Sponsored by The Tire Rack
Old 05-13-2010, 12:49 AM   #1
zemperaye
My Ride: e46 M3 04/04
need advice on rear camber....
Hey guys. I just mounted my BBS LM. The rears have the reverse center mounted. I believe the original 19 X 10 offset is et25, and with the reverse center mounted, the offset is more aggressive obviously. Im currently on TC klines, about 13.0 inch drop in the rear, -2 camber AND a fender roll.
I dont really want to raise it, but will if need be, but was wanting to know if I can dial in some more camber to help out with the rubbing, but still maintain street use/street tire wear. I have stock arms so not sure how much more camber I can get. Any advice??? Thanks.
zemperaye is offline   Reply With Quote
Old 05-13-2010, 12:20 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Stock arms can adjust camber up to a point. I believe up to -2.5 in the rear.
As long as your toe is within spec, then -2.0 is not a problem at all.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-13-2010, 02:12 PM   #3
Penguin Koolaid
Banned
My Ride: Inline Six
-2.0 in the rear is not a problem. (I was under impression that's what the non-M e46's with sport package run standard ) so increasing the negative camber slightly shouldn't be a problem as well. The tire wear characteristics change slightly, but you're still within safe limits.
Penguin Koolaid is offline   Reply With Quote
Old 05-13-2010, 04:26 PM   #4
zemperaye
So -2.5 is the furthest in I can go with stock arms? would -3 be out of the question, and if possible, would that be ok for street use?
Old 05-13-2010, 05:39 PM   #5
be-doubleyou
My Ride: 02 325ci
I was able to run -3 from the stock camber setting.
I have a non-m but aftermarket camber arms are interchangeable with M's and non-M's, so the amount of camber adjustment between the two stock setups should be similar.
Bill
be-doubleyou is offline   Reply With Quote
Old 05-13-2010, 06:01 PM   #6
tinkwithanr
My Ride: '00 323i + '75 2002
Am I the only one that's impressed he's running a 13" drop??
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 05-13-2010, 06:31 PM   #7
zemperaye
13.0" center to fender. sorry.
Old 05-13-2010, 06:39 PM   #8
ChasCan
My Ride: 2001 330xi
-3 deg is heavy camber for the rear unless you're tracking your car. -2 deg is OK for street as long as the toe is in spec. Chas
ChasCan is offline   Reply With Quote
Old 05-13-2010, 07:53 PM   #9
tmb 02
My Ride: 02 330i, 06 gto
my first thought as well
tmb 02 is offline   Reply With Quote
Old 05-13-2010, 08:02 PM   #10
nk_zhp
My Ride: ZHP / E30 M3
Even for the track -3 is heavy IMO.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
