Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 05-11-2010, 10:25 PM   #1
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
New AR Builds Underway
I finally pulled the trigger and started going to work on my new dual-AR project. I am going to convert my DPMS AP4 carbine to a Mk12 SPR. The barrel will come off and I am going to install a Noveske 18" SPR or DPMS Mini-SASS 18" barrel. Add a free-float picatinny forend and a mid-range scope/optic, and the rifle will basically be done. All I need for this build is the barrel, gas block, gas tube and forend. Then, I have to decide which scope I'm going to slap on it. I still can't decide.
In addition to that, I also went ahead and bought a Rock River Arms LAR-15 lower today along with a parts kit and a Magpul MIAD grip kit. This is going to be part of my PDW build. It's going to be a free float Vltor CASV-M, Noveske 7.5" Diplomat barrel, and some yet-to-be-selected mini/micro red dot with BUIS.
It'll look similar to this:
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 05-12-2010, 12:14 AM   #2
david05111
My Ride: drei hundert dreißig
Should be a fun project/thread!
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
david05111 is offline   Reply With Quote
Old 05-12-2010, 06:28 AM   #3
6-speed
My Ride: E21 > E46
awesome, I have thought about doing a SBR. I have a RRA lower that needs an upper.
6-speed is offline   Reply With Quote
Old 05-12-2010, 07:19 AM   #4
Serbonze
Master of his domain.
My Ride: My wife
I have absolutely no idea what most of what you posted actually means, and I can't look it up because I'm at work.
Serbonze is offline   Reply With Quote
Old 05-12-2010, 10:05 AM   #5
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 05-12-2010, 10:12 AM   #6
Reedo302
Reedo302's Avatar
An SPR is a Special Purpose Rifle. SPRs are multi-role rifles that can be used for direct combat engagements and CQB, while also being capable of long range accuracy for expedient sniper/counter sniper operation. SPRs are chambered in a main combat caliber like 5.56mm, have an intermediate/mid-range scope (1.1-8x, 1.5-6x, 1.8-10x, 2.5-8x, 2.5-10x, 3.5-10x, you get the idea..) designed to be used at intermediate ranges of 500-800yds, have a tight twist barrel (1:7 is best, but 1:8 works), and a free-float barrel to help with accuracy. The barrel will ideally be 18", but 16-20" is acceptable. The rifle must be 1MOA or sub-MOA capable. It fills the gap between a standard combat rifle and a dedicated sniper rifle. An example of this rifle is the US Navy Mk12.
DPMS Mk12
standard carbine (top
Mk 12 SPR variant (bottom- note the longer barrel and scope)
A PDW is a Personal Defense Weapon. These are usually smaller submachine guns like the MP5K/MP5K-PDW, KAC-PDW, H&K MP7A1 ( ). They have very short barrels and are designed to be compact, concealable, and able to be used inside of very tight quarters, like inside a vehicle. My concept for my PDW is actually going to be a PSD (protective security detail) concept. The rifle will maneuver and feel like a submachine gun. The shorter barrel, high magazine capacity, short sight radius (if I use the Back Up Iron Sights (BUIS) ), lighter weight, and highly maneuverable for use in a vehicle or when clearing rooms in very confined CQB (close-quarter battle) situations.
Knight Arms Co. KAC-PDW
Glock Armorer
Old 05-12-2010, 04:03 PM   #7
bigdog2003_99
My Ride: 2009 Audi B8
i kind of like the 416 pdw, but the stubby buffer would be fun to try to work with, especially with a 2-4k upper... let me know what you think of the mk12, i really want one and was debating on the mod 1 with a leupold 3-9x40 or wait for the mr556
btw sbr ar15 ftw, any length and almost any caliber at your disposal
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 05-12-2010, 04:31 PM   #8
Reedo302
Reedo302's Avatar
I decided that I'm going to pony up the extra $160 for the Noveske SPR 18" barrel over the DPMS. I did some more reading, and I want the 1:7 twist rate. Also, Noveske utilizes polygonal rifling, which increases barrel pressure due to a better seal. This should really give a boost to the velocity for long-range accuracy. My Mk12/SPR will be mostly custom. I'll probably eventually slap on a Giselle trigger or a JP two-stage.
As for the PDW/PSD build, the initial one will be 5.56mm, however I'll probably wind up building a second upper in the future with the same specifications and chamber it in 6.8SPC to compare with the 5.56mm.
Glock Armorer
Old 05-12-2010, 04:34 PM   #9
bigdog2003_99
ive heard alot of good about woa barrels too, noveske is the best barrel period though, i think the 6.8 would be nice for a pdw-if my m4-2000 was 6.8 instead of 5.56 id be running one now
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
Old 05-30-2010, 08:54 PM   #10
Reedo302
Reedo302's Avatar
Well, after talking to William Graves with GPS Defense (sniperschool.com), which used to be the McMillan Sniper School, He advised me that DPMS made their Mk12 5.56mm barrel to his specifications, and that it was originally custom ordered for him and some Navy SEALs he was training. Come to find out, William has the very first production model DPMS Mk12 rifle, and he's been getting 0.5 MOA from Mk262 77gr projectiles, and they're still penetrating 1/2" plywood boards at 900m!! He HIGHLY recommended that I look into the DPMS Mk12 18" barrel. At $179, it's a hell of a good price. I figured that since it's such a good deal and sub-MOA capable, I would have to give it a shot. So, I ordered one. DPMS said it'll be 30-60 days lead time to get one.
In the mean time, I sold my TA01 ACOG this week, so now I have $600 to fart around with. I'm most likely going to buy the EOTech XPS2-0 sight:
I considered the Vortex SPARC as a budget alternative. It's about the same size as the Aimpoint T1 Micro, but it only costs $199. I like Vortex's standards for great customer service and a lifetime warranty, but there's something about a $200 Chinese-made red dot collimator sight that just rubs me the wrong way. Ideally I'd like to get an Aimpoint T1 Micro, but those are so insanely expensive, it's disgusting. The cheapest I could find one was $579. Compare that to $440 for the EOTech.
I'm waiting on a large order from DPMS for parts for both rifles. The other problem is that Noveske is still out of stock of the 7.5" Diplomat barrels. I don't know when they'll get those back in. Hopefully soon. The EOTech is going on the PDW build.
As for the MK12 SPR build, I'm waiting for the Viper PST scopes to finally come out. Should only be a couple more weeks. I have a 4-16x on order right now for my M21A1 build, but I'm gonna have to pick up the 2.5-10x44 for the SPR build. Then, I'll mount it with my red dot sight on an ARMS #35 setup with a tactical ring cap to mount the dot. That, or I'll just do the LaRue Tactical SPR mount with J-point Side-mount option. Still to be decided.
Glock Armorer
Old 05-30-2010, 09:23 PM   #11
Rush4theYehO
My Ride: XI fts(now)
Reedo, there are the XPS-0 and the XPS-1....waht're the differences? I'd be picking between the Eotech micro or the Aimpoint Micro T-1/H-1.
Rush4theYehO is offline   Reply With Quote
Old 05-30-2010, 11:41 PM   #12
Reedo302
Reedo302's Avatar
XPS2 - non night vision compatible
XPS3 - night vision compatible
(first number indicates number of buttons on the back of the sight- third button being NV compatibility button)
-0 1moa center dot/65moa outer ring
-1 1moa center dot
-2 1moa center dot x2 for bullet drop/65moa outer ring
So XPS3-1 is NV compatible with 1moa center dot, while XPS2-0 is non-NV compatible with 1moa/65moa reticle.
I'm pretty sure I'm going to be getting the XPS. I want a bigger reticle. A simple 2moa reticle from an Aimpoint is very small, and I think it certainly lends itself to increased target acquisition times. There is also concern that with the Aimpoints, you need to have some close approximation of a cheek weld to the stock to make sure you can actually see the reticle. EOTech boasts that you can be off a bit more to different angles and still have visibility of the reticle with no parallax.
The XPS has solved a couple of problems that EOTechs have experienced or complaints that previous users have voiced. They're supposed to be the pinnacle of EOTech technology right now.
I have heard so many good things about Aimpoint T-1s, and I think it'd be a great investment. The H-1 is also a good option. The only differences are that the T-1 is Night vision compatible and is waterproof to 80ft, whereas the H-1 is not NV compatible and is waterproof to only 15ft, and it has white lettering on it. So, if you're not a Navy SEAL or Miami/Dade SWAT, the H-1 is the more reasonable alternative, with a cost differential of about $60 (H-1 being less). Both Aimpoints have a 50,000 hour life on a battery, which is really nice. The major advantage that Aimpoints have is their battery life.
In contrast, the XPS will go about 500-600 hours on the one battery. BUT, the EOTechs are a holographic sight that have a much different reticle that puts out a significantly higher amount of electricity, increasing the load on the battery. In contrast, the Aimpoints are collimator sights that have a very small electric load, basically allowing them to be left on permanently for 2,083 days (5.7years) without a battery change. Conversely, an EOTech would theoretically run out after only 25 days, should the 8hr auto-shutoff stop working.
It's all about preference. I know that if I get XPS, I'll most likely go get the Micro up the road for my next build (6.8SPC model).
Glock Armorer
Old 06-01-2010, 02:56 PM   #13
M3_Chris
My Ride: C63
Send a message via MSN to M3_Chris
I slapped on that exact EOTech on my LMT and love it. Ordered a LaRue mount and saving up some coin for a 3X Magnifier.
Ya battery life is short but to me I can prob afford to change a $5 battery every 6 months or so since I don't go to the range that often. So for a big reticle and shorter battery life I think thats a good compromise.
M3_Chris is offline   Reply With Quote
Old 06-01-2010, 04:47 PM   #14
Reedo302
Reedo302's Avatar
Is there a Larue mount that works for the XPS series? I didn't see any, and I want one.
As for the battery life and usage, what you said is exactly why I'm going with the XPS. I will probably run out a lot faster, as I tend to shoot more, but I'd rather make the sacrifice to get the larger and faster reticle. I also always have lots of CR123 batteries lying around, because I own so many lights that use them.
The 1MOA dot also lends itself to better long range accuracy, and since the optic is holographic, the reticle doesn't get bigger when you slap on the magnifier. That's a nice plus.
Glock Armorer
Old 06-01-2010, 04:50 PM   #15
CRZY BMW
CRZY BMW's Avatar
My Ride: has wings & a prop
I have the same grip... Love it!
http://forum.e46fanatics.com/attachment.php?attachmentid=309167&stc=1&d=1238667257
CRZY BMW is offline   Reply With Quote
Old 06-01-2010, 05:36 PM   #16
M3_Chris
My Ride: C63
Here is the LaRue EOTech QD Mount LT-110. The extra picatinny rail on the back gets your magnifier and XPS in perfect co-witness.
Old 06-01-2010, 06:12 PM   #17
Reedo302
Reedo302's Avatar
Oh snap. Sweetness.
Glock Armorer
Old 06-06-2010, 12:06 AM   #18
Reedo302
Reedo302's Avatar
Just got a couple Magpul B.A.D. Levers delivered. Installed one on my SPR build. Other one is still awaiting the PDW build.
By the way, these things are FANTASTIC!
Oh, and a recent check of my checking account shows that the BATFE has deposited my NFA payment check. Should be a couple more weeks at the most...hopefully.
Glock Armorer
Old 06-08-2010, 06:11 PM   #19
learthworml
mod-er-at-or-er
My Ride: 2011 Tundra Crewmax
Looks like it would work well, but I'd def have to get used to it.
mods
Kore Fox coilovers w/ 2.5" front lift , Fox Rear piggy backs w/ 1" rear lift, 305/65 18 BFG at/ko, TRD front Skid plate, console vault
SQ sound system
Seas Nextel Mids, Focal Utopia Mids, Focal BE tweeters, JL Audio 13tw5, Alpine PDX-4.150, Alpine PDX-1.600, Audison Bit One processor, Pioneer z150 hu
learthworml is offline   Reply With Quote
Old 06-09-2010, 10:34 AM   #20
Reedo302
Reedo302's Avatar
The DPMS and Magpul fairy visited me. Got some cool stuff in.
DPMS:
rifle length gas tube, A3 upper, barrel nuts, replacement pins, flash hider, ejection port cover assembly, oversized forward assist, mil-spec carbine receiver extension tube, BCM Gunfighter large charging handle, Badger Ordnance NAVSPEC Mk12 gas block.
MAGPUL:
New 30rd window PMAGs (4), 20rd PMAGS in FDE (4), ASAP plates (2), MS2 Sling in FDE, MOE rear stock (mil spec), Art of the Tactical Carbine DVD set, "Twinkie, Twinkie, Cupcake" t-shirt.
Glock Armorer
