Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 4.80 average. Display Modes
Old 06-16-2013, 03:14 PM   #341
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
And yes, I did start the engine:
Old 06-16-2013, 03:55 PM   #342
mkodama
mkodama's Avatar
Cool pictures and good progress as always!
-Welding stainless to mild steel shouldn't be a problem, IF you use the correct filler material and technique. 309L filler rod is normally the filler rod of choice when welding stainless to mild steel. Using mild steel filler rod on stainless, or certain types of stainless filler rods on mild steel, causes dilution of the chromium and results in a brittle weld(usually resulting in a small crack), while 309L has extra high chromium to reduce this.
-For the thickness of that tubing and size of that fitting, the weld looks a little too big and too hot. Excessive heat leads to greater stresses and chance of cracking and warping. Too hot of a weld also pulls in more contaminants, especially from the back side of the weld.
Old 06-16-2013, 04:04 PM   #343
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Man that sounds wicked. Congrats.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is online now   Reply With Quote
Old 06-16-2013, 04:17 PM   #344
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Re: Technique Tuning Stage 1 Turbo on an automatic
Nice work Adam
Sent from my SGH-T889 using BimmerApp mobile app
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 06-16-2013, 04:31 PM   #345
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Houston...we have lift-off!
Old 06-16-2013, 05:02 PM   #346
STORMER
My Ride: AA SC 98 M3
Wow. Project of years. Have you been driving it at all during this time? Or intermittantly in small intervals?
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-16-2013, 11:54 PM   #347
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Thanks for the advice Miles.
An odd question, but what did you do with the windshield washer system?
Thanks Ejaz
Originally Posted by ritos530i View Post
Nice work Adam
You're alive!
Thanks Rito
I will admit if felt that way when it first started.
I wish....last time I drove this car was Sept. 2010. I'm getting really excited to drive it again...
Old 06-17-2013, 12:15 AM   #348
WALKD U
My Ride: Just Fast!
Where have I been! Glad to see Progress Adam
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 06-17-2013, 01:23 AM   #349
Diabolu$
My Ride: 330 ci supercharged
Very nice!
Diabolu$ is offline   Reply With Quote
Old 06-17-2013, 01:47 AM   #350
mkodama
mkodama's Avatar
I was young, I had a lot of bad ideas, I took out the washer fluid tank thinking it'd save weight, made a jumper to plug into the level switch connector to make the car not show a low washer fluid light, and tucked the wiring away. I think all the electrical should still be there.
By the looks of it, it looks like I also took out the sprayers and hose that went with it too.
As for where it went, after it was removed, I'm not quite sure. I can check if it's on a shelf somewhere if you want.
Old 06-17-2013, 05:32 AM   #351
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I'm pretty sure I was the bad influence that initiated the Windshield washer delete mod. I went pretty nuts with the 330Ci....at one point it was down to less than 2700 lbs w/o driver or fuel.
I have the washer tank and pump(s) from the 330Ci, but I don't have any of the lines or nozzles. If you could check, it would be much appreciated, as I am looking to re-install all of these parts.
Old 06-17-2013, 09:38 AM   #352
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
Fantastic to see updates.
Did the dual cooler approach with hood venting cause too many clearance issues?
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 06-17-2013, 12:14 PM   #353
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I think it was feasible, but I just didn't have the time to fabricate it. The EGR pump, and windshield washer tank would need to be relocated on the passenger side, which would be fairly complicated.
I've had to drop a number of ideas for the time being to accelerate the running timeline. Lots of these things could be done at a later time, if the existing solutions proved to be ineffective.
Something else to consider is that this was meant to be a car that I would drive while building my next project car to replace the 330Ci. The ideas for that are really radical, so I have to pick my battles regarding time spent developing ideas.
Old 06-17-2013, 03:45 PM   #354
MisterM
My Ride: 03 M3
Thanks for the update Adam. I always enjoy your updates and insight - wherever you post them!
Enjoy
MisterM is offline   Reply With Quote
Old 06-21-2013, 04:30 AM   #355
autospeed_01
My Ride: 2000 328Ci
Half way around the world (in the middle of a class) and I'm still following along and jumping forums to see this build! Great job Adam looks great and as always love the way you put everything together especially with the trans-cooler bracket in the bumper support.
autospeed_01 is offline   Reply With Quote
Old 06-21-2013, 06:05 AM   #356
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Enjoy
Thank you MisterM.
Yup...you are exactly half way around the world from me. (11,700km)
Honestly, the trans cooler bracket is more a matter of convenience in fabrication than functionality. If I was to do it again, I would probably build the bracket into the radiator support assembly, so that the bumper support can be unbolted easily.
For those that wondered why I didn't paint the entire bumper: There may be more changes to it in the middle and on the passenger side in the future.
Also, some may note that I haven't finished connecting the CCV. There is still some work in that area that I haven't got to yet....just waiting on some more electronics to arrive before I finalize how I'm going to do it.
Old 06-21-2013, 06:47 AM   #357
0-60motorsports
Adam, wish I could come over and work in a AM solution for the oem CSL box without drilling it. That would be an awesome yet frustrating challenge.
I'm sorry but I couldn't help laughing at the pics with the fuel rail leaking. It was a DOH moment. Hahahahaha
Old 06-21-2013, 08:25 AM   #358
AudiEtr
My Ride: 330i
Sub'd!
AudiEtr is offline   Reply With Quote
Old 06-28-2013, 11:26 PM   #359
MC330CI
My Ride: 2001 330ci
Congratulations Adam...that's fantastic!
MC330CI is offline   Reply With Quote
Old 06-29-2013, 07:40 AM   #360
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
In many ways I see this build being about the journey and not necessarily the destination.. and I admire your dedication!
Sent from my Galaxy Nexus using BimmerApp mobile app
