Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 4.80 average. Display Modes
Old 04-11-2014, 09:48 AM   #561
mdrobnak
My Ride: 04 330i SMG TT STG1
I love some of the stickers for the key pad LOL
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 04-12-2014, 11:04 AM   #562
Herrubermensch
My Ride: E39 M5 and E46 M3
Fun stuff!
Herrubermensch is offline   Reply With Quote
Old 04-12-2014, 03:09 PM   #563
Twin_Turbo_S54
My Ride: M3
Adam, looking very nice & exciting.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 04-12-2014, 03:50 PM   #564
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Thanks guys!
The bracket is done!!!!
Very happy with how it turned out.
Old 04-12-2014, 09:29 PM   #565
armykyle1
My Ride: 1999 328i
Long read but fantastic work. I love the attention to detail and those welds look amazing. Staying tuned in.
armykyle1 is offline   Reply With Quote
Old 04-15-2014, 04:46 AM   #566
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
To mount the TCU and E888, I had 4 options:
- Double sided adhesive tape
- Velcro (3M high strength)
- External bracket strap
- Bolt the case directly to the mounting bracket
I chose the last option, which I will probably get some flack for, but I'm comfortable with it:
The mounting bracket with self etching primer applied:
Boost solenoid valves do a lot of clicking. Considering I will be running 2 of them, and they will effectively be mounted to the firewall, I decided to isolate them to cut down on some noise. I put a rubber grommet on each side of the mounting surface:
The finished electronics bracket with everything mounted:
The rubber grommets for the boost solenoid valves are visible in the image below:
The Ignitors are mounted against bare aluminum, with thermal paste applied to the contact surface:
You can see where I wiped excess paste away with acetone; it cut away some of the paint.
The electronics bracket in the car:
The next step will be to install Mil-spec connectors on the chassis, and then wiring can start.
Old 04-15-2014, 07:39 AM   #567
unevolved
My Ride: 2003 325i
That looks really badass. You mentioned you're not worried about vibration affecting your components, why is that? Wouldn't it make sense to vibration-isolate that beautiful bracket?
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 04-15-2014, 09:11 AM   #568
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
If these components were mounted directly to the engine, I might consider adding isolation mounts, but the chassis in this location isn't really an issue. Regardless, there are no instructions from Bosch, Motec, or PCS to isolate any of these electronics, so I doubt that typical chassis vibration would be an issue.
The boost solenoids are isolated to reduce noise.
Old 04-15-2014, 09:45 AM   #569
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Awesome updates. Coming along well.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 04-15-2014, 09:59 AM   #570
unevolved
My Ride: 2003 325i
I guess that's true, 6 cylinders are relatively smooth, and so long as you've got not-solid engine mounts, you should be okay. Especially since none of those have accelerometers. (Right?)
Old 04-15-2014, 10:16 AM   #571
Commanderwiggin
My Ride: 900rwhp Turbo M3
Wow
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 04-15-2014, 10:24 AM   #572
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Good question.
I know that the M150 ECU has 3axis internal, precisely to monitor chassis vibrations. (And you can catalog this data) But I'm not sure if they have integrated his into the PDMs. Will check.
Old 04-23-2014, 01:28 PM   #573
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
More goodies for the wiring harness:
An example of one of the seven (7) Mil-Spec connectors being used on the harness:
Old 04-23-2014, 01:34 PM   #574
mdrobnak
Looks great.
As an aside, what camera are you using? Are the connectors / plastic really that colorful?
-Matt
Old 04-23-2014, 03:15 PM   #575
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by mdrobnak View Post
Looks great.
The colourful bits are just the protective caps for shipment.
Colours are generally pretty accurate; I correct white balance and saturation in LR.
Camera: Nikon D200 (2006)
Lens: 24-70 AFS f2.8
That's pretty much my "everything" combo...although I've got a few other bits in my bag:
12-24mm f4
20mm f2.8
85mm f3.5 Macro
70-200mm f2.8 VR
300mm f2.8
Old 04-23-2014, 03:50 PM   #576
0-60motorsports
You crazy man you! Looking awesome.
Old 05-22-2014, 04:37 PM   #577
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Anything new?
Old 05-22-2014, 05:53 PM   #578
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Very very well done my friend.... Keep up the good work....
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-22-2014, 10:49 PM   #579
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by aggieE46 View Post
Anything new?
Yes, but nothing with pictures.
Details are dragging me down, but they are important to me, so I'm taking my time with them. For example wiring harness labels, and crimp splices...
Also, Matt and I are just starting to collaborate on M1 Build Projects, so I expect that to take up a lot of both of our free time in the near future...
Thank you.
Old 05-23-2014, 02:09 PM   #580
BartenderPlease
My Ride: '03 540i/6 M-Sport
64 Inputs:
Not including the transmission controller...
Wow. Never saw this build. Those inputs! Another great PEI thread.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
