Old 05-13-2010, 03:24 PM   #1
iDriftYou
My Ride: is a HighWay monster
Broke a Strut tower bolt
So me and my buddy just got finished installing his OEM springs in. I was using a torque wrench for the top bolts and had it set at 21 ft lbs. As i was tightening, one of the studs just ripped off. The wrench did not click! I felt like such a dumbass for breaking a god damn stud. My question to you guys is, I just need to replace to top hat right? I also read by drilling the stud out, and getting a bolt of the same size, poking it through and tightening it, it will work ( a lot of other car forums use that as another option to fix it). Is driving on 2 studs fine for now? He drives on the highway, nothing more. And can I just drill the stud out and replace it with a bolt? Thanks again fanatics.
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 05-13-2010, 03:41 PM   #2
paraklas
My Ride: ESS TS2 320ci
If you manage to hold the bolt not to turn while tightening
Old 05-13-2010, 03:44 PM   #3
iDriftYou
People say apply JB weld with a washer and I should be good?
-Shehroz
Future: GT35r
My DIY:
Old 05-13-2010, 04:08 PM   #4
paraklas
If it holds enough to properly torque the bolt I don't see why not
Old 05-13-2010, 04:09 PM   #5
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
not hard to replace the strut towers, plus, they wear over time anyway. Just replace it
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 05-13-2010, 04:11 PM   #6
iDriftYou
At 92$ for each side, can't afford them right now.
-Shehroz
Future: GT35r
My DIY:
Old 05-13-2010, 04:14 PM   #7
paraklas
I think he means strut tower bearing, it's around $20 each?
Old 05-13-2010, 04:18 PM   #8
330ciandr6
My Ride: .
no, upper strut mount
Old 05-13-2010, 05:38 PM   #9
fotsir
My Ride: 2004 Lexus IS300
If you can't afford it then do the bolt, but in the long term it's a bad idea. Save up and buy a mount when you can.
fotsir is offline   Reply With Quote
Old 05-13-2010, 05:49 PM   #10
Chibo
My Ride: Nothing
JBWeld won't really hold torque, been there, tried that. You can take it to a muffler shop and have a nut tack welded on for like $5 though.
It'd be like...
Bolt - Nut tackwelded onto bottom of tower - tower - rough road plate (if you have one) - body - nut
2005 330i ZHP Sedan (Street/Track)
2003 Yamaha R6 (Track/Race)
2007 Aprilia Tuono 1000 (Street/Track)
Chibo is offline   Reply With Quote
broke, strut, stud, wtf
