Old 05-13-2010, 03:02 AM   #1
khbiesfd
My Ride: 2000 BMW 323ci
lightweight flywheel
Im currently in the market for an aftermarket flywheel. I just have one simple question- are there any disadvantages to having one versus a stock unit?
khbiesfd is offline   Reply With Quote
Old 05-13-2010, 07:25 AM   #2
tinkwithanr
My Ride: '00 323i + '75 2002
This has been covered a bunch already..
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 05-13-2010, 04:00 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
You might accidentally spin your tires through first. Sucks.
A little noise, but well worth it.
Old 05-13-2010, 08:47 PM   #4
davematuska
My Ride: 2005 330i ZHP -Imola
IC engines produce power in pulses each time a cylinder fires. These pulses are very close together at RPMs above 1000 or so. Below that, when you are at idle, the pulses can be heard. The heavy stock fly wheel absorbs these pulses. Lighter fly wheels absorb it to a smaller degree. It sounds like chatter when you are sitting at a stop light. You can make it go away by pressing the clutch or bringing the revs up to 1000 or so.
davematuska is offline   Reply With Quote
Old 05-13-2010, 09:09 PM   #5
xixixi
Banned User
My Ride: 01 330x-xi
i've noticed after my ltw wheels mod i spin more??? than with the ltw flywheel just another opinion. for awd that is not rwd
Old 05-13-2010, 10:11 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
I have both and I was being sarcastic.
Old 05-13-2010, 10:21 PM   #7
xixixi
Banned User
My Ride: 01 330x-xi
damn net no way to read sarcasm... what do your wheels weigh?
Old 05-13-2010, 11:07 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
http://forum.e46fanatics.com/showthread.php?t=679996
Old 05-14-2010, 01:24 AM   #9
xixixi
Banned User
My Ride: 01 330x-xi
nice wheels gd son 16lb! 18.6lbs for 18x8.5 you got 17x9s
Old 05-30-2010, 12:07 AM   #10
khbiesfd
so will the wheels spin all the time or just if your not used to it. and also will i be better off getting a good name brand one, or just fidanza or the likes. And also which is better steel or aluminum.
Old 06-01-2010, 09:19 AM   #11
khbiesfd
Old 06-01-2010, 10:37 AM   #12
aggieE46
Keep it clean
aggieE46's Avatar
No, your wheels won't spin all the time. Do some research. Check UUC's site, they have a TON of information on the product. The UUC is a Fidanza.
