Old 12-06-2010, 01:10 AM   #241
sgplayer69
My Ride: 2003 CB M3 Coupe
lol I'm still so confused about the Damper, I guess I don't know enough car lingo to understand the benefits
Coming Soon...?
sgplayer69 is offline   Reply With Quote
Old 12-06-2010, 08:21 AM   #242
TxZHP04
My Ride: ESS TS2+ ZHP
Read this:
http://www.atiracing.com/products/dampers/101/index.htm
Old 12-06-2010, 08:36 AM   #243
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by bigjae1976 View Post
I've added measurements to the list. Ladies...do note that my snout is thicker than PEI330Ci's!
1. aggieE46
2. bluejeansonfire (Payment 1 of 2 Sent)
3. HighBoostin330
4. Zerosum (Payment 1 of 2 Sent)
5. TrippinBimmer (Payment 1 of 2 Sent)
6. gte869h
7. quacktoduck
8. bigjae1976 (Payment 1 of 2 Sent) 1.2590"
9. PEI330Ci (Payment 1 of 2 Sent) 1.2585"
10. AL330CI (Payment 1 of 2 Sent)
I've got 4 M54B30 cranks at the shop so I measured them all:
#1: 1.2585
#2: 1.2600
#3: 1.2595
#4: 1.2590
And when I removed the damper off the 330i street car, I literally pulled the damper off with my hands. It was pretty easy once I got that darn bolt off....
Old 12-06-2010, 08:55 AM   #244
McSpeed
My Ride: 2005 ZHP TT Stg 1
#1: 1.2585
#2: 1.2600
#3: 1.2595
#4: 1.2590
whew- that's a spread! .0015" variance.......there goes the hope of a one size fits all Super Damper.
my stock damper slipped off easily too
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-06-2010, 12:37 PM   #245
Jackcat559
My Ride: 2003 530
same here
Jackcat559 is offline   Reply With Quote
Old 12-06-2010, 10:08 PM   #246
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Should we mention if we have an aftermarket lightweight flywheel when ordering this?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-07-2010, 09:36 AM   #247
McSpeed
nah- the damper's job is the same regardless of flywheel or any mod unless the redline is going to be over 7500 or your power way way up there- then you'd want one like Adam's that displaces most accessory pullies
Old 12-07-2010, 11:01 PM   #248
bigjae1976
bigjae1976's Avatar
Cool.
Anthony@Bimmerbrakes...definitely want the threaded install adaptor. Let me know how much more I need to send with my final payment. Thanks!
Old 12-09-2010, 02:57 PM   #249
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Cool.
I will put a note and let you know when final payment is due. Let's get this on a roll guys. Only a few more people left and we can get this started.
Anthony@BimmerBrakes
Sent from my iPhone using BimmerApp
BimmerBrakes is offline   Reply With Quote
Old 12-16-2010, 09:17 AM   #250
ZeroSum
My Ride: 05 325
Come on guys lets keep this going... before your oil pump nuts fall off
ZeroSum is offline   Reply With Quote
Old 12-21-2010, 09:30 PM   #251
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
+my oil pumps (yes, plural failures)
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 12-21-2010, 10:07 PM   #252
BimmerBrakes
The Brake Newbie!
X2
Guys, Lets get this on a Roll. At-least send your First Deposit so I can get the Order going.
-Anthony@BimmerBrakes
Old 12-22-2010, 08:43 AM   #253
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
If I don't have to buy a new MAF I'll have this pretty shortly. Just a bad few months for trying to buy car stuff!
Old 12-22-2010, 10:18 AM   #254
bigjae1976
bigjae1976's Avatar
Hyundai Sonata 2.5l MAF FTW!...less than $100.
Old 12-22-2010, 11:48 AM   #255
aggieE46
Keep it clean
aggieE46's Avatar
That'll work for my 12/02 build date?
Just searched, looks like it's only for 323, 325, 328s. Thanks for getting my hopes up!!!
Old 12-22-2010, 01:09 PM   #256
bluejeansonfire
ninja editor
My Ride: m5xual
i have a maf sitting around, let me know if you need it
Old 12-22-2010, 05:38 PM   #257
bigjae1976
bigjae1976's Avatar
Check the Siemens part # on the MAF
Pulled my MAF, its got 6 wires and the siemens part # is 5WK9 642. The Hyundai Sonata has a 5WK9 643.
Old 12-23-2010, 02:20 PM   #258
bluejeansonfire
ninja editor
My Ride: m5xual
remember that ms43 and ms45 use different mafs
Old 12-23-2010, 05:59 PM   #259
AL330CI
My Ride: 330Ci
The MS45 MAF unit has the intake air temperature built in. Okay, let's get this back on topic.
AL330CI is offline   Reply With Quote
Old 12-23-2010, 08:00 PM   #260
bigjae1976
bigjae1976's Avatar
Don't the pre-03/03 330's use the MS43 DME thus have the same MAF as every other non-M E46? So it should be able to use the Hyundai MAF.
Not totally off topic...if we help Brady save a couple of bucks on a MAF then he'll have more for the damper!
But...here's a repost of the last list. Not sure who the gte869h and quacktoduck guys are?
1. aggieE46
3. HighBoostin330
6. gte869h
7. quacktoduck
