Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 4.80 average. Display Modes
Old 06-03-2010, 07:26 AM   #61
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
why doesn't the 325 get any love for turbo applications?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 06-03-2010, 10:30 AM   #62
BimmerDude18
My Ride: 1998 528i
325 will, xi will not...
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 06-06-2010, 10:59 AM   #63
Bimmer Dude Xi
im gussing the front axle will get in the way of the exhaust system associated with the turbo setup
Old 06-06-2010, 03:13 PM   #64
BimmerDude18
My Ride: 1998 528i
Yeah, top mount is the only possibility for you guys.
-Tyler
Old 06-09-2010, 11:17 PM   #65
TrippinBimmer
My Ride: Just Fast!
Status?
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 06-10-2010, 03:59 AM   #66
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by TrippinBimmer View Post
Status?
-TrippinBimmer
The kit is sitting on a shelf at my shop. I've been so busy with other stuff that I haven't had a chance to even look at it.
Today I'm flying to Montreal for the F1 race, which I planned with 2 friends nearly 6-7 months ago. Life just seems to be in high gear lately....
Hopefully I'll be able to install it in August, but I need to be done of a couple of other projects first.
Old 06-10-2010, 06:50 AM   #67
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Take some good pics at F1!
Old 06-10-2010, 11:46 PM   #68
TrippinBimmer
My Ride: Just Fast!
Keep me posted. I want to go boosted this Fall.
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
Old 06-20-2010, 03:41 AM   #69
NaZty NaZe One!
My Ride: 02' 330ci "Ebony"
Send a message via AIM to NaZty NaZe One!
any updates?
Photobucket
NaZty NaZe One! is offline   Reply With Quote
Old 06-20-2010, 06:13 PM   #70
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by NaZty NaZe One! View Post
any updates?
I wish I had more to report, but I'm simply swamped with other things. It would be really unfair to a number of other parties if I started installing the kit without proceeding with what I promised.
I might have some pictures of components that have really impressed me, but the install must wait....
Old 06-20-2010, 07:03 PM   #71
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Ok I guess we will take photos until that time. Oh well. LMBO JK
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 07-13-2010, 09:18 PM   #72
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
A minor update, but I think it's fairly important to track this kind of stuff.
The 3.38 open diff has been swapped for a 4.10 LSD, and I took the car to the track.
I ran a best of 14.9891 @ 92.19 MPH in warmer weather than my last trip to the track. The car ran consistent 2.2X sec 60fts on a non-prep'd track, with a best of 2.17. Where with the 3.38 the car would cross the traps at 6300+ in 3rd gear, the 4.10 prompted a shift into 4rth gear at about the 990ft mark and saw just under 6k RPM crossing the stripe.
As a reminder, in cooler weather with a prepared track the best 60ft I saw was 2.27 and it was far from being consistent. The best run was a 15.1590 @ 92.37 MPH
The real tell of the tale is at the 1/8th mile however, as that's where the true differences between the 3.38 and 4.10 ratios show up:
The 3.38 did a 9.8140 @ 73.14 MPH.
The 4.10 did a 9.67 @ 74.52 MPH.
With the 4.10 LSD, the darn automatic transmission hangs onto 3rd gear as it bounces off of the rev limiter before shifting into 4th. (It does the same shifting into 3rd but you don't notice it as much) Where we have a clear 1+ MPH gain with the 4.10 at the 1/8th...it's disappeared by the time the car has hit the 1/4.
Before I do any more "go fast" stuff with the car, I need to sort out the automatic gear shifting issues. Under full throttle in "Manual shift" mode, it simply doesn't shift when you tell it to. Under part throttle, it shifts no problem.
Old 07-13-2010, 09:24 PM   #73
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Adam, a local car here has that same issue with the auto not shifting when it's supposed to. We actually boosted it with a simple 8psi AA kit and in 3rd gear sometimes it damn near goes past 7k and bounces before it shifts. No idea why, but I'd love to hear about you figuring it out!
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 07-13-2010, 09:38 PM   #74
BimmerDude18
My Ride: 1998 528i
Is this Stan?
-Tyler
Old 07-14-2010, 07:13 AM   #75
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
David,
I'm installing a data logger into the 330i to more carefully watch what's actually going on. I'll be able to log when I "ask" for a shift, when it actually happens, and other parameters like the TPS, RPM and acceleration Gs. The next step after that is to change the transmission fluid and filter to see if that helps. (Switching to Royal Purple) After that, I'll probably try ESS's transmission software.
Old 07-14-2010, 02:40 PM   #76
ritos530i
David,
Adam,
Is this a SMG tranny?
Old 07-14-2010, 03:26 PM   #77
SaaDiesel
My Ride: 02 330i Tech 1
Completely stock steptronic 5 speed.
E46-7 years STRONG
ZSP/ZPP/ZCW
BFP Intake, Euro Cooling Ducts, OEM Clear Lenses, 8000K HIDS
Matte Black-Grill, Headlight, Window, & Body Trim
SaaDiesel is offline   Reply With Quote
Old 07-14-2010, 03:30 PM   #78
ritos530i
I am asking because I knew that HPF was doing some upgrades with the SMG tranny's to handle extra boost and this sounds very similar to what Adam is having problems with. So these are very different trannys I assume.
Old 07-14-2010, 03:43 PM   #79
I*do*Werke
My Ride: E46 --> E30
In for updates
^M52B28 Swapped E30^
I*do*Werke is offline   Reply With Quote
Old 07-14-2010, 04:07 PM   #80
BimmerDude18
My Ride: 1998 528i
The SMG in the M3 is the same as the 6 speed in the M3 but without detents and with an external shift mechanism that isn't driver controlled.
The auto in Adams car is a ZF 5-speed slushbox (IIRC).
-Tyler
