Old 10-16-2012, 10:49 AM   #881
Steven747
My Ride: 05 330ci
Originally Posted by bigjae1976 View Post
I'm going to buy Anthony's and then break it. In fact, I'm going to buy them all and break them all so no one can have an ATI damper...
heheh
not mine
Old 10-16-2012, 11:47 AM   #882
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Originally Posted by Steven747 View Post
heheh
not mine
I want it!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-16-2012, 11:04 PM   #883
secono330ci
My Ride: 04' 330ci/15' A3 TDI
nooooo
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-17-2013, 04:55 PM   #884
TrippinBimmer
My Ride: Just Fast!
Anyone looking for one?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-17-2013, 05:19 PM   #885
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
I am glad I saw this thread but I remember someone on here that got their nut loose even after the ATI Damper install and the custom oil sump pump from that one member.
does anyone else remember this or am I crazy?
Old 01-17-2013, 05:30 PM   #886
SoloII///M
My Ride: Many
It can still happen if you rev the motor too high.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 01-17-2013, 09:16 PM   #887
da Vinci
My Ride: 2003 BMW 330i ZHP
I am interested.
Click here for my Build Thread
"Make everything as simple as possible, but not simpler." Albert Einstein
da Vinci is offline   Reply With Quote
Old 01-19-2013, 07:47 AM   #888
bigjae1976
bigjae1976's Avatar
Was it me? I had the ATI damper and lost the oil pump nut. Don't think that this damper solves your problems although it helps.
Old 01-19-2013, 08:29 AM   #889
flashmeow
Banned User
I dont remember but I was really shocked when I saw the post. did you also hav Greg's special customized oil pump assembly installed
Old 01-19-2013, 08:41 AM   #890
da Vinci
Do you have your redline raised? If so, to what RPM?
Old 01-19-2013, 08:57 AM   #891
flashmeow
Banned User
this is really bugging me. I think I saw the post as part of someone engine build. the failure was posted with pix but it was just a one liner. my memory might be off but I think what made this failure stood out was that the person had the Ati Damper + Greg pump. Again, I can be wrong and probably just confusing VAC pump failure from Pei330 build.
i spent 30 mins looking for that thread. I knew I should have bookmarked it
Old 01-19-2013, 07:58 PM   #892
bigjae1976
bigjae1976's Avatar
No.
7000 rpm. Didn't spend a lot of time there.
There is an inherent issue with the engine that CANNOT be solved unless you rebuild the engine. The oil pump, damper, S54 tensioner, zip ties, and duct tape are all band aids. They help but the problem is still there. If that keeps you up at night, sell the car.
Old 01-19-2013, 08:47 PM   #893
Steven747
My Ride: 05 330ci
No.
So would the BMW Motorsport pump solve all opn issues if it was more affordable and a new spaced oil pan was made
Old 01-19-2013, 10:51 PM   #894
bigjae1976
bigjae1976's Avatar
Don't think so. A couple of sources agree that the harmonic issue is inherent to the rotating assembly. So bolting stuff on doesn't fix that. The best solution is to carefully balance and match the rotating assembly with lightweight components (pistons and rods) to minimize harmonic issues. Then add the 4 bolt pump as insurance.
The damper and aftermarket flywheels? Haven't really gotten to that part yet.
Realistically, only those cars seeing extreme service demands should really need to deal with this issue sooner than later. Street driven cars (even ones driven aggressively) don't see the sustained loading and unloading that a track driven cars see. I think my s/c'd 330 may be one of the most abused engines on this forum because it sees a lot of track use so I need to address this. Most, I wouldn't bother.
Old 01-19-2013, 11:38 PM   #895
Steven747
My Ride: 05 330ci
thanks
Old 01-20-2013, 07:36 AM   #896
SoloII///M
My Ride: Many
I think a lot of it has to do with the aluminum block. It is not as stiff as the S series iron blocks so is more likely to propagate harmonics.
One of the worst things you can do is bang the motor off the rev limiter. Ours is set to 6900 and we do hit it but we try not to ride it.
Retaining the stock flywheel and adding a damper are two things that will mitigate the harmonic problems but they aren't a 100% solution.
John V
Old 01-20-2013, 07:49 AM   #897
Steven747
My Ride: 05 330ci
really thinking about putting in a lwfw for the performance benefits but dont plan on sitting high for very long either
Old 01-20-2013, 10:16 AM   #898
TerraPhantm
My Ride: M3 & ZHP
S52 was an iron block and plenty of them have the OPN issue. Same crank as the M54B30. I don't think aluminum is the problem.
Old 01-21-2013, 10:28 PM   #899
TrippinBimmer
My Ride: Just Fast!
Dry slump FTW
Alpine White M3
MaximumPSI Stage4
Old 01-22-2013, 04:58 AM   #900
SoloII///M
My Ride: Many
They have OPN issues when people over-rev them.
John V
