Skip shifts? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-22-2013, 12:57 PM   #1
NyC35AV
My Ride: 99' 323i ZSP/S52 E34
Skip shifts?
Usually now I've gotten into the habbit of skipping gears whenever I shift (i.e 1-3-5). I usually try and rev match it to the next gear the best I can as to not put too much wear on the clutch. I've gotten lazy to the point where I don't want to go thru every gear here in the city and my thinking is I save a bit of gas too.
Am I doing any damge to synchro's or accelerating wear to any other parts?
NyC35AV is offline   Reply With Quote
Old 10-22-2013, 01:49 PM   #2
foo-fighter69
My Ride: 1997 ///M3
Hope some one sheds some light on this,but I do this all time and never really thought anything of it.
2001 325i 5 MT, ZSP (sold and missed)
1997 ///M3 5 MT Luxary package
foo-fighter69 is offline   Reply With Quote
Old 10-22-2013, 01:51 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Meh I do it sometimes, mostly getting on the highway.
Old 10-22-2013, 01:53 PM   #4
Llink78
My Ride: 2002 330i
City driving the speed limit is unually 35. I go 1st 2nd 4th. Iv been doing that for the last year. No I'll affects.
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 10-22-2013, 01:56 PM   #5
ANREC330
My Ride: C6 Vette & M3
Skip shifts?
Only damage you could cause is if you Lug the engine.
Skipping shifts are fine. I skip from 1st to 4th in the corvette when I'm feeling lazy.
ANREC330 is offline   Reply With Quote
Old 10-22-2013, 02:01 PM   #6
golf_234
My Ride: E46, E90
Have been doing this a lot too haha 1-3-5
golf_234 is offline   Reply With Quote
Old 10-22-2013, 02:06 PM   #7
cityjohn
My Ride: 2001 M3
You just took the S out of S-M-G
cityjohn is offline   Reply With Quote
Old 10-22-2013, 02:07 PM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
what do you mean rev match? rev match upshift?
Old 10-22-2013, 02:13 PM   #9
golf_234
My Ride: E46, E90
Rev match up or down. You can rev match either direction.
i.e. Got the car going up to 40mph in first, at say 4000 rpm, release, drop down to say 3500 rpm and drop into second. Seamless, smooth shift.
Old 10-22-2013, 02:19 PM   #10
cityjohn
My Ride: 2001 M3
Wouldn't you be closer to 6000?
Old 10-22-2013, 02:24 PM   #11
NyC35AV
Yes, I've seen some corvette's that will lock the gates so you have to go from 1-4 as a gas saving feature.
Also you can rev match your upshifts for smooth shifting, if you get it spot on you don't even need to clutch, although I have heard that, that will wear your synchros.
Old 10-22-2013, 02:31 PM   #12
breadvanracing
My Ride: E46 328Ci, Z3 MC
I don't skip on the upshift, but I do on the downshift. 5-3, 5-2, 4-2. On a 4-2 I actually put it through third, then into second without releasing the clutch, not for any reason, just something I've always done.
I grew up in England, pretty sure if you skipped an upshift you'd fail. Block downshifting was allowed though.
breadvanracing is offline   Reply With Quote
Old 10-22-2013, 02:32 PM   #13
Sedan Hussein
My Ride: e46
e46s dont have enough torque to skip shifts. But yes, i do it as well.
Sedan Hussein is offline   Reply With Quote
Old 10-22-2013, 02:38 PM   #14
golf_234
My Ride: E46, E90
Probably haha. My numbers weren't very good here.
Old 10-22-2013, 02:41 PM   #15
sunsetcoast
My Ride: '99 323i & '00 323iT
As long as there is no lugging, you will be fine. Matching revs helps quite a bit. May not actually save gas. In the city, though, I'd be more concerned about not being in the "right" gear (torque band) in an emergency situation.
I often skip shift, but it is generally on lightly-travelled roads rather than in traffic.
sunsetcoast is offline   Reply With Quote
Old 10-22-2013, 02:44 PM   #16
ApolloTheGod
My Ride: E92, E46, E36, Caddy
I have a really interesting way of driving my stick because I am trying to promote longevity for it and it dosnt help that I have straight cut gears.
I shift 1st gear at 20 mph, 2nd at 30, 3rd at 40, and if I am cruising under 55 MPH i always keep it in 4th gear. Any speeds above 55 to about 80 its in 5th gear and I only go into 6th whenever I go above 100
Sometimes I skip 1st and start in 2nd and go straight to 4th. Just depends on driving style at the time
I know that at 40 mph in 2nd gear I am at 4500 RPMs with an 8k redline so when I shift to 4th from 2nd it falls to about 2100 rpms so I just put in the clutch and just as its about to hit 2100 rpms I let it out and it catches perfectly. Sometimes I will miss it and revmatch up again. Like I said, just depends on style
ApolloTheGod is offline   Reply With Quote
Old 10-22-2013, 02:46 PM   #17
My Ride: Lexus
I skip 1 to 3 to 5 all the time. plenty torque. I can even take off in second gear
Old 10-22-2013, 02:51 PM   #18
golf_234
My Ride: E46, E90
+1. I am sure the ratios are different, and obviously vastly different mechanics, But in the same idea, that is what the automatics do as well depending on driving style. (Start in 1st or second)
Old 10-22-2013, 02:56 PM   #19
tks
My Ride: slower than yours
Skip shifts?
I usually redline second and then go into fifth gear and start cruising.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 10-22-2013, 02:57 PM   #20
Sedan Hussein
My Ride: e46
straight cut gears in what? the 335?
3->5 isnt too bad. 2nd gear start is too bogged for my taste.
I came from a mustang.
