Sponsored by The Tire Rack
Old 05-11-2010, 04:23 PM   #1
starlights
My Ride: 2006 330Ci
What kind of Tire Pressure Monitoring Sys on 2006 330 Coupe?
I have a Late 06 330 Coupe - I recently changed the wheels and tires from 17" to 18" . The mechanic who did the swap told me that my car does not have TPMS in the tires but the monitoring system runs off indirectly.
Soon after the wheel swap, one of the tires lost all air due to a leaking valve stem while the car was parked - so when I put on the spare (5th wheel of the 17" set) the system inside the car warned me of low pressure in one of the tires - how does it work?
starlights is offline   Reply With Quote
Old 05-11-2010, 05:03 PM   #2
MeanMangoMan
My Ride: E46 325xi
Flux Capacitor located in each tire, very intricate tech. Do not mess with it!
Just kidding, as it turns out the 06 had indirect TPMS! Very cool stuff see below:
Having read the manual of the '06 330xi, I see that it uses a so-called "indirect" TPMS which doesn't actually check the pressure, it just detects the difference in rotation among the tires. This system would pick up low pressure in a single tire, but not seasonal pressure changes (due to temperature drops in the fall and winter) that affect all 4 tires. This would explain why many owners had to replace the entire set of tires early.
Another subtle point is that the TPMS had to be "initialized" right after the tires are inflated to the correct pressures, because that's the reference point used by the computer to compare the tire rotation later. If the system is not initialized properly, e.g., not reset after tire rotation or a flat repair, that would also end up running the tires at the wrong pressure.
MeanMangoMan is offline   Reply With Quote
Old 05-11-2010, 05:04 PM   #3
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
thats pretty much the only place it can monitor...valve stem! Doesn't fit on every rim tho.
howie is offline   Reply With Quote
Old 05-11-2010, 05:11 PM   #4
starlights
My Ride: 2006 330Ci
Well - we checked the tires, (the 17s which were replaced - and nothing in there) yet when i put a 17in spare with the rest 3 18s - the light came on - my impression is that its got to do something with the rotation of the tire (different rotation on 17 vs the 3 18s) ......... but i could be wrong - and am definitely very confused! Lol
Old 05-11-2010, 05:36 PM   #5
MeanMangoMan
My Ride: E46 325xi
Did you read my post? It is done by monitoring tire rotation speed.
Old 05-11-2010, 05:42 PM   #6
howie
NINJA huh...
that's pretty smart. Wouldn't think it was very accurate but wthell
Old 05-11-2010, 06:10 PM   #7
starlights
My Ride: 2006 330Ci
Yep - reading it now ...... you edited and posted your post after my question
Old 05-11-2010, 06:13 PM   #8
MeanMangoMan
My Ride: E46 325xi
Originally Posted by howie View Post
NINJA huh...
If it works it is pretty low maintenance, nice CLK by the way!
Old 05-11-2010, 06:52 PM   #9
howie
thanks, I'm sure it works. But how well does it really work? I mean you would have to be pretty low on tire pressure to notice a difference in rotation...I would think.
