Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 06-09-2010, 11:10 AM   #21
Serbonze
Master of his domain.
My Ride: My wife.
Serbonze is offline   Reply With Quote
Old 06-10-2010, 01:58 PM   #22
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
JP Enterprises adjustable trigger came in yesterday, and I just installed it on my Mk12 SPR. At $132, it's a great bargain. The components appear to be mil-spec quality, so they're pretty rugged. Compared to other single-stage triggers, this is a really good buy from what I can see. I'll have to do some testing with it for durability, but at first glance, I'd recommend it if you want a better trigger pull. The trigger down to around 3.5lbs, and I'm sure that on rapid fire engagement, I will be able to shoot a lot faster with this trigger. There is very little travel on it, which is always a good thing.
Reedo302 is offline   Reply With Quote
Old 06-15-2010, 11:25 PM   #23
Reedo302
Reedo302's Avatar
The VLTOR CASV-M forend came in today. Here's the mock-up of it with the stripped receiver. The 16" upper is there for comparison.
Old 06-17-2010, 10:48 AM   #24
Reedo302
Reedo302's Avatar
A couple new developments:
Mk12 SPR:
SLR15 Sully trigger guard
Magpul ASAP sling plate/MS2 sling
Magpul MIAD FDE grip
PDW:
Noveski 7.5" Diplomat barrel, 1:7PT rifling
Noveski KX3 flash suppressor
Noveski auto bolt carrier group
Old 06-20-2010, 07:34 PM   #25
Reedo302
Reedo302's Avatar
Alright, here's the first SPR mock-up. It'll be set to go once I get the 18" Mk12 barrel in. For now, it just retains the 16" carbine barrel.
I anticipate the scope coming in sometime within the next week or two. No clue how long it'll be for the barrel.
Old 06-20-2010, 09:16 PM   #26
CRZY BMW
CRZY BMW's Avatar
My Ride: has wings & a prop
Man that thing looks long!
CRZY BMW is offline   Reply With Quote
Old 06-20-2010, 10:44 PM   #27
Reedo302
Reedo302's Avatar
Yeah it does. I noticed that too. It's no longer than a normal 16" carbine, but the Troy 13.8" forend rail really makes it seem long. Kinda cool. Makes me wonder what it'll look like with the 18" on.
Old 06-22-2010, 09:56 PM   #28
Reedo302
Reedo302's Avatar
Okay, just a bit of a rant here, but I'm getting pissed off. 5 weeks and STILL nothing from the ATF. They cashed the check for the NFA stamp, I know that. But that was 3 weeks ago. Where's my stamp?!?! I did the Trust method, so theoretically, I should be getting this thing any day now... Theoretically.
Old 06-23-2010, 09:30 AM   #29
daedalus34r
My Ride: 2004 BMW 330i
Originally Posted by Reedo302 View Post
is that a desert camo skin.... or is that gun heavily used?? Looks cool regardless.
daedalus34r is offline   Reply With Quote
Old 06-23-2010, 09:58 AM   #30
Serbonze
My Ride: My wife.
You have fat hands.
Old 06-23-2010, 10:37 AM   #31
Reedo302
Reedo302's Avatar
The original gun was spray painted tan. Then I took off parts and the forend and grip are flat dark earth (FDE) colored. The black on the cheek rest is from excess wear from my face.
Originally Posted by Serbonze View Post
You have small fat hands.
Fixed. And yes, it's embarrassing. My wife is 5'2'' and her hands are the same size. That's why I can't shoot double-stack .45s.
Old 07-22-2010, 12:20 PM   #32
Reedo302
Reedo302's Avatar
Well, the Mk12 barrel came in this morning. I've already done a mock-up and now am waiting for the loctite to dry on the Mk12 gas block bottom screws. Once that's done, I'll finalize the build. Barrel is still black, though. I'm most likely going to paint it, but probably not until later tonight. Now I just have to wait for word on the scope, which is still backordered.
Note the gas block position, and how the gas tube and gas block stay completely protected
And finally, here's comparison of the barrel contours between the 18" Mk12 (top) and the 16" Carbine (bottom):
Old 07-22-2010, 01:44 PM   #33
Rush4theYehO
My Ride: XI fts(now)
Any response from ATF?
Rush4theYehO is offline   Reply With Quote
Old 07-22-2010, 01:47 PM   #34
CRZY BMW
CRZY BMW's Avatar
Nice gun, i'm just not a fan of sprayed guns... Unless I was in the desert and had a tactical advantage to doing it... but to each his own!
Old 07-22-2010, 03:34 PM   #35
Reedo302
Reedo302's Avatar
Not yet. I talked to a couple other guys who put in their Form 4 and Form 1 submissions around the same time I did. They said that there is a massive backlog right now and the ATF can't keep up. The Trust route used to take a month, but now it's going on two months with no sign of progress.
The main reason I paint many of my weapons is for weather resistance. Paint makes a good moisture barrier, and it's easier and cheaper than DuraCoat or Cerakote. It's also nice because it can be removed easily and repainted to different schemes for different environments, or just removed and left off. Also, I just really like the color tan. It really is a personal preference thing.
Most people really don't need to do it, though. I just shoot a lot in inclement weather and it's proven to be pretty effective against oxidation and corrosion resulting from precipitation, ambient moisture or barrel "sweating".
My next rifle will be a DMR/SDMR in 5.56 or another SBR/PDW-style in 6.8mm. At least one of those will wind up being black and green two-tone.
Old 07-22-2010, 04:19 PM   #36
learthworml
mod-er-at-or-er
My Ride: 2011 Tundra Crewmax
Send a message via AIM to learthworml
Nice!
mods:
Kore Fox coilovers w/ 2.5" front lift , Fox Rear piggy backs w/ 1" rear lift, 305/65 18 BFG at/ko, TRD front Skid plate, console vault w/ HK p30 cocked and locked
SQ sound system
Seas Excel Mids, Seas Titanium Tweeters, JL Audio clean sweep, JL Audio 13tw5, Alpine PDX-4.150, Alpine PDX-1.600, PPI DCX-730 processor
learthworml is offline   Reply With Quote
Old 09-20-2010, 02:09 PM   #37
Reedo302
Reedo302's Avatar
Got my NFA stamp on Saturday!
Here's the completed PDW, sans rear sight and Aimpoint T-1 Micro sight.
More Photos Here:
http://unastamuscombat.com/concept_weapons.html
Old 09-20-2010, 03:22 PM   #38
Parish_Rane
My Ride: '02 330xi
Completely dense question. How did you get the 7.5" barrel? Here in CO it's 16" minimum.
** That was beyond annoying **
Originally Posted by Allure View Post
Fuk banks, who invented them? Useless sh!t, that's all I can say. I always deal with cash, with real money, not some numbers in a computer.
Parish_Rane is offline   Reply With Quote
Old 09-20-2010, 03:46 PM   #39
Serbonze
My Ride: My wife.
Congrats on the NFA! What was the total wait time?
Old 09-20-2010, 03:55 PM   #40
6-speed
My Ride: E21 > E46
that thing is cute!
XboxLive- EmployedZebra
Originally Posted by Stephen Zawistowski (VP of ASPCA)
"A pit bull is like a Porsche. It's a finely tuned, highly muscled athlete, and just like you wouldn't give a Porsche to a 16-year-old, you don't want just anyone to own a pit bull. It should be someone who has experience with dogs and is willing to spend the time, because with training and proper socialization you will get the most out of them as pets."
6-speed is offline   Reply With Quote
