
while i know i get no horsepower from a k&n 57... would i lose less? stay the same? thoughts?
JJR4884 is offline   Reply With Quote
Old 05-10-2010, 10:06 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Cold air, long tube type, (Dinan, Benefer, Cosmo) those are the only type I would ever use. If you're worried about ingesting water, get a bypass valve.
Old 05-10-2010, 10:07 PM   #5
Redline
Redline's Avatar
My Ride: ///M3 Vert
i have a k&n panel filter with a hole cut in the front of my airbox with a pipe leading to the front bumper. cone filters suck in hot air off of the engine reducing power as well.
k.
///M
Old 05-10-2010, 10:09 PM   #6
Iceman00
Banned User
My Ride: E90 6MT
Same issue. The filter is to close to the MAF, and causes it to read too much/too little air because of turbulence. You need a Venturi ring of some sort (like JWT uses on Nissans) or a longer tube to smooth out the air flow.
Old 05-10-2010, 10:14 PM   #7
toastygt30r
My Ride: 2002 330 ci
I don't think I see a difference in horsepower per say but see a difference in throttle response
92 Full Race HB...RIP
toastygt30r is offline   Reply With Quote
Old 05-10-2010, 10:17 PM   #8
E46 S54B32
My Ride: 323ci
hmm that article makes alot of sense...now what about the foam filter on the itg/conforti intake systems...will that also create an air vortex?
i have the conforti intake with the heat shield that draws air from the front kidney vents
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 05-10-2010, 10:46 PM   #9
carcus
My Ride: 2006 BMW M5
The Gruppe M intake is a bit different though, not really a HAI intake.
EDIT: Nice information from Import Tuner Magazine BTW..........LOL
I am sure there are about 1000 posts on intakes here that Import Tuner Mag did not publish.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 05-10-2010, 11:00 PM   #10
Iceman00
Banned User
My Ride: E90 6MT
I hate Import Tuner, but I hold Tony from Motordyne Engineering in high regard. I've had MANY heated debates with him on My350Z, and I can tell you, not only does he go through great lengths to gather information, he is very intelligent. His input into this article is the only reason it's worth reading.
That being said, it's NOT were the air is being gathered from, it's HOW. A intake element closer to the MAF will have more turbulence than something further way. this turbulence is what leads the maf to read more/less air and cause it to run rich/lean. The gruppe M is just not as effective as a Dinan long tube intake, and the Conforti as well (though you can see the Conforti uses a smaller tube to separate the intake from the maf)
Old 05-10-2010, 11:05 PM   #11
carcus
Thanks for the advice, this was new to us here.
Old 05-10-2010, 11:07 PM   #12
Iceman00
Banned User
My Ride: E90 6MT
I'm not sure if this is sarcasm, but I'd like to see these long discussed topics complete with MAF readings, and A/F readouts. Most of the threads regarding intakes usually consist of "search, this has been covered" "they don't add power, just sound" and "stock is best"
Old 05-10-2010, 11:12 PM   #13
carcus
Those can be found in the Import Tuner Mag you just posted.
Old 05-10-2010, 11:17 PM   #14
SNORCE
My Ride: 2005 ///M3
cold air ftw
Photobucket
SNORCE is offline   Reply With Quote
Old 05-10-2010, 11:17 PM   #15
Iceman00
Banned User
My Ride: E90 6MT
I'm pretty sure that article has A/F ratios clearly listed. Please take your douchebaggery elsewhere if you cannot provide a constructive (and informative) post.
Old 05-10-2010, 11:18 PM   #16
E46 S54B32
My Ride: 323ci
Originally Posted by SNORCE View Post
cold air ftw
Photobucket
i want!!!
Old 05-10-2010, 11:20 PM   #17
carcus
No problem Ice Man....
EDIT:
And it was kind of gay you post something from Import Tuning Mag....and call me a douche. Hell, you have a Z3 in your sig....granted I love a BMW, but do not come on here with a Z3 and post import mag stuff and call me a douche....ROFLOL!!!!
Old 05-10-2010, 11:33 PM   #18
Iceman00
Banned User
My Ride: E90 6MT
Instead of you making a comment about Import Tuner (which I don't read, and those aren't my scans) Why don't you provide me on the specifics on what invalidates this article.
Old 05-10-2010, 11:37 PM   #19
spikester550
My Ride: 330ci, 86.5 hardbody
Send a message via AIM to spikester550
iceman at it again.....
MODS
ESS TX2, 3.38 Diff, K&N CAI, 19" LM's, UUC TSE3,
30 LED AE, OEM MT2 Front & Rear,
CF CSL Trunk, Black Kidney Grills, Smoked Corners,
Painted Reflectors, M3 Steering Wheel,
ZHP Shift Knob, Clutch Stop, Shark Injector,
15mm Spacers, 3k DDM HID Fogs, OEM M3 Hood,
Coilovers, UUC Sways, and many more..
spikester550 is offline   Reply With Quote
Old 05-10-2010, 11:44 PM   #20
Iceman00
Banned User
My Ride: E90 6MT
Are you just an idiot? Or did you not see how this thread went from being informative and factual to down right childish. Even my biggest critic JJ commented, and questioned in a mature fashion.
Grow up.
