Old 11-01-2010, 09:18 PM   #201
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Originally Posted by bigjae1976 View Post
Got it, thanks. So we send 50% now? Also, I would like to purchase the ATI damper install tool...can we tack that onto the order?
I will add that to the Part 2 of the Payment
Originally Posted by HighBoostin330 View Post
I am super busy for the next two weeks. No time to take apart my car.
Same here. I will be a SEMA and trying to get new stuff for us guys.
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 11-01-2010, 11:28 PM   #202
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Just wanna make sure...that is a yes? What is the additional cost?...not like that REALLY matters at this point.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-02-2010, 01:32 AM   #203
BimmerBrakes
The Brake Newbie!
I will have to Find out from ATI.
Old 11-02-2010, 05:26 PM   #204
Jackcat559
My Ride: 2003 530
I can also rent out the ATI install tool, adapter, high temp lube, and OE damper removal tool. Repalcement deposit, minus shipping and $50 upon safe return
Drop down 1/2 way through the page
http://forums.bimmerforums.com/forum...220347&page=17
Jackcat559 is offline   Reply With Quote
Old 11-02-2010, 07:26 PM   #205
bigjae1976
bigjae1976's Avatar
Thanks...I will need to rent some OE removal tools. I would like to just buy the ATI install tool for if/when I need to remove the ATI unit.
Old 11-02-2010, 07:55 PM   #206
Jackcat559
My Ride: 2003 530
The removal tool set and adapter run $185
Old 11-02-2010, 08:07 PM   #207
AL330CI
My Ride: 330Ci
Can ATI make the snout fit correctly based on the average of a few measurements (i.e. Adam & McSpeed so far)? Although I can finally fit this damper into my budget, I don't have the tools/facility/time to measure mine. If anyone else measured their snout, please post your measurement here. As I have mentioned before, the difference betwen the two measured snouts so far is 0.0007". Is this large enough of a difference to require custom measurement for everyone?
AL330CI is offline   Reply With Quote
Old 11-02-2010, 08:09 PM   #208
Jackcat559
My Ride: 2003 530
Mine was x.xxx5
I've been inside their offices, and they hold 10 US patents for their work
Old 11-02-2010, 08:14 PM   #209
quacktoduck
My Ride: e39
yeah i was thinking the same for the measurment... hey jackcat559 nice to see another e39er here... lols
quacktoduck is offline   Reply With Quote
Old 11-02-2010, 08:19 PM   #210
Jackcat559
My Ride: 2003 530
gotta use all the resources
Old 11-02-2010, 09:55 PM   #211
McSpeed
My Ride: 2005 ZHP TT Stg 1
Here's another measurement from the first thread:
Originally Posted by F1004fun View Post
The interference fit is .0008"-.0011"
Pie330 - My crank snout measured out to 1.2590" on the dot.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-04-2010, 02:01 AM   #212
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
All,
I'm going to measure my crank on the actual engine I'll be putting this on. The variance is too great in my opinion.
A big part of how this damper works is in having a good coupling with the crank shaft. The damper is targeting 2nd/3rd/4th order harmonics, which are higher frequency and requires a solid coupling with the crankshaft to be most effective.
Brady/Anthony,
People like myself are going to take at least another 3-4 weeks to get this measurement to you. I would advise talking to ATI about getting the general machining going on the dampers to speed things up, and then adding the measurements at a later date. It's the final honing that this measurement is relavant for, and they have a lot of work to do before this....
Sorry for the holdup on the measurement, but I am really busy.
Old 11-04-2010, 05:59 AM   #213
bigjae1976
bigjae1976's Avatar
That's for the ATI adaptor?
Old 11-04-2010, 07:12 AM   #214
McSpeed
The thread adaptor was $50 and the tool $144 when I got them so it sounds like there's a little discount action going on. Note that about a quarter inch of the pointy end of the tool had to be dremelled off for it to clear my radiator - so it's not perfect, and it includes a bunch of adaptors and screws that aren't used in this application - thus there may be a more suitable and less expensive tool out there if someone feels like looking.
Old 11-09-2010, 01:46 PM   #215
BimmerBrakes
The Brake Newbie!
*Updated*
I know some of you guys are tight on Money and Like to Hold out alittle while. That is fine as-long the other people on the GB is OK with it.
1. aggieE46
2. bluejeansonfire (Payment 1 of 2 Sent)
3. HighBoostin330
4. Zerosum
5. trippinbimmer
6. gte869h
7. quacktoduck
8. bigjae1976
9. PEI330Ci (Payment 1 of 2 Sent)
10.
I will be sending a mass email tonight to let you guys know the details and how we can get this GB done.
Old 11-09-2010, 02:09 PM   #216
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I should have it pretty soon.
Old 11-09-2010, 06:35 PM   #217
bigjae1976
bigjae1976's Avatar
So how much is the first installment?
Old 11-09-2010, 07:21 PM   #218
aggieE46
Keep it clean
aggieE46's Avatar
Should be $275, half of $550.
Anthony should have sent you an email. PM him if you didn't get it.
Old 11-17-2010, 06:44 AM   #219
bigjae1976
bigjae1976's Avatar
Who's paid so far? I guess I'm just dragging my feet. I've never been so unexcited about a mod...
Promise I will pay the deposit by the end of the week.
Old 11-17-2010, 07:21 AM   #220
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Don't worry....I'll start sending hatemail to those that haven't paid up soon.
