Old 02-02-2012, 08:16 PM   #721
secono330ci
My Ride: 04' 330ci/15' A3 TDI
I'm down for a group buy number two. I'll send deposit tonight.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 02-03-2012, 10:26 AM   #722
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Originally Posted by Rob43 View Post
Get your cat to do it ? ! ?
He is in trouble and sitting in timeout. The little bastard triggered the motion sensor in the garage and the police were dispatched to the house. Of course there was no break in and the police department fined me for the false alarm.
Apparently he loves to jump on top of the bimmers and wave at the motion sensor.
sent from HTC EVO
Old 02-03-2012, 02:18 PM   #723
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
sent from HTC EVO
Man, that's a "cat"astrophe !
SUMMIT POINT WV 1:24:229 SCCA
Old 02-03-2012, 02:28 PM   #724
darksideracer69
My Ride: 01 325ci
:screwy:
Sent from my SGH-T959V
IMAG02051
Old 02-03-2012, 07:21 PM   #725
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
LOL at the few last comments.
BimmerBrakes is offline   Reply With Quote
Old 02-03-2012, 07:27 PM   #726
jblack03zhp
My Ride: 330i zhp
Im down for GBpt2
Sent from my DROIDX using Bimmer App
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
Old 02-05-2012, 01:53 PM   #727
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
has anyone used a 5 rib pulley with a 4 ribbed belt?
/_________\
O==[][]==O
Old 02-05-2012, 04:42 PM   #728
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Julio has.
Old 02-06-2012, 02:32 PM   #729
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Tested mine at the track this weekend. Definitely notice that the engine is smoother near redline. There is still some harshness above 6k but significantly less. So hopefully this helps reduce the likelihood of the oil pump nut backing off...now if I can only stop spinning the car.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-07-2012, 05:44 PM   #730
330i ZHP
330i ZHP's Avatar
great news on my end - I pulled the pan on the TS3 engine and the oil pump nut was very tight
I removed the windedge pan and checked the cyl walls - everything looks great - front and rear main seals in great shape and there dont seem to be any leaks on the bottom end
cams look good - the only reason I opened the top end - my vanos has been off so many times the I stripped a stud awhile ago and it has been a slow leak - driving me nuts - so fixing that before getting it ready for going into wagon
/_________\
O==[][]==O
Old 02-08-2012, 09:36 AM   #731
SweTurbo
Big Pimpin'
My Ride: 323i -98
Im in for groupbuy#2 aswell , send me a PM when its time
Old 02-08-2012, 11:57 AM   #732
Steven747
My Ride: 05 330ci
in for group buy number 2 just need someone to install it for me.
i want to do ati damper uuc stage 1 clutch my vanos seals and cdv delete at the same time.
Old 02-08-2012, 06:30 PM   #733
TrippinBimmer
My Ride: Just Fast!
Alot of talk here...Any ACTIONS?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-08-2012, 06:45 PM   #734
Rob43
Rob43's Avatar
Exactly.
Old 02-11-2012, 10:07 AM   #735
bigjae1976
bigjae1976's Avatar
Yup...money talks bullsh1t walks. Kind of how the first group buy started out.
Old 02-11-2012, 03:12 PM   #736
SoloII///M
My Ride: Many
Just wait until VAC gets set up and ready to sell these for the M54. Then try to do a group buy with them. It will be much easier.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 02-11-2012, 06:51 PM   #737
Steven747
My Ride: 05 330ci
not sure if i can perform an action because there isisnt a group by and i didn't have a chance at the last one
Old 02-12-2012, 12:00 AM   #738
bigjae1976
bigjae1976's Avatar
Someone just needs to talk to ATI, collect the money and specs, send to ATI, receive the dampers and mail them out.
Old 02-12-2012, 12:14 AM   #739
PawnStar
My Ride: 330ci
i'm willing to jump in on group buy #2, just not actively on the forum enough to take control
PawnStar is offline   Reply With Quote
Old 02-14-2012, 09:49 AM   #740
PawnStar
My Ride: 330ci
Should we start to say how many people will actually put deposit down for group buy #2?
1. PawnStar
