Old 05-21-2010, 03:42 PM   #1
tedheadfred
My Ride: 2001 E46 convertible
Swap 5 speed for 6 speed (330ci)
Hi all,
I've been impressed wiht the number of automatic cars that have been swapped to manuals.
I've already got a manual (5 speed) and am interested in a swap to a 6 speed. Any guidance anyone could give in getting that done (did they do it themselves or have a shop do it, were they happy with the outcome, what would they do differently, etc), that would be appreciated.
Thanks!
tedheadfred is offline   Reply With Quote
Old 05-21-2010, 04:45 PM   #2
dpgrand
My Ride: 2005 330xi
There are numerous threads on this....
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 05-21-2010, 07:36 PM   #3
bigdog2003_99
My Ride: 2009 Audi B8
i had all the parts to do this to my 323ci but i ended up trading them for some schrick cams, headers and money. if you can find a 6sp tranny and driveshaft for a good price i'd go for it, same with the clutch, flywheel, shifter assembly, and trans mount, btw the parts are cheaper now than they were when i was going to do it
the 6sp is nothing special compared to a 5sp, unless you are running aggressive gears, it has 5 speed gearing with an extra gear
just search around and you should find the info you need
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 05-21-2010, 07:48 PM   #4
Define ///M3
My Ride: Dream 2 B Suprchrgd
for all the work involved...is it really worth an extra gear?
AKA Huggy1989
"I expect to pass through life but once. If, therefore, there can be any kindness I can show, or any good thing I can do to any fellow being, let me do it now, and not defer or neglect it, as I shall not pass this way again."- WP
Define ///M3 is offline   Reply With Quote
Old 05-22-2010, 03:49 PM   #5
bigjae1976
bigjae1976's Avatar
My Ride: A car
Yeah, not really worth it unless you get some cool custom gearing or something.
bigjae1976 is online now   Reply With Quote
Old 05-22-2010, 03:54 PM   #6
SalM
My Ride: Shhh
It would be cool, but I dont think all the time and money is worth it dont you think? unless M3 swap
SalMPhotography
SalM is offline   Reply With Quote
Old 05-22-2010, 06:48 PM   #7
mrshelley
My Ride: 2004 330i
The 6 speed gearbox is 25lbs heavier than the 5 speed ZF.
Old 06-01-2010, 02:46 PM   #8
Lemonsqr
My Ride: 2001 TiAg 330i
The only way i could justify it is if a person did a diff swap as well so the 6th gear will drop cruising down to a lower RPM.....having said that, I still want a 6sp trans cause I have never had one
Lemonsqr is offline   Reply With Quote
Old 06-01-2010, 05:43 PM   #9
bigdog2003_99
i have a 6sp in my zhp, and would like to buy the parts down the road again to swap my 323 to 6sp also
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
