Sponsored by The Tire Rack
Old 05-23-2002, 02:17 AM   #1
///Mike GmbH
My Ride: 01 330Ci
Mmm....It's time to order new tires!
Planning to get S0-3's in 225/40/18 & 255/35/18
Please post feedback about this setup.Thanks, oic, BTW, those wheels are 18x8.5
///Mike GmbH is offline   Reply With Quote
Old 05-23-2002, 02:18 AM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
nice, but I'd recommend 235/40 up front
Clem is offline   Reply With Quote
Old 05-23-2002, 02:22 AM   #3
///Mike GmbH
My Ride: 01 330Ci
Clem, Can you help me answer a question? My car is lowered with H&R Cup Kit, I was told if I run 255/35/18 in the rear, I might have to roll my fender, is that true?
Old 05-23-2002, 02:33 AM   #4
Clem
Alpha Male
Clem's Avatar
It's possible but I can't say for sure.
When E46s are lowered they produce negative camber in the rear as there is no rear camber adjustment unless you get adjustible rear control arms. Essentially from behind, your tires look like this:
/_/ \_\
That said, enough negative camber maybe produced that you won't need to roll your fenders. But with 255s they maybe be wide enough that you will have to roll them.
Personally I'd roll them anyways just to be on the safe side. But that's just me.
Old 05-23-2002, 11:29 AM   #5
roz121xi
My Ride: 330xi
are those replicas? if so, where'd ya get em?
2002 330xi
roz121xi is offline   Reply With Quote
Old 05-24-2002, 12:51 AM   #6
Chase265
Suck it easy.............
My Ride: A BIG POS
Send a message via AIM to Chase265
you won't have to roll your fenders with that setup, I am running the same setup, no problems at all
Chase265 is offline   Reply With Quote
Old 05-24-2002, 02:25 AM   #7
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
depends on the drop in the rear and if it's a sedan or coupe. AllenYad had rubbing with 255s on 18s when he had UUC springs on his sedan. Camber and offset and everything else have an impact on this. You might as well roll to be sure.
And yeah, 225 up front on an 8.5 is less than ideal, too stretched, get 235s.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
